CP30711
CP30711
    CLIFF
    适配器连接器 USB-C(USB TYPE-C),插座 至 USB-C(USB TYPE-C),插头 面板安装,法兰
CP30711 数据手册
CLIFF DUALSLIM USB-C Female-Male FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30711 CP30711X CP30711X1 DUALSLIM USB-C F-M Black plastic frame, CSK holes DUALSLIM USB-C F-M Black plastic frame, Ø2.5 PLAIN holes DUALSLIM USB-C F-M Black plastic frame, Ø3.2 PLAIN holes Feedthrough Features — Fits standard rectangular cutout. — Front or rear mounting through the panel. — Various hole mounting options. — No soldering or punch termination. Use standard cable for each connector style. — Low rear profile. General: Please note: Functionality is affected by cable quality, length and cable wiring configuration. © CLIFF 11/2020 ISS.1 Material: 1. Insert: ABS - UL94 HB 2. Plastic Frame: Polyamide UL94 V-2 USB-C Specification: Maximum Rated Current - 3A Maximum Working Voltage - 30V Withstanding Voltage - 100V for 1 minute. Contact Resistance - 40 Milli-ohms Max. Insulation Resistance - 100 Mega-ohms Min. Insulator Flammability Rating - UL-94V0 Insertion Life - 10,000 Cycles. For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30711 价格&库存
很抱歉,暂时无法提供与“CP30711”相匹配的价格&库存,您可以联系我们找货
