INCORPORATED
THIN-PAC
THIN-PAC
TM
GENERAL
THIN-PACs are extremely thin, highly efficient
surface mount inductors specifically designed for
applications where physical size, especially component
height, is critical. With heights as low as 1.8 mm,
THIN-PACs offer circuit design engineers a choice of
very powerful inductors in very small and thin packages.
THIN-PACs deliver inductance values from 0.47 to
47.0 µH with current ranges from 0.59 to 2.8 Amps.
They are manufactured using toroidal cores for low EMI,
high Q, and high efficiency. The devices incorporate
advanced technology materials and processes resulting
in the highest possible power density in the thinnest
possible case.
THIN-PACs provide circuit design engineers the
highest performance to height ratio of any SMT
inductors. Their ideal applications include DC-DC
converters, PC cards, disk drives, and small-scale
power supplies.
THIN-PACs are packaged on standard 13” reels to
facilitate pick-and-place assembly. Their rugged
construction permits normal exposure to infrared reflow
soldering to +240°C.
In addition to the standard inductance values shown,
modified THIN-PAC inductors are available to meet your
high volume requirements.
FEATURE - BENEFITS
• Ultrathin Product Profile - as Thin as 1.8 mm
• Highest Performance to Height Ratio of Any
SMT Inductors
• Inductance Range from 0.47 to 47.0 µH
• Current Range from 0.59 to 2.8 Amps
• Toroidal Cores provide Low EMI
• High Efficiency and High Q
• Supplied in Tape-and-Reel Packaging
for Pick-and-Place Assembly
• Modified Standard Products Available
1
INCORPORATED
Coiltronics designs and manufactures standard and
custom electromagnetic components. Contact the factory
or your Coiltronics representative with your transformer
and inductor requirements.
6000 PARK OF COMMERCE BOULEVARD • BOCA RATON, FL 33487 • Phone 561-241-7876 • Fax 561-241-9339
THIN-PAC
TP1-1R0
THIN-PAC 1 FAMILY TABLE
(1)
OCL
µH +/-20%
(2)
IRMS
Amperes
(3)
(4)
ISAT
DCR
Amperes Ohms max.
TP1-R47
0.47
0.544
1.7
3.0
0.1085
*TP1-1R0
1.0
1.17
1.5
2.6
0.1401
TP1-1R5
1.5
1.57
1.4
2.2
0.1560
*TP1-2R2
2.2
2.55
1.3
1.8
0.1876
TP1-3R3
3.3
3.73
1.2
1.5
0.2246
*TP1-4R7
4.7
5.10
1.1
1.3
0.2647
TP1-6R8
6.8
7.45
0.96
1.1
0.3240
*TP1-100
10.0
10.31
0.90
0.92
0.3739
*TP1-150
15.0
16.57
0.81
0.73
0.4612
*TP1-220
22.0
24.25
0.74
0.60
0.5483
*TP1-330
33.0
38.56
0.66
0.47
0.6847
*TP1-470
47.0
49.49
0.62
0.43
0.7699
Notes:
m Henries or m Watt-Seconds
Inductance
µH (rated)
10.0
Typical Inductance & Energy vs Saturation Current
1.0
0.1
0.01
0.0 0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6 1.8
2.0
2.2
2.4 2.6
Amperes (Peak)
Energy
Inductance
TP1-100
100.0
(1) Open Circuit Inductance Test Parameters: 100 KHz, 0.250 Vrms, 0.0 Adc.
(2) RMS current for an approximate ∆T of 40°C. at an ambient temperature of 85°C.
(3) Peak current for approximately 30% rolloff.
(4) Values @ 20°C.
*BOLD are available from stock
Part
Number
TM
10.0
1.0
0.1
Coiltronics Incorporated reserves the right to change component specifications without notice.
0.0
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
Amperes (Peak)
MECHANICAL DIAGRAM
Inductance
TOP VIEW
TP1-470
Pin # 1 Indicator.
1
CONNECTION DIAGRAM
1
9.40 12.20
max.
9.40
2
2
1.27
SIDE VIEW
100.0
PACKAGING INFORMATION
1.8
max.
10.0
1.0
0.1
3.18 max.
Energy
0.0
0.1
0.2
Parts are packaged on 13” reels. 2250 parts per reel.
PCB PAD LAYOUT
0.4
0.5
0.6
0.7
Inductance
Energy
2.0
1.5 Dia.
1
0.3
Amperes (Peak)
4.0
Pin #1 Indicator.
