CC9007
CC9007
    QUANTICCROVEN
    晶体
CC9007 数据手册
Quartz Crystal Specification Frequency 100.000000 MHz Cut SC-cut Vibration Mode 5th overtone Holder SM1 Calibration Tolerance ± 5 ppm at 87 °C Load Capacitance Series Frequency-Temperature Stability LTP from 80 to 95 ºC Motional Resistance Rs 100 ohms maximum Motional Capacitance C1 0.15 fF nominal Shunt Capacitance C0 3.0 to 4.5 pF nominal Quality Factor Q ≥ 100,000 G-sensitivity < ± 0.5 ppb/g per axis (not tested) Drive Level ≤ 100 uW Aging < ± 0.3 ppm/yr after 30 days Marking 1. Bar code label with Serial Number – standard electrical data to be provided Environmental Shock: MIL-STD-202G, M213 Condition C - 100 g, 6 msec, ½ sine Vibration: MIL-STD-202G, M204 Condition C, 10 g peak, 55 to 2000 Hz 1 sweep per axis Solderability, Seal and Workmanship per MIL-PRF-3098 RoHS Parts are RoHS compliant Revision Date APPROVALS DATE ENG SALES Description D. Scepanovic 03-May-2012 CAGE CODE SIZE C. Visniar 03-May-2012 00809 A Approved DWG. NO. CC9007 SHEET 1 0F 1 500 Beech Street, Whitby, Ontario, Canada, L1N 5S5 crovensales@crovencrystals.com REV -
CC9007 价格&库存
很抱歉,暂时无法提供与“CC9007”相匹配的价格&库存,您可以联系我们找货
