D6 Labs™
Engineered IoT Solutions
WSK-900-0004
HVAC System Monitoring Kit, Ethernet Interface
General Description
This kit contains a complete IoT sensor network. It is the ideal solution to remotely monitor an entire HVAC system. It features the Smart.Hub (Pro, Ethernet
version) with power supply and antennas for cloud connectivity and (3) Whisker.Block® sensor modules. The first Whisker.Block® is for measuring ambient
(room) temperature.
The second Whisker.Block® is configured for monitoring the compressor unit. It features:
• A current transformer input for a 25 amp current transformer.
• Dual external temperature Probes.
• An internal temperature sensor to measure the ambient temperature of the Whisker.Block® location.
The third Whisker.Block® is configured for monitoring the temperatures in air ducts. It consists of:
• Dual external temperature probes designed for duct mounting.
• A dry contact switch input.
This bundle contains the following components:
Quantity
1
Part Number
WH1-9-00-PDNEN-N
Description
Smart.Hub™ Pro, Ethernet Interface
Whisker.io™, Smart.Hub™, Pro, 900MHz, Ethernet, 120VAC
1
WB1-9-00-NNNNNNNN-0000-LR
Whisker.Block®, Internal Temp
900MHz, battery powered, int. antenna, int. temperature
1
WB1-9-00-C2TRTRNN-0000-LR
1
WB1-9-00-TRTRNNNN-0000-LR
Whisker.Block®, HVAC Current/Dual Temp Probe
900MHz, battery powered, int. antenna, int. temperature,
ext. 0-25A current trans. input qty. (1), 10K Thermister
Input qty. (2)
Whisker.Block®, Int. Temp & Dual 10KO Thermistor Input
ext. 10K thermistor qty. (2)
1
WBP_SC_0005_01
Sensor Cable / Current XFMR / Thermistor
1
WBP_SC_0005_02
Sensor Cable / Thermistor
1
WBP_SC_0005_03
Sensor Cable / 2 Duct Mount Thermistors
www.d6labs.com
sales@d6labs.com
© Copyright 2019 All Right Reserved
Page 1
1-844-365-8647
D6 Labs™
WH1-9-00-PDNEN-N
General Description
Throughput
The Smart.Hub™ Pro is a versatile and reliable IOT gateway device
for use in indoor applications. Smart.Hub™ products are gateways
used to move data from Whisker.Block® sensor blocks and end user
customized Whisker.Engine™ based sensor nodes to the
Whisker.io™ cloud platform.
The number of devices that can be supported by this hub varies with
the reporting rate of the connected devices. This is a single channel
hub, which ultimately determines its limitations; with a single
channel, this hub can process about 1,800 messages an hour. The
following table estimates device capacity for several different
update rates.
Features
Plug and play operation
Ethernet & Cellular options
Data buffering during loss of connectivity
Supports all Whisker.io Cloud services
Works with 3rd party platforms via Whisker.io Forwarding
Supports two-way communication with field devices – monitor
and control
• Communicate with field devices over distances more than 1.6
kilometers.
Robustness and Reliability
Update Rate
5 Minutes
1 Hour
4 Hours
24 Hours
This hub supports two-way communications with field devices that
support the Whisker.io™ protocol. For battery powered devices, the
hub will queue down-stream messages (commands) and send them
to the device when it reports in at its sampling interval; therefore,
the command latency is equivalent to the update rate of the device.
For line powered devices, commands are sent immediately, with a
latency of less than 1 second.
Whisker.io Services
If the hub loses connectivity to the Internet, it will buffer all
incoming messages from field devices to storage on the SD card.
When hub connectivity is restored, the messages will be sent to the
cloud for storage and forwarding. In the event of catastrophic
failure, the data on the SD card can be recovered using our Data
Recovery App (Windows).
Storage
Alerting
Dashboard
Forwarding
www.d6labs.com
sales@d6labs.com
Estimated number of devices
250
1500
5000
10000
Devices that are configured with the storage service
will persist their historic data in the Whisker.io cloud,
making it available for visualization and analysis using
our Whisker.io™ Portal web-based software.
Rules based alerting allows a text or email to be sent
when the specified condition is met and when it
clears.