A
1.75
4.19
11.5
Component View 6.48
14.86
24.0
12.6 9.9
ACTUAL SIZE
THIN PAC 1
2.4
2
6.35
INCORPORATED
SECTION A-A
3.9
9.9
12.0
A
Direction of feed
2
THIN-PAC
TM
TP2-1R0
Inductance
µH (rated)
OCL
µH +/-20%
(2)
IRMS
Amperes
(3)
(4)
ISAT
DCR
Amperes Ohms max.
TP2-R47
0.47
0.399
2.2
3.2
0.0537
*TP2-1R0
1.0
1.00
1.8
2.1
0.0805
TP2-1R5
1.5
1.53
1.7
1.7
0.0910
*TP2-2R2
2.2
2.15
1.5
1.4
0.1110
TP2-3R3
3.3
3.45
1.4
1.1
0.1328
*TP2-4R7
4.7
4.56
1.3
0.97
0.1472
TP2-6R8
6.8
6.84
1.2
0.80
0.1797
*TP2-100
10.0
9.53
1.1
0.68
0.2151
*TP2-150
15.0
14.83
1.0
0.54
0.2512
*TP2-220
22.0
23.11
0.88
0.44
0.3269
*TP2-330
33.0
32.34
0.67
0.37
0.5677
*TP2-470
47.0
47.68
0.60
0.30
0.6962
Notes:
10.0
1.0
0.1
0.2
0.0
0.4
0.6
1.4
1.6
1.8
2.0
2.2
Energy
100.0
(4) Values @ 20°C.
10.0
1.0
0.1
0.0
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
Amperes (Peak)
MECHANICAL DIAGRAM
Energy
Inductance
TOP VIEW
TP2-470
Pin # 1 Indicator.
1
CONNECTION DIAGRAM
1
9.40
6.60 max.
6.60
2
1.27
SIDE VIEW
100.0
10.0
1.0
0.1
0.0
PCB PAD LAYOUT
1.2
TP2-100
2.51 max.
1.0
Inductance
2
0.8
Amperes (Peak)
Part
Number
(1)
THIN-PAC 2 FAMILY TABLE
0.1
0.2
0.3
0.4
Amperes (Peak)
Parts are packaged on 13” reels. 2000 parts per reel.
Inductance
0.5
0.6
Energy
2.2
max.
1.5 Dia.
2.0
Pin #1 Indicator.
1
4.0
A
1.75
4.06
11.5
Component View
3.81
11.93
24.0
9.8 7.1
ACTUAL SIZE
THIN PAC 2
2.5
2.9
SECTION A-A
7.1
2
5.08
3
INCORPORATED
12.0
A
Direction of feed
THIN-PAC
TP3-1R0
THIN-PAC 3 FAMILY TABLE
(1)
OCL
µH +/-20%
(2)
IRMS
Amperes
(3)
TP3-R47
0.47
0.417
2.6
4.2
0.0644
*TP3-1R0
1.0
1.15
2.1
3.4
0.0949
TP3-1R5
1.5
1.65
2.0
2.8
0.1064
*TP3-2R2
2.2
2.24
1.8
2.4
0.1241
TP3-3R3
3.3
3.68
1.7
1.9
0.1471
*TP3-4R7
4.7
5.45
1.5
1.6
0.1806
TP3-6R8
6.8
7.47
1.4
1.3
0.2051
*TP3-100
10.0
11.09
1.3
1.1
0.2550
*TP3-150
15.0
15.17
1.2
0.97
0.2966
*TP3-220
22.0
23.99
1.1
0.78
0.3700
*TP3-330
33.0
35.08
0.96
0.64
0.4433
*TP3-470
47.0
47.71
0.90
0.55
0.5122
Notes:
10.0
(4)
ISAT
DCR
Amperes Ohms max.
Inductance
µH (rated)
1.0
0.1
0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0 3.2 3.4
Amperes (Peak)
TP3-100
(4) Values @ 20°C.
100.0
10.0
1.0
0.1
0.0
0.1
0.2
0.3
0.4
0.6
0.7
0.8
0.9
1.0
1.1
1.2
1.3
Energy
Inductance
TOP VIEW
TP3-470
Pin #1 Indicator.
CONNECTION DIAGRAM
1
1
10.80 13.59
max.
10.80
2
1.27
SIDE VIEW
100.0
10.0
1.0
0.1
0.0
0.1
0.2
0.3
3.68 max.
