CP30700GM
CP30700GM
    CLIFF
    适配器连接器 HDMI,插座 至 HDMI,插座 面板安装,法兰
CP30700GM 数据手册
CLIFF ISS. AMEND DATE 1 ISSUED 05/01/21 DUAL MOUNT CAN BE FRONT OR REAR MOUNTED 17.15 (0.675") HOLES TO SUIT SCREW USED 22.86 (0.900") 29.00 Ø3.20 PLAIN HOLE CP30700GMX1 29.0 19.0 2.80 16.7 2.3 29.00 35.5 22.5 RoHS ü COMPLIANT TOLERANCE Material: 1. Insert: ABS UL94 HB 2. FT Frame: Diecast, Nickel plated 3. Shell: Gold plated 4. Contacts: Gold Plated 4x HOLE VARIANTS Ø3.2mm CSK 90° x Ø5.85 M3 x 0.5 THREAD #4-40 UNC THREAD PLAIN Ø3.2 HOLES Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2021 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: See Notes See Notes DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. 3rd ANGLE PROJECTION: NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± UNLESS OTHERWISE STATED DO NOT SCALE DUAL SLIM METAL FT HDMI F-F DRWG. No. CP30700GM FORM: A4DRWGH
CP30700GM 价格&库存
很抱歉,暂时无法提供与“CP30700GM”相匹配的价格&库存,您可以联系我们找货