Secure, user friendly dashboard with visualization
through gauges, graphs, sensor signal strength and
fuel gauges.
The forwarding service allows two-way
communications between Whisker.io devices and
third party platforms such as Amazon, ThingLogix, etc.
Page 2
1-844-365-8647
Mechanical
Connectivity Options
Every Whisker.io™ Hub can connect to the Internet via Ethernet. Hubs that are purchased with the Cellular option can also
connect via Cellular.
Installation and Setup
All Whisker.io™ hubs are truly plug-and-play, requiring no provisioning or setup in the field. Simply mount the hub, connect it to
power, and wait for all the status lights to come on.
Once a hub is installed, it is automatically configured to work with devices within its transmission range.
Order Information
Part Number
WH1-9-00-PDNEN-N
www.d6labs.com
sales@d6labs.com
Description
Page 3
1-844-365-8647
D6 Labs™
General Description
Internal Channels
Whisker.Blocks® are long-range, wireless sensors that come in a
variety of I/O and power configurations. These sensor blocks use our
proprietary long range wireless communication technology, ensuring
reliable and robust operation.
They can be configured for battery or external power. When
powered from internal batteries, the sensors can operate for 10 or
more years, depending on the sensors use and configuration.
Each sensor is housed in a durable, IP67 enclosure that supports a
variety of mounting methods. External sensors are connected via
one or two 4-pin M8 style waterproof connectors, depending on
how many external channels are configured.
The long range, exceptional battery life, and flexible I/O
configurations of the Whisker.Block® make it the perfect choice for
nearly any IoT application.
This Whisker.Block® is configured with two (2) internal channels:
Battery Voltage
Ambient Temperature
External Connections
This Whisker.Block® has no configured external channels
Power
This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl
battery pack that should give 10+ years of service life before a
battery change is required, assuming a 5 minute update period.
Con 2: Not used
Con 2: Not used
Range
They come in a variety of configurations with multiple external
channels for various analog and digital inputs.In an unobstructed,
outdoor line-of-site environment, the sensor should be able to
communicate for more than 0.8 kilometers assuming a receiving
antenna elevation of 3.0 meters. If the receiving antenna is raised to
6.1 meters or more, the range should increase to more than 1.6
kilometers.
When used in environments where line of sight cannot be obtained
or where there are many reflective obstacles in the transmission
path, the range will degrade due to multi-path fading. It is
impossible to predict the transmission range of a Whisker.Block® in
any specific situation, so we do encourage users to take advantage
of our site survey tools to ensure coverage exists anywhere a sensor
is to be deployed. For more information on site survey techniques,
see application note .
www.d6labs.com
sales@d6labs.com
Page 4
1-844-365-8647
Mechanical
Electrical Specifications
Parameter
Battery Life—Standard Pack
Operating Temp. Range
Transmission Range
Frequency Range
Internal Temperature Measurement Range
Internal Temperature Measurement Accuracy
Sensor Sample Rate
Minimum
N/A
-40
Typical
10
Maximum
0.8-1.6
902
-40
-1
928
+85
1
5
Units
Years
Degrees Celsius
kilometers1
MHz
Degrees Celsius
Degrees Celsius
Minutes
1) Typical range: Outdoors, line of sight, unobstructed, antenna elevation 3 meters. Max range: Outdoors, line of sight, unobstructed, antenna elevation 12 meters
Order Information
Part Number
www.d6labs.com
sales@d6labs.com
Description
Page 5
1-844-365-8647
D6 Labs™
General Description
Internal Channels
Battery Voltage
Ambient Temperature
This Whisker.Block® is configured with three (3) external channels:
Power
Range
kilometers.
www.d6labs.com
sales@d6labs.com
Con 2 (Left)
Connector
1
1
1
1
2
2
2
2
Pin
1
2
3
4
1
2
3
4
Function
Vout
Channel 1
Channel 2
Ground
Vout
Channel 3
Not used
Ground
Con 1 (Right)
Description
Switched output voltage
C.T. Input
10K Thermister Input
Circuit ground
Not used
Circuit ground
Page 6
1-844-365-8647
Mechanical
Parameter
Transmission Range
Frequency Range
Sensor Sample Rate
Analog input voltage range
Sensor Voltage supply
Sensor Supply Current
Current Input2
Thermal Resistance
Minimum
N/A
-40
Typical
10
0.8
902
-40
-1
Maximum
>8.1
928
+85
1
5
4
10K
Units
Years
Degrees Celsius
kilometers1
MHz
Degrees Celsius
Degrees Celsius
Minutes
mA
VDC
mA
Amps A.C.
