CP30220XW
CP30220XW
    CLIFF
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat5e 无屏蔽
CP30220XW 数据手册
CLIFF CAT5e RJ45 FEEDTHROUGH CONNECTOR Feedthrough Features l Fits standard XLR Ø24mm cutout. l No soldering or punch termination. Use standard cable for each connector style. l Front or rear mounted. l Low rear profile General: Please note: Functionality is affected by cable quality, length and cable wiring configuration. Other models available: Part No. CP30220 Cat5e RJ45 Black plastic frame, CSK holes CP30220W Cat5e RJ45 White plastic frame, CSK holes CP30220M Cat5e RJ45 Nickel plated metal frame, CSK holes CP30220M3 Cat5e RJ45 Nickel plated metal frame, M3 holes CP30220MB Cat5e RJ45 Black metal frame, CSK holes CP30220M3B Cat5e RJ45 Black metal frame, M3 holes CP30220X Cat5e RJ45 Black plastic frame, PLAIN holes CP30220XW Cat5e RJ45 White plastic frame, PLAIN holes © CLIFF 04/2022 ISS.3 Material: 1. RJ45 In-Line Coupler: ABS UL94-V0 2. RJ45 In-Line Coupler Contact: Phosphor Bronze, 3-50 micro inches gold plating over nickel plate. 3. PCB: FR4 4. Frame: Polyamide UL94-V2 Performance: 1. T568A & T568B wiring. 2. Meet ISO/IEC 11801 and EN50173 3. Meet ANSI/TIA/EIA 568B.2 4. Rating 125VAC RMS 1.5A 5. Operating Temperatures: Min -10°C Max +60°C For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30220XW 价格&库存
很抱歉,暂时无法提供与“CP30220XW”相匹配的价格&库存,您可以联系我们找货
