L6R36DM-240-C8
L6R36DM-240-C8
    TRI-MAG
    24V 36 W AC/DC 外部 台式(类 II) 适配器 缆线(单独出售) 输入
L6R36DM-240-C8 数据手册
GR EEN POW ER Medical Power Supplies L6R36DM Series 36W Medical Power Supply • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • ANSI/AAMI/IEC/EN ES60601-1:2012 Approved • Means of Protection: 2xMOPP • Corded Output Connection • IEC 60320 C6 / C14, C8 / C18 AC input connectors • Light Weight and Compact • 2-Year Warranty Output Current (A) Application Output Connector Output Voltage Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. Min Rated L6R36DM-050 Medical Corded Connector +5.0V 0 5.00 — ±5% < ± 2% ± 1% ± 5% L6R36DM-075 Medical Corded Connector +7.5V 0 4.00 — ±5% < ± 2% ± 1% ± 5% L6R36DM-090 Medical Corded Connector +9.0V 0 4.00 — ±5% < ± 2% ± 1% ± 5% L6R36DM-120 Medical Corded Connector +12.0V 0 3.00 — ±5% < ± 2% ± 1% ± 5% L6R36DM-150 Medical Corded Connector +15.0V 0 2.40 — ±5% < ± 2% ± 1% ± 5% L6R36DM-180 Medical Corded Connector +18.0V 0 2.00 — ±5% < ± 2% ± 1% ± 5% L6R36DM-240 Medical Corded Connector +24.0V 0 1.50 — ±5% < ± 2% ± 1% ± 5% Model No.1 1. Add “C6”, C8, “C14” or “”C18” for the required AC input connector configuration. • • • • • The output voltage is verified to specs at 60 percent rated load condition. The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load. The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load and nominal line. The efficiency is measured at rated load and nominal line. 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com Power Supplies L6R36DM Series Innovative, inexpensive and medical reliability. This to match your needs. Rated up to 36W when economical DOE Level VI compliant medical power powering either stationary or charging portable supply/charger is available in a variety of voltage devices for home healthcare and medical office/ levels, 5.0 to 24.0Vdc (per the model number table) hospital applications. Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Environmental • • • • • • • 90 Vac ~ 264 Vac, 100~240Vac Nominal 47 Hz to 63 Hz < 0.15W 1.0A @ 120Vac / 0.45A @ 230Vac 60A Max. / 230Vac < 100μA IEC 60320 C6, C8, C14 or C18 Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • Load Regulation Ripple & Noise Hold-up Time Overvoltage Protection Overload Protection Short Circuit Protection • • • • • • 5.0 to 24.0Vdc 5.00A to 1.50A No min. load required. ± 1% at rated load across input voltage range ± 5% (typical) 2% Vp-p Max. @ full load 10mS @ Full Load Auto recovery Auto recovery Auto recovery Output General Dielectric Withstand Efficiency MTBF • 4,000Vac Primary to Secondary • DoE Level VI, ErP Stage 2 compliant • 300,000 hrs. @ 25ºC per Telcordia SR-332 Operating Temperature Operating Humidity Storage Temperature Storage Humidity • • • • 0°C to 40°C 20 to 80% RH, Non-Condensing -20°C to +80°C 10 to 90%, Non-Condensing EMC & Safety Safety Approvals • ANSI/AAMI ES60601-1:2012, edition 3.1 IEC/EN ES60601-1:2012, edition 3.1 EMC Approvals • Radiated & Conducted Emissions: EN55011 CISPR 11, Class B Harmonic Current: EN61000-3-2, 3 EMC: IEC60601-1-2:2014, edition 4.0 Warranty Warranty Period • 2 years Dimensions and Notes Dimensions in mm Tolerance Size Weight Connectors Output Cord length • ± 0.2mm • L 100 x W 50 x H 33 mm L 3.94” x W 1.97” x H 1.30” • Approx. 210g [0.46 lb.] (ref.) • AC input: IEC 60320 C6, C8, C14 or C18 DC output: standard 5.5mm x 2.1mm corded dc output connector or per customer specification. • 1500 ±50 mm [59.1 ±2.0”] Mechanical Drawing 2017-08 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
L6R36DM-240-C8 价格&库存
很抱歉,暂时无法提供与“L6R36DM-240-C8”相匹配的价格&库存,您可以联系我们找货
