CLIFF
CAT.6 RJ45 SHIELDED FEEDTHROUGH
CONNECTOR
Material:
1. RJ45 In-Line Coupler: ABS UL94-V0 Fully Shielded
Feedthrough Features
2. RJ45 In-Line Coupler Contact:
l Fits standard XLR Ø24mm cutout.
Phosphor Bronze, 3-50 micro inches
l No soldering or punch termination. Use standard cable for
gold plating over nickel plate.
each connector style.
3. PCB: FR4
l Front or rear mounted.
4. Plastic Frame: Polyamide UL94 V-2
l Low rear profile
5. Metal Frame: Diecast, Black or Nickel plated
General:
Performance:
Please note: Functionality is affected by cable quality, length
1. T568A & T568B wiring.
and cable wiring configuration.
2. Meet ISO/IEC 11801 and EN50173
3. Meet ANSI/TIA/EIA 568B.2
4. Rating: 125VAC RMS 1.5A
Other models available:
5. Operating Temperatures: Min -10°C Max +70°C
Part No.
CP30222S
Cat.6 RJ45 Shielded Black plastic frame, CSK holes
CP30222SW Cat.6 RJ45 Shielded White plastic frame, CSK holes
CP30222SM
Cat.6 RJ45 Shielded Nickel plated metal frame, CSK holes
CP30222SM3 Cat.6 RJ45 Shielded Nickel plated metal frame, M3 holes
CP30222SMB Cat.6 RJ45 Shielded Black metal frame, CSK holes
CP30222SM3B Cat.6 RJ45 Shielded Black metal frame, M3 holes
CP30222SX
Cat.6 RJ45 Shielded Black plastic frame, PLAIN holes
CP30222SXW Cat.6 RJ45 Shielded White plastic frame, PLAIN holes
© CLIFF 04/2022 ISS.4
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“CP30222SXW”相匹配的价格&库存,您可以联系我们找货
