WB1-9-00-C4TRTRNN-0000-LR 数据手册
D6 Labs™
Engineered IoT Solutions
Whisker.Block®, HVAC Current/Dual Temp Probe
General Description
Internal Channels
Whisker.Blocks® are long-range, wireless sensors that come in a
variety of I/O and power configurations. These sensor blocks use our
proprietary long range wireless communication technology, ensuring
reliable and robust operation.
They can be configured for battery or external power. When
powered from internal batteries, the sensors can operate for 10 or
more years, depending on the sensors use and configuration.
Each sensor is housed in a durable, IP67 enclosure that supports a
variety of mounting methods. External sensors are connected via
one or two 4-pin M8 style waterproof connectors, depending on
how many external channels are configured.
The long range, exceptional battery life, and flexible I/O
configurations of the Whisker.Block® make it the perfect choice for
nearly any IoT application.
This Whisker.Block® is configured with two (2) internal channels:
Battery Voltage
Ambient Temperature
External Connections
This Whisker.Block® is configured with three (3) external channels:
Power
This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl
battery pack that should give 10+ years of service life before a
battery change is required, assuming a 5 minute update period.
Range
They come in a variety of configurations with multiple external
channels for various analog and digital inputs.In an unobstructed,
outdoor line-of-site environment, the sensor should be able to
communicate for more than 0.8 kilometers assuming a receiving
antenna elevation of 3.0 meters. If the receiving antenna is raised to
6.1 meters or more, the range should increase to more than 1.6
kilometers.
When used in environments where line of sight cannot be obtained
or where there are many reflective obstacles in the transmission
path, the range will degrade due to multi-path fading. It is
impossible to predict the transmission range of a Whisker.Block® in
any specific situation, so we do encourage users to take advantage
of our site survey tools to ensure coverage exists anywhere a sensor
is to be deployed. For more information on site survey techniques,
see application note .
www.d6labs.com
sales@d6labs.com
Con 2 (Left)
Connector
1
1
1
1
2
2
2
2
Pin
1
2
3
4
1
2
3
4
© Copyright 2019 All Right Reserved
Function
Vout
Channel 1
Channel 2
Ground
Vout
Channel 3
Not used
Ground
Con 1 (Right)
Description
Switched output voltage
C.T. Input
10K Thermister Input
Circuit ground
Not used
Circuit ground
Page 1
1-844-365-8647
Mechanical
Electrical Specifications
Parameter
Battery Life—Standard Pack
Operating Temp. Range
Transmission Range
Frequency Range
Internal Temperature Measurement Range
Internal Temperature Measurement Accuracy
Sensor Sample Rate
Analog input voltage range
Sensor Voltage supply
Sensor Supply Current
Current Input2
Thermal Resistance
Minimum
N/A
-40
Typical
10
0.8
902
-40
-1
Maximum
>8.1
928
+85
1
5
4
10K
Units
Years
Degrees Celsius
kilometers1
MHz
Degrees Celsius
Degrees Celsius
Minutes
mA
VDC
mA
Amps A.C.
ohms
1) Outdoors, line of sight, unobstructed, antenna elevation 3 meters
2) Using a C.T. with a 0-5V DC output scaled for 0-100Amps such as our CT-SCT010T-100A (Supplied with Block)
Order Information
Part Number
www.d6labs.com
sales@d6labs.com
Description
900MHz, battery powered, int. antenna, int. temperature, ext. 0-100A current trans. input qty. (1), 10K Thermister Input
qty. (2)
Page 2
1-844-365-8647
WB1-9-00-C4TRTRNN-0000-LR 价格&库存
很抱歉,暂时无法提供与“WB1-9-00-C4TRTRNN-0000-LR”相匹配的价格&库存,您可以联系我们找货