ohms
1) Outdoors, line of sight, unobstructed, antenna elevation 3 meters
2) Using a C.T. with a 0-5V DC output scaled for 0-25Amps such as our CT-SCT010T-25A (Supplied with Block)
Order Information
Part Number
www.d6labs.com
sales@d6labs.com
Description
900MHz, battery powered, int. antenna, int. temperature, ext. 0-25A current trans. input qty. (1), 10K Thermister Input
qty. (2)
Page 7
1-844-365-8647
D6 Labs™
General Description
Internal Channels
Battery Voltage
Ambient Temperature
This Whisker.Block® is configured with two (2) external channels:
Power
Range
kilometers.
www.d6labs.com
sales@d6labs.com
Con 2: Not used
Connector
1
1
1
1
Pin
1
2
3
4
Function
Vout
Channel 1
Channel 2
Ground
Con 1 (Right)
Description
Circuit ground
Page 8
1-844-365-8647
Mechanical
Parameter
Transmission Range
Frequency Range
Sensor Sample Rate
Thermal Resistance2
Minimum
N/A
-40
Typical
10
0.8
902
-40
-1
Maximum
>8.1
928
+85
1
5
4
10K
Units
Years
Degrees Celsius
kilometers1
MHz
Degrees Celsius
Degrees Celsius
Minutes
mA
VDC
mA
ohms
2) This Whisker.Block® is configured for external 10K thermistor(s)
Order Information
Part Number
www.d6labs.com
sales@d6labs.com
Description
900MHz, battery powered, int. antenna, int. temperature, ext. 10K thermistor qty. (2)
Page 9
1-844-365-8647
D6 Labs™
WBP_SC_0005_01
General Description
This cable kit contains a base Sensor Attachment Cable that is connected to the sensor block. The below listed components are shipped attach to the listed
Sensor Attachment Cable as shown in the below diagram.
Quantity
1
Part Number
WBP-TR-01-3F
Description
8cm Thermistor Temperature Probe, 91cm Cable
1
WBP-CT2-01-3F
0-25A A.C. Current Transformer
1
CBL_M8MALE26AWG_3FT_01
Sensor Attachment Cable, 91cm Cable
Blue/No Marker = Channel 1, Yellow Marker = Channel 2
Wiring Diagram
www.d6labs.com
sales@d6labs.com
Page 10
1-844-365-8647
D6 Labs™
WBP-TR-01-3F
General Description
Compatible Whisker.Blocks®
reliable and robust operation. They come in a variety of
configurations with multiple external channels for various analog
and digital inputs.
This external sensor is designed to work with a Whisker.Block® that is
configured with an external thermistor (TR) input. When properly
mounted, this sensor can detect temperatures in the range of -40°C
to +85°C.
The thermistor is contained within a 8cm stainless steel housing that
can be used in air, food products, and most liquids. It is available
with a 15cm and 91cm cable.
We offer other temperatures probe configurations that can be used
in a variety of applications. The WBP-TR-02-xx is a 13cm version of
this probe, the WBP-TR-03-xx is designed to be mounted in HVAC
ducts, and finally the WBP-TR-04-xx is a lug mounted probe that can
be used on equipment such as motors.
Part Number
WB1-9-00-DCTRNNNN-0000-LR
WB1-9-00-DCTRTRNN-0000-LR
WB1-9-00-C1TRTRNN-0000-LR
WB1-9-00-C3TRTRNN-0000-LR
WB1-9-00-C4TRTRNN-0000-LR
Wiring
Power
Power for the sensor is provided by the Whisker.Block®.
