MENT1150A4851Q01
MENT1150A4851Q01
    SLPOWER
    AC/DC DESKTOP ADAPTER 48V 150W
MENT1150A4851Q01 数据手册
MENT1150 Universal Input 150 Watt Series Medical / ITE Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop Style with LED Power-On indicator •12V to 48V Single Output Models, up to 150W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No Load Power Consumption 100K hours (calculated, 25 C at full load) Hold-up Time 20 ms min. @ 115VAC Overvoltage Protection 130% of nominal output voltage Overload Protection 120-180% of full rated load, auto-recovery Short Circuit Protection Provided with no damage to supply Output Voltage See chart Overtemperature Protection Output Power See chart Input Harmonics Meets IEC61000-3-2 1% pk-pk max., 20MHz BW Safety Standards IEC/EN/UL60601-1 & EN/IEC/UL60950-1 2nd edition Ripple and Noise Line/Load Regulation Including Cord: Line: +/- 1%, Load: +/-5% Switching Frequency Transient Response Maximum deviation of 5% with 25% to 75% load change and 0.2A/uSec slew rate Not required Isolation Minimum Load Case Material Case Dimensions Altitude Black 94V0 Polycarbonate see mechanical drawing -500 to 10,000 ft, operating; -500 to 40,000 ft, non-operating Operating Temperature Temperature Coefficient Latched, requires input recycling 40kHz to130kHz , variable Input-Output: 4000VAC, Input-GND: 1500VAC, Output-GND: 700VDC 0° to 40°C Full load Derate linearly to 40% of full rated load at 70°C 0.04% per °C, maximum Storage Temperature Relative Humidity -40°C to +85°C 5% to 95%, non-condensing EMI/EMC Compliance Conducted Emissions FCC Part 15 Subpart B, Class B, EN55011 Class B, EN55024 Radiated Emissions FCC Part 15 Subpart B, Class B, EN55011 Class B, EN55024 Voltage Fluctuations EN61000-3-3 Complies (dmax
MENT1150A4851Q01 价格&库存
很抱歉,暂时无法提供与“MENT1150A4851Q01”相匹配的价格&库存,您可以联系我们找货
