WBP-DO-01-3F
WBP-DO-01-3F
    DIGITALSIXLABS
    RES DOOR SENSOR 3FT CABLE
WBP-DO-01-3F 数据手册
D6 Labs™ Engineered IoT Solutions WBP-DO-01-3F Door Sensor, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks™ are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. This door sensor can be connected to sensor blocks with a dry contact input. The sensor is a normally open switch that closes in the presence of a magnetic field. There are multiple compatible Whisker.Block™ products available that have a dry contact input. The part numbers of the compatible Whisker.Block™ products are show to the right. Refer to the Whisker.Block™ documentation for details on the various modes for reading the state of the sensor. Part Number WB1-9-00-DCNNNNNN-0000-LR WB1-9-00-DCTRNNNN-0000-LR WB1-9-00-DCTRTRNN-0000-LR WB1-9-00-DCA4NNNN-0000-LR WB1-9-00-DCA4A4NN-0000-LR WB1-9-00-DCA5NNNN-0000-LR WB1-9-00-DCA5A5NN-0000-LR Wiring Power This is a passive sensor that requires no external power. Mounting There are screw holes for mounting both the switch body and the associated magnet but they can also be mounted with double sided tape (not included). In a typical application the switch body is mounted to the door or window frame and the magnet is mounted on the door or window so that the magnet is closely aligned with the switch body when the door or window is closed. Recommended Wiring: Connector Pin Sensor Wire 1 2 or 3 Blue/Black 1 4 White www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Description Switch Pole Ground Reference Page 1 1-844-365-8647
WBP-DO-01-3F 价格&库存
很抱歉,暂时无法提供与“WBP-DO-01-3F”相匹配的价格&库存,您可以联系我们找货
