Technical Data 10115
Effective September 2016
Supersedes April 2016
BUSSMANN
SERIES
Bussmann series
22 x 58 mm Modular fuse holders
Product description
Eaton’s Bussmann series 22 x 58 mm modular
fuse holders are suitable for use with standard
cylindrical fuse links and FW type ferrule fuse
links.
Their compact dimensions helps reduce space,
allows for higher cable bending radius. Low
watts loss and wide range of accessories
make them ideally suited for most industrial
applications.
Standard features
Compact dimensions
Ventilation zones optimised for a better heat
dissipation
Inbuilt padlocking facility
IP20 degree of protection (see page 2)
Flexiblity to mount on DIN Rail and/or screw
mounting
Toolless DIN-Rail mounting, improves ease
of use and reduces installation time and
costs
Bussmann series
Catalogue Symbol
Standards/Approvals
CH221DNXU: neutral fuse holder
IEC 60269-1 and 60269-2
CH22(# of poles)DU: standard fuse holder
UL listed file number E14853
CCC
CH22(# of poles)DIU: fuse holder with neon indicator
CH221(# of poles)DNU: standard fuse holder and neutral
CH221(# of poles)DNIU: standard fuse holder and neutral and
neon indicator
Packaging
CH221(# of poles)DMSU-F: fuse holder with microswitch
(pre-breaking/fuse operation)
1-pole: 6 per pack
2-pole: 3 per pack
3-pole: 2 per pack
4-pole: 1 per pack
CH221(# of poles)DNMSU-F: fuse holder with neutral and
microswitch (pre-breaking/fuse operation)
CH221DI-48U: fuse holder with LED indicator
Table 2. Technical Data
Compatible fuse links
C22G and C22M: 22 x 58 mm gG and gM fuse links
FWP-A22F, see maximum continuous fuse current below
Table 1. FWP Ferrule fuse links
Catalogue
number
Maximum continuous
fuse current
FWP-20A22F
20 A
FWP-25A22F
25 A
FWP-32A22F
32 A
FWP-40A22F
38 A
FWP-50A22F
44 A
FWP-63A22F
55 A
FWP-80A22F
73 A
FWP-100A22F
86 A
Technical data
Number of poles: 1 to 4
Rated voltage
IEC: CH22DU Series 690 V a.c. / 1000 V d.c.
UL: 700 V a.c.
Rated current
IEC: CH22DU Series 125 A (a.c. and d.c.)
UL: 100 A (a.c.)
SCCR: 120 kA (a.c.) / 50 kA (d.c.)
Microswitch (IEC): 250 V a.c. / 5 A
Rated power acceptance: 9.5 W to IEC 60269-2
Protection index: IP20 Finger-safe
Rated impulse withstand voltage (Uimp): 6 kV
Cable size (Copper only): 2.5 mm2 - 70 mm2
Torque settings:
Recommended torque setting 4 N•m
Maximum torque setting: 5 N•m
Old part
number
CH221BNX
CH221B
CH222B
CH223B
CH224B
N/A
CH222DIU
2
N/A
CH223DIU
3
N/A
CH224DIU
4
CH221BN
CH223BN
CH221DNU
CH223DNU
2
4
1-pole + neutral fuse holder
3-pole + neutral fuse holder
Fuse holder and neutral and neon indicator
N/A
CH221DNIU
2
N/A
CH223DNIU
4
1-pole + neutral fuse holder + neon
indicator
3-pole + neutral fuse holder + neon
indicator
Fuse holder with microswitch
CH221BMS
CH221DMSU-F
1
CH223BMS
CH223DMSU-F
3
1-pole fuse holder with microswitch
3-pole fuse holder with microswitch
Fuse holder with neutral and microswitch
CH223BNMS
CH223DNMSU-F 3
3-pole cylindrical fuse holder +
neutral + microswitch (pre-breaking/
fuse operation)
Fuse holder with LED Indicator
N/A
CH221DI-48U
1
1-pole fuse holder with LED
Indicator
Table 3. Accessories
Part
number
Description
Unit
packing
Multi-pole connector kit. One kit will gang up to 4-poles
together
IP20 protection accessory, provides IP20 protection to
terminals with 10mm2 or less cable
Microswitch to work on CH221D(I)U, 1 n/o + 1 n/c
changeover type
Microswitch to work on CH223D(I)U, 1 n/o + 1 n/c
changeover type
12
CH22-CTP
EATON www.eaton.com
1-pole fuse holder with neon indicator
2-pole fuse holder with neon indicator
3-pole fuse holder with neon indicator
4-pole fuse holder with neon indicator
Storage & operating temperature range
2
1-pole fuse holder
2-pole fuse holder
3-pole fuse holder
4-pole fuse holder
1
RoHS compliant.
1
2
3
4
CH221DU
CH222DU
CH223DU
CH224DU
CH221DIU
Self-extinguishable UL 94-V0 rated polyester material
Operating temperature -20ºC to +70ºC
Neutral holder
N/A
1
Fuse holder with neon indicator
JV-L
CH221DNXU
Fuse holder only
Mounting: 35mm DIN-Rail or 2 x M4 Panel mounting screws
Storage temperature -40ºC to +80ºC
Number
of poles Description
Neutral only
New part
number
CH22-SPS
CH22-TPS
12
3
3
Bussmann series
Dimensional data - mm
Changes to the products, to the information
contained in this document, and to prices
are reserved; so are errors and omissions.
Only order confirmations and technical
documentation by Eaton is binding. Photos
and pictures also do not warrant a specific
layout or functionality. Their use in whatever
form is subject to prior approval by Eaton.
The same applies to Trademarks (especially
Eaton, Moeller, and Cutler-Hammer). The
Terms and Conditions of Eaton apply, as
referenced on Eaton Internet pages and
Eaton order confirmations.
Eaton
EMEA Headquarters
Route de la Longeraie 7
1110 Morges, Switzerland
Eaton.eu
© 2016 Eaton
All Rights Reserved
Publication No. 10115
September 2016
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“CH221BNX”相匹配的价格&库存,您可以联系我们找货