0.5
Amperes (Peak)
MECHANICAL DIAGRAM
2
Energy
Inductance
Part
Number
TM
PCB PAD LAYOUT
Inductance
2.0
1.5 Dia.
Pin # 1 Indicator.
0.5
0.6
0.7
0.8
0.9
Amperes (Peak)
Parts are packaged on 13” reels. 1500 parts per reel.
2.2
max.
0.4
A
4.0
Energy
1.75
1
4.19
11.5
Component View 7.87
2
7.40
16.25
24.0
14.0 11.3
ACTUAL SIZE
THIN PAC 3
2.5
SECTION A-A
4.1
11.3
16.0
A
Direction of feed
INCORPORATED
4
THIN-PAC
TM
TP4-1R0
Inductance
µH (rated)
(1)
OCL
µH +/-20%
(2)
IRMS
Amperes
(3)
(4)
ISAT
DCR
Amperes Ohms max.
TP4-R47
0.47
0.507
2.8
6.3
0.0411
*TP4-1R0
1.0
1.09
2.4
4.4
0.0536
TP4-1R5
1.5
1.85
2.2
3.4
0.0641
*TP4-2R2
2.2
2.22
2.1
3.2
0.0715
TP4-3R3
3.3
3.21
2.0
2.7
0.0802
*TP4-4R7
4.7
5.05
1.8
2.2
0.1037
TP4-6R8
6.8
6.54
1.7
1.9
0.1168
*TP4-100
10.0
10.14
1.5
1.6
0.1458
*TP4-150
15.0
14.49
1.4
1.3
0.1727
*TP4-220
22.0
21.33
1.0
1.1
0.3068
*TP4-330
33.0
32.74
0.80
0.87
0.4922
*TP4-470
47.0
47.42
0.59
0.72
0.9080
Notes:
10.0
1.0
0.1
0.0
0.0
1.0
0.5
1.5
2.0
2.5
3.0
3.5
4.5
4.0
Amperes (Peak)
Energy
Inductance
TP4-100
Part
Number
THIN-PAC 4 FAMILY TABLE
(4) Values @ 20°C.
100.0
10.0
1.0
0.1
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6
Amperes (Peak)
MECHANICAL DIAGRAM
Energy
Inductance
TOP VIEW
TP4-470
Pin #1 Indicator.
1
9.40 12.20
max.
CONNECTION DIAGRAM
1
9.40
2
2
1.27
SIDE VIEW
100.0
10.0
1.0
0.1
3.43 max.
3.0
max.
0.2
0.3
0.4
0.5
Amperes (Peak)
Inductance
0.6
0.7
Energy
2.0
1.5 Dia.
Pin # 1 Indicator.
4.0
4.19
Component View 6.48
0.1
PCB PAD LAYOUT
1
A
1.75
11.5
14.86
24.0
12.6 9.9
ACTUAL SIZE
THIN PAC 4
3.3
2
6.86
3.9
SECTION A-A
9.9
12.0
A
Direction of feed
5
INCORPORATED
THIN-PAC
TM
ENVIRONMENTAL SPECIFICATIONS
DESIGN KITS AVAILABLE
• Storage Temperature Range:
-40°C to +125°C.
• Operating Ambient Temperature Range:
-40°C to +85°C
Range is application specific
• Infrared Reflow Temperature:
+240°C for 30 seconds maximum
• Meets UL 94V-O Flammability Standard
To assist in prototyping, Coiltronics offers low-cost Design
Kits for the THIN-PAC product family. Each Kit contains an
assortment of inductance values complete with
specifications. Coiltronics Design Kits can save hours
(even days) of searching for parts and waiting on samples.
• Order Part Number TPK01-13692
Information furnished herein by Coiltronics Incorporated is believed to be accurate and reliable.
However, Coiltronics Incorporated cannot assume responsibility for the use of any of our
components, nor for any liabilities which may result from component use. Coiltronics Incorporated
Life Support Policy: Coiltronics Incorporated does not authorize the use of any of its products for
use in life support devices or systems without the express written approval of an officer of
Coiltronics Incorporated. Life support systems are devices which support or sustain life, and whose
failure to perform, when properly used in accordance with instructions for use provided in the
labeling, can be reasonably expected to result in significant injury to the user.
©1997 Coiltronics Incorporated. All rights reserved.
INCORPORATED
Distributed by BRAVO ELECTRO COMPONENTS, INC. • Phone 800-392-6318 • Fax 408-783-8555
6
很抱歉,暂时无法提供与“TP2-1R0-R”相匹配的价格&库存,您可以联系我们找货
