MFG.
ENG.
APPROVED BY:
DATE:
APPROVED BY:
DATE:
QA
"Z"±.010
SEE CHART
NOTES:
1. CONNECTORS TO BE PACKED IN PARTITION BOX, 200 PC PER BOX
BOTTOM BOX P/N: 006K580, TOP BOX P/N: 006K580A, BOX DIVIDER: 006K540.
HEX NUT AND GASKETTO BE BULK PACKED IN A SEPARATE BAG.
INNER BOX LABEL (P/N: LAB-0036) WITH CXA PART NUMBER, QUANTITY,
LOT # AND DATE CODE TO BE PLACED ONTO THE TOP BOX (P/N: 006K580A).
CONTACT QTY.
HOUSING P/N
"X" REF
"Y" REF
"Z"
W7281-2SG-P-3ES
2 #20
6286V4P-21
0.710
0.090
0.145
W7281-3SG-P-3ES
3 #20
6286V4P-31
0.663
0.043
0.192
W7281-4SG-P-3ES
4 #20
6286V4P-41
0.710
0.090
0.145
W7281-5SG-P-3ES
5 #20
6286V4P-51
0.710
0.090
0.145
W7281-6SG-P-3ES
6 #20
6286V4P-61
0.663
0.043
0.192
EPOXY
P/N: ES
P/N: W7281-XSG-P-3ES
CONXALL
QTY.:
Lot:
Date Code:
2.
3.
4.
5.
6.
ASSEMBLY P/N
"Y" REF
SEE CHART
CONTACTS TO BE INSERTED INTO HOUSING.
BACK OF CONNECTOR TO BE FILLED WITH BLACK EPOXY (P/N: ES)
PARTS TO BE 100% INSPECTED FOR DEFECTS.
SEE DRAWING HPMISTD FOR HOLE PATTERN.
ALL REFERENCE DIMENSIONS ARE WITHIN ±.015 UNLESS OTHERWISE NOTED
ASSEMBLED VIEW
W7281-2SG-P-3ES SHOWN
.805 REF
"X" REF
SEE CHART
.570±.003
D-FLAT
.134 REF
.050 REF
.555 REF
KEY
KEY
(2-6) #20 SOCKET CONTACTS, PC TAIL
P/N: 580-PCG
MATING FACE
HEX NUT
P/N: 6291V4
KEY
KEY
2
KEY
PANEL-MOUNT HOUSING
P/N: SEE CHART
KEY
KEY
1
4
1
WIRING END
GASKET
P/N: 6293 B
6
1
5
PART
NUMBER:
W7281-XSG-P-3ES
.800 REF
ACROSS
FLATS
B
A
3
2
W7281-2SG-P-3ES
WIRING END
W7281-3SG-P-3ES
WIRING END
W7281-4SG-P-3ES
WIRING END
W7281-5SG-P-3ES
GASKET P/N WAS 6293SP PER ECR 9512
01-17-20
RELEASED PER PDR 16014
PNK
01-08-18
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
3
WIRING END
04-01-20
MA
REV. INIT.
2
4
MA
WIRING END
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
W7281-6SG-P-3ES
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DRAWING CREATED PER PDR16014
DESCRIPTION
ORIG. DRAWN BY:
DATE:
01-08-18
PNK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
W7281-XSG-P-3ES
SHEET
1 OF 1
DIRECTORY:
SLW
PANEL MOUNT ASSEMBLY
(2-6) #20 SOCKET CONTACTS, PC, EPOXY
INSTA-CLICK™ MINI-CON-X
CUSTOMER: STANDARD PRODUCT
PART
NUMBER:
W7281-XSG-P-3ES
REV
B
很抱歉,暂时无法提供与“W7281-6SG-P-3ES”相匹配的价格&库存,您可以联系我们找货
