NOTES:
1. ALL PARTS TO BE BULK PACKED
2. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE
3. DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS
ASS'Y P/N
GROMMET SIZE
W6282-XPG-P-311
CABLE O.D. .09-.14 [2.3 - 3.6]
W6282-XPG-P-315
ASSEMBLY P/N
CONTACTS
CABLE O.D. .15-.17 [3.8 - 4.3]
W6282-2PG-P-3XX
2 #20
W6282-XPG-P-318
CABLE O.D. .18-.20 [4.6 - 5.1]
W6282-3PG-P-3XX
3 #20
W6282-XPG-P-321
CABLE O.D. .21-.23 [5.3 - 5.8]
W6282-4PG-P-3XX
4 #20
W6282-5PG-P-3XX
5 #20
W6282-6PG-P-3XX
6 #20
W6282-XPG-P-3XX
.250
6.4
DAISY CHAIN GROMMETS
FOR W6282-XPG-P-3DC
.125 I.D. FOR CABLES .09-.14 [2.3 - 3.6] O.D.
.188 I.D. FOR CABLES .18-.20 [4.6 - 5.1] O.D.
.250 I.D. FOR CABLES .24-.26 [6.1 - 6.6] O.D.
GROMMET SIZE FOR
SINGLE GROMMET OR
"DC" FOR DAISY CHAIN
1.325
33.7
NUMBER OF CONTACTS
CUSTOMER PRINT
.125
3.2
.188
4.8
.375
9.5
TYP
.900
22.9
SHOWN ASSEMBLED
FOR CUSTOMER REFERENCE ONLY
.078
2
KEY
.931
23.6
.430
10.9
.688
17.5
KEY
WIRING END
MATING FACE
W6282-2PG-P-3XX SHOWN
WITHOUT HARDWARE
W6282-XPG-P-3XX
PART
NUMBER:
GROMMET
MAT'L: SANTOPRENE, BLACK
CABLE-END HOUSING
MAT'L: UV PBT, BLACK
COUPLING RING
O-RING
MAT'L: SILICONE, RED
SPRING
MAT'L: STAINLESS STEEL
KEY
1
KEY
2
1
3
WIRING END
W6282-2PG-P-3XX
(2-6) #20 PIN CONTACT, SOLDER
MAT'L:COPPER ALLOY, GOLD PLATED
KEY
2
WIRING END
W6282-3PG-P-3XX
1
2
BACKSHELL
KEY
4
3
KEY
1
5
4
2
3
WIRING END
W6282-4PG-P-3XX
WIRING END
W6282-5PG-P-3XX
1
6
CUSTOMER APPROVAL
5
2
4
3
WIRING END
W6282-6PG-P-3XX
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
RoHS COMPLIANT
A
MA
03-02-20
RELEASED PER PDR 16014-7
PNK
11-25/19
BACKSHELL P/N 6284 CHANGES TO 6284V4
PNK
05-10-19
PDR 16014
DATE
DESCRIPTION
REV. INIT.
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.010
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
ORIG. DRAWN BY:
DATE:
05-10-19
PNK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 1
FILE:
W6282-XPG-P-3XX
DIRECTORY:
SLW
CABLE-END ASSEMBLY
2-6 #20 PIN CONTACTS, SOLDER
INSTA-CLICK™ MINI-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W6282-XPG-P-3XX
REV
A
很抱歉,暂时无法提供与“W6282-3PG-P-3DC”相匹配的价格&库存,您可以联系我们找货
