H12CD4850
H12CD4850
    SENSATA(森萨塔)
    Hockey Puck
    固态 SPST-NO(1 Form A) Hockey Puck
H12CD4850 数据手册
Panel Mount DataSheet H12C Series e • Ratings from 25A to 125A @ 48-660 VAC • SCR output for heavy industrial loads • AC or DC control • Zero-crossing (resistive loads) or random-fire (inductive loads) output Control Voltage 4-15 VDC 90-140 VDC AVAILABLE OPTIONS H12C 50 A H12CD4850 H12CD4890 H12CA4825 H12CA4850 H12CA4890 Load Current 25: 25 Amps 50: 50 Amps 90: 90 Amps Blank: No Internal Overvoltage Protection P: Internal Overvoltage Protection ol Series Control Voltage D: DC (4-15 V) A: AC (90-140 V) A U 48 25 U Operating Voltage 48: 48-660 VAC F 90 A 25 A H12CD4825 et PRODUCT SELECTION U P G Blank: Screw Terminals F: Faston Terminals Blank: No HeatTransfer Pad H: HeatTransfer Pad -10 H U Blank: No Input status LED G: Input status LED Required for valid part number Switching Mode Blank: Zero cross Turn-On -10: Random Turn-On OUTPUT SPECIFICATIONS(1) 25 A 50 A 90 A Operating Voltage (47-63Hz) [Vrms] Transient Overvoltage [Vpk] Maximum Off-State Leakage Current @ Rated Voltage [mArms] Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec] (2) Maximum Load Current (3) [Arms] Minimum Load Current [Arms] Maximum Surge Current (16.6ms) [Apk] Maximum On-State Voltage Drop @ Rated Current [Vpk] Thermal Resistance Junction to Case (Rjc) [°C/W] Maximum I2t for Fusing (8.3 msec) [A2 sec] Minimum Power Factor (with Maximum Load) 48-660 1200 1.0 500 25 150 250 1.6 1.02 260 0.5 48-660 1200 1.0 500 50 150 625 1.6 0.63 1620 0.5 48-660 1200 1.0 500 90 150 1200 1.6 0.28 6000 0.5 O bs Description Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. Panel Mount DataSheet INPUT SPECIFICATIONS (1) Description H12CD H12CA Control Voltage Range Maximum Turn-On Voltage Maximum Turn-Off Voltage Typical Input Current Nominal Input Impedance Maximum Turn-On Time [msec] (4) Maximum Turn-Off Time [msec] 4-15 VDC 4.0 VDC 1.0 VDC 15 mA 300 Ohm 1/2 Cycle 1/2 Cycle 90-140 Vrms 90 VDC 10.0 VDC 15 mA 8K Ohm 10 40 e GENERAL SPECIFICATIONS Description Parameters 4000 VRMS 109 Ohms 8 pF -40 to 80 °C -40 to 125 °C 3.0 oz (86.5g) Thermally conductive Epoxy Screws and Saddle Clamps Furnished, Unmounted 6-32 Screws - 10 in/lbs. 8-32 & 10-32 Screws - 20 in. lbs. (Screws dry without grease) Double pair* (50A model only) Caution: User must connect to both pairs et Dielectric Strength, Input/Output/Base (50/60Hz) Minimum Insulation Resistance (@ 500 VDC) Maximum Capacitance, Input/Output Ambient Operating Temperature Range Ambient Storage Temperature Range Weight (typical) Encapsulation Terminals Recommended Terminal Screw Torque Range: Fastons: GENERAL NOTES O bs ol (1) All parameters at 25°C unless otherwise specified. (2) Off-State dv/dt test method per EIA/NARM standard RS-443, paragraph 13.11.1 (3) Heat sinking required, for derating curves. (4) Turn-on time for DC random turn-on versions is 0.02 msec (DC Control Models). Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. Panel Mount DataSheet MECHANICAL SPECIFICATIONS 25 A 50 A 110 10 NO HEATSINK 5 120 5 10 15 20 25 20 .5˚C/W 90 40 60 80 Max Ambient Temp. [˚C] 1.5˚C/W 40 100 2˚C/W 110 20 NO HEATSINK 0 10 20 30 40 50 20 Load Current [Arms] bs Load Current [Arms] 1˚C/W 120 Power Dissipation 2˚C/W 15 90 A Base Plate Temp [˚C] 3˚C/W 60 ol 100 20 Power Dissipation 1˚C/W 25 0 95 Base Plate Temp [˚C] Power Dissipation 30 120 40 60 80 Max Ambient Temp. [˚C] 90 .5˚C/W .2˚C/W .4˚C/W 80 110 40 120 0 20 40 60 80 Load Current [Arms] 0 20 40 60 80 Max Ambient Temp. [˚C] AGENCY APPROVALS AGENCY APPROVALS O UL E116949 CSA LR81689 VDE 10143 UG Rev. 111710 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. 100 1˚C/W Base Plate Temp [˚C] THERMAL DERATE INFORMATION et e Tolerances: ±0.02 in / 0.5 mm All dimensions are in: inches [millimeters] Panel Mount DataSheet DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险 • Verificar todas las conexiones y colocar todas las tapas antes de energizer el equipo. El incumplimiento de estas instrucciones puede provocar la muerte o lesiones serias. • Eteindre toutes les sources d'énergie de cet appareil avant de travailler dessus de cet appareil GEFAHR EINES ELEKTRISCHE N SCHLAGES ODER EINER EXPLOSION. • Stellen Sie jeglichen Strom ab, der dieses Gerät versorgt, bevor Sie an dem Gerät Arbeiten durchführen RISCHIO DI SCOSSA ELETTRICA O DELL’ESPLOSIONE. • Spenga tutta l'alimentazione che fornisce questa apparecchiatura prima di lavorare a questa apparecchiatura 存在电击、 爆炸或电弧 闪烁危险 • 在操作此设 备之前请先 关闭电源。 • Vor dem Drehen auf Energie alle Anschlüsse überprüfen und alle Abdeckungen ersetzen. 若不遵守这些说明, 可能会导致严重的 人身伤害甚至死亡。 • Vérifier tous connections, et remettre tous couverts en olace avant de mettre sous • Verificare tutti i collegamenti e sostituire tutte le coperture prima dell’accensione De non-suivi de ces instructions provoquera la mort ou des lésions sérieuses sérieuses. Unterlassung dieser Anweisungen können zum Tode oder zu schweren Verletzungen führen. L'omissione di queste istruzioni provocherà la morte o lesioni serie ol Failure to follow these instructions will result in death or serious injury. • Desconectar todos los suministros de energia a este equipo antes de trabajar con este equipo. RISQUE DE DESCHARGE ELECTRIQUE OU EXPLOSION e • Verify all connections and replace all covers before turning on power. RIESGO DE DESCARGA ELECTRICA O EXPLOSION. et HAZARD OF ELECTRIC SHOCK, EXPLOSION, OR ARC FLASH. • Disconnect all power before installing or working with this equipment. bs WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告 RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE RISQUE DE DOMMAGE MATERIEL ET DE SURCHAUFFE DU BOITIER GEFAHR VON MATERIALSCHÄDEN UND GEHÄUSEERHITZUNG • The product's side panels may be hot, allow the product to cool before touching. • Follow proper mounting instructions including torque values. • Do not allow liquids or foreign objects to enter this product. • Les panneaux latéraux du produit peuvent être chauds. Laisser le produit refroidir avant de le toucher. • Respecter les consignes de montage, et notamment les couples de serrage. • Ne pas laisser pénétrer de liquide ni de corps étrangers à l'intérieur du produit. • Die Seitenwände können heiß sein. Lassen Sie das Produkt abkühlen, bevor Sie es berühren. • Beachten Sie die Montageanweisungen, • Führen Sie keine Flüssigkeiten oder Fremdkörper in das Produkt ein. Die Nichtbeachtung dieser Anweisung kann Körperverletzung oder Materialschäden zur Folge haben. RIESGO DE DAÑOS MATERIALES Y DE SOBRECALENTAMIENTO DE LA UNIDAD RISCHIO DI DANNI MATERIALI E D'INVOLUCRO CALDO 材料损坏和高温外壳的危险性 • Los paneles laterales del producto pueden estar calientes. Esperar que el producto se enfríe antes de tocarlo. • Respetar las instrucciones de montaje, y en particular los pares de apretado. • No dejar que penetren líquidos o cuerpos extraños en el producto. • I pannelli laterali dell'apparecchio possono scottare; lasciar quindi raffreddare il prodotto prima di toccarlo. • Seguire le istruzioni di montaggio corrette. • Non far entrare liquidi o oggetti estranei in questo apparecchio. Si no se respetan estas precauciones pueden producirse graves lesiones, daños materiales. La mancata osservanza di questa precauzione può causare gravi rischi per l'incolumità personale o danni alle apparecchiature. O Le non-respect de cette directive peut entraîner, Failure to follow these instructions can result in des lésions corporelles graves ou des serious injury, or equipment damage. dommages matériels. Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. • 产品的一侧面板可能很热,在其冷却前请 不要触碰。 • 遵照正确的安装说明,包括扭矩值。 • 请勿让液体及其他异物进入本产品。 如不能正确执行这些操作说明, 极有可能造成严重人体伤害或者设备的损坏。 Panel Mount DataSheet ANNEX - ENVIROMENTAL INFORMATION The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products. Toxic or hazardous Substance and Elements Lead (Pb) Mercury (Hg) Cadmium (Cd) Hexavalent Chromium (Cr (VI)) Semiconductor die Polybrominated diphenyl ethers (PBDE) et Solder Polybrominated biphenyls (PBB) e Part Name 附件 - 环保信息 部件 名称 铅 汞 镉 有毒有害物质或元素 六价铬 多溴联苯 (Pb) (Hg) (Cd) (Cr (VI)) bs 半导体芯片 焊接点 ol 此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006, 电子信息产品污染控制标识要求。 O 50 Do not forget to visit us at: www.crydom.com Copyright © 2017 Crydom Inc. Specifications subject to change without notice. (PBB) 多溴二苯醚 (PBDE)
H12CD4850 价格&库存
很抱歉,暂时无法提供与“H12CD4850”相匹配的价格&库存,您可以联系我们找货
