STE115A12-Z
STE115A12-Z
    NIDEC(尼得科)
    SWITCH TOGGLE SPST 15A 125V
STE115A12-Z 数据手册
STE Dust Proof Miniature Power Switch RoHS Compliant UL CSA PSE ■    ■Features 1. Miniature toggle switch with small footprint. 2. Reinforced insulation by adopting resin frame and lever. 3. High inrush current rated (90A). 4. UL recognized. CSA PSE Dielectric strength 2,000VAC 1 minute Insulation resistance 100MΩ min. Rating UL・CSA Electrical life 50,000 cycles Operating temperature range Storage temperature range −15∼+70℃ (1A 2∼4VDC) (500VDC) −20∼+70℃ ■ Terminal Styles ■Part Numbering STE 1 15 A 10 − Z Series code Inrush Current (p.f.=0.6) Initial contact resistance 15A AC125V 8A AC250V 15A AC125V 8A AC250V 90A AC125V 48A AC250V 30mΩ max. Current Switching function Type STE115A10−Z Screw Terminal STE115A12−Z Solder Terminal Terminal style Dimensions Number of poles A ON ー OFF Screw Terminal 10 (M3.5×0.6) D ON ー ON 12 Solder Terminal Plating ■Tightning Torque for Hex Nut :78.4 N・cm Max. Brass Brass − Silver plated ■Panel Cut-Out Dimensions Panel thickness : 4 mm max. ■Soldering  Manual soldering Device : Solder iron 420℃ Max. 3 sec. Max. With Locking Ring Without Locking Ring ■Electrical Appliance and Material Safety Law Listed Products For appliances For electronic appliances Circuit Part No. AC125V AC250V AC125V SPST STE115A10−Z 15A 8A − − SPDT STE115D10−Z 15A 8A − − For general appliances For motors AC125V STE SPST STE115A10 Key way Switching function Terminal numbers are shown on the bottom of the switch. Key way Part No. ★STE115A10−Z ON OFF Connecting terminals 1−3 − (Screw Terminal) SPST STE115A12 Key way Switching function Terminal numbers are shown on the bottom of the switch. Key way Part No. ☆STE115A12−Z ON OFF Connecting terminals 1−3 − (Solder Terminal) SPDT STE115D10 Key way Switching function Terminal numbers are shown on the bottom of the switch. Key way Part No. ★STE115D10−Z ON OFF Connecting terminals 2−3 2−1 ■ Standard Accessories Combination (Q'ty/switch) Accessories ① ② ③ ④ ⑤  STE115A10−Z 1 1 0 2 2  STE115A12−Z 1 1 0 0 0  STE115D10−Z 1 1 3 3 3 Part No. (Screw Terminal) The number of accessories enclosed with the switch is shown in the above table. ■Accessories 《Supplied separately》 Standard Accessories For mounting Part Name Part No. ① ② For terminals Lockwasher ③ Spacer 140008010235 140008030055 − Nickel plated Zinc plated Nickel plated Hex Nut Optional Accessories ④ For mounting ⑤ Lockwasher Locking Ring 140000080127 140008030057 140008020065 Nickel plated Zinc plated Zinc plated Screw Dimensions Finish :Electrical Appliance and Material Safety Law. See page 432. :Optional Accessories. ☆:Semi-standard products. ★:Made to order products.
STE115A12-Z 价格&库存
很抱歉,暂时无法提供与“STE115A12-Z”相匹配的价格&库存,您可以联系我们找货
