19050351WEC
19050351WEC
    CMLTECHNOLOGIES
    M8 LED IND 24VDC GREEN REC
19050351WEC 数据手册
PRODUCT DATA SHEET Part Number: Type LED Size M8 Rating 24Vdc 1905x35xWEC Description Recessed LED Indicator with Leads Dimensions in mm (Not to scale) 190 ± 10 29 3 10 ⌀ 9.5 Red wire: +ve Black wire: -ve White plastic body 5mm Partial Strip SW10 M8 x 0.75 Part Number 1905x353WEC 1905x351WEC 1905x352WEC 1905x357WEC Colour Red Green Yellow Blue x = 0: Satin chrome bezel Voltage 24Vdc 24Vdc 24Vdc 24Vdc Typ. Current (mA) 20 20 20 20 x = 1: Black chrome bezel Typ. Luminous Intensity (mcd) 80 32 32 60 x = 2: Matt chrome bezel Notes: 1 2 3 4 5 6 7 8 9 10 11 12 13 Electrical & optical data are measured at an ambient temperature of 25ºC The stated luminous intensity is for dc operation Due to component tolerances, colour temperature variations may be observed Storage temperature range: -25 ºC to +80ºC Operating temperature range: -20 ºC to +60ºC Sealed to IP67 above panel when the supplied gasket used The plastic (polycarbonate) has limited chemical resistance The plastic cartridge contains 3 wire exit holes - the rear of the product is not sealed Lead wires are internally soldered Lead wires: 7/0.2 (24 AWG) stranded copper, tinned annealed copper wire, PVC insulation Marking: Part number, voltage rating, LED colour and date code REACH SVHC compliant This product contains free-machining brass and is RoHS compliant via exemption clause Annex iii 6 (c) of EU Directive 2011/65/EU [Copper alloy containing lead up to 4% by weight] Page 1 of 1 Issue 1: 21Feb20 CML Innovative Technologies Ltd • 69-70 Eastern Way • Bury St Edmunds • Suffolk • IP32 7AB • England Tel: +44 (0) 1284 714700 • Fax: +44 (0) 1284 754406 • Email: bury@cml-it.com • www.cml-it.com Registered Office: Eastern Way, Bury St Edmunds – Registration No. 265006 England
19050351WEC 价格&库存
很抱歉,暂时无法提供与“19050351WEC”相匹配的价格&库存,您可以联系我们找货