Mounting
Recommended Wiring:
Connector Pin
Sensor Wire
1
1
Red
1
2 or 3 Blue/Black
Description
Sensor power supply
Thermister output
The sensor is housed in a 6.1mm round by 8cm long stainless steel
tube.
It should be mounted so that the bottom half the tube is fully
submerged in the medium you are monitoring.
Take care not to crimp or otherwise damage the stainless steel tube
as that might adversely affect proper operation or might shorten the
operating life of the sensor.
www.d6labs.com
sales@d6labs.com
Page 11
1-844-365-8647
D6 Labs™
WBP-CT2-01-3F
0-25A A.C. Current Transformer, 91cm Cable
General Description
and digital inputs.
This external current transformer is designed to work with a
Whisker.Block® that is configured with a 25 amp current Transformer
(C2) input with 0-5VDC output. When properly mounted, this sensor
will detect current from 0 to 25 amps A.C.
Part Number
WB1-9-00-C2NNNNNN-0000-LR
Wiring
Power
This is a passive sensor that requires no external power.
Mounting
Recommended Wiring:
This current transformer is connected to the D6 CBLM8MALE26AWG wire harness as shown in the wiring diagram. This
sensor is housed in a padlock type assembly that is clamped around
the AC power line that is to be monitored.
Connector Pin
1
2
1
4
Sensor Wire
Blue
White
Description
0-5V Analog In
Ground Reference
Parameter
Rated Input Current (Continuous)
Max Input(1 Min)
Rated Output
Output Ripple Voltage
Accuracy
Output Impedance
Isolation Impedance (500VDC)
Working Voltage
Working Temp
Storage Temp
Frequency Range
Dielectric Strength (50Hz, 1Min)
www.d6labs.com
sales@d6labs.com
Minimum
Typical
Maximum
25
37.5
5
5% output voltage
Units
Amps A.C.
Amps A.C.
VDC
±2%
7
100
-25°C
-30°C
50
660
+60°C
+90°C
60
3.5
k?
M?
Volts
Degrees Celsius
Degrees Celsius
Hz
KV
Page 12
1-844-365-8647
D6 Labs™
General Description
and digital inputs.
The Sensor Attachment Cable is installed on the Whisker.Block® to
provide a means to connect up to two (2) sensors to the
Whisker.Block® without having to wire the sensor(s) directly to the
Whisker.Block® circuit board connector.
Part Number
WB1-9-00-A5NNNNNN-0000-LR
WB1-9-00-C1NNNNNN-0000-LR
WB1-9-00-C3NNNNNN-0000-LR
WB1-9-00-C4NNNNNN-0000-LR
WB1-9-00-DCNNNNNN-0000-LR
WB1-9-00-TRNNNNNN-0000-LR
Mounting
The Sensor Attachment Cable comes attached to the Whisker.Block®.
In some cases, the sensors must be connected to the Sensor
Attachment Cable using the wiring configuration shown on the
sensor data sheet.
www.d6labs.com
sales@d6labs.com
Page 13
1-844-365-8647
D6 Labs™
WBP_SC_0005_02
General Description
Quantity
1
1
Part Number
WBP-TR-01-3F
Description
Wiring Diagram
www.d6labs.com
sales@d6labs.com
Page 11
1-844-365-8647
D6 Labs™
WBP_SC_0005_03
General Description
Quantity
1
1
Part Number
WBP-TR-03-3F
Description
Thermistor Temperature Probe, Duct Mount, 91cm Cable
Wiring Diagram
www.d6labs.com
sales@d6labs.com
Page 12
1-844-365-8647
D6 Labs™
WBP-TR-03-3F
General Description
and digital inputs.
to +85°C.
Part Number
Wiring
Power
Mounting
Recommended Wiring:
Connector Pin
Sensor Wire
1
1
Red
1
2 or 3 Blue/Black
Description
Sensor power supply
Thermister output
The sensor is housed in a 20cm long tube with a top mounted
flange. The flange has two 6.4mm holes for mounting to the duct.
It should be mounted so that the sensor is fully inserted into the
duct and is oriented so that the air will flow over the sensor as it
passes through the duct.
Take care not to crimp or otherwise damage the sensor as that
www.d6labs.com
sales@d6labs.com
Page 13
1-844-365-8647
