WSK-900-0006
WSK-900-0006
    DIGITALSIXLABS
    热传感器 套件 5 件(3 个值 - 混合数量)
WSK-900-0006 数据手册
D6 Labs™ Engineered IoT Solutions WSK-900-0006 Pharmacy Cold-Storage Mon. Kit, Ethernet Interface General Description This kit contains a complete IoT sensor network. It is the ideal solution to remotely monitor cold-storage equipment and refrigerated products in a pharmacy environment. It features the Smart.Hub (Pro, Ethernet version) with power supply and antennas for cloud connectivity and (2) Whisker.Block® sensor modules. The sensor blocks are for measuring the ambeint internal temperature of refrigerators or freezers. The external probe can be used to measure the temperature of a particular product inside a cold-storage environment. This bundle contains the following components: Quantity 1 Part Number WH1-9-00-PDNEN-N Description Smart.Hub™ Pro, Ethernet Interface Whisker.io™, Smart.Hub™, Pro, 900MHz, Ethernet, 120VAC 2 WB1-9-00-TRNNNNNN-0000-LR Whisker.Block®, Int. Temp & 10KO Thermistor Input 900MHz, battery powered, int. antenna, int. temperature, ext. 10K thermistor qty. (1) 2 WBP_SC_0005_02 Sensor Cable / Thermistor www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 1 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WH1-9-00-PDNEN-N Smart.Hub™ Pro, Ethernet Interface General Description Throughput The Smart.Hub™ Pro is a versatile and reliable IOT gateway device for use in indoor applications. Smart.Hub™ products are gateways used to move data from Whisker.Block® sensor blocks and end user customized Whisker.Engine™ based sensor nodes to the Whisker.io™ cloud platform. The number of devices that can be supported by this hub varies with the reporting rate of the connected devices. This is a single channel hub, which ultimately determines its limitations; with a single channel, this hub can process about 1,800 messages an hour. The following table estimates device capacity for several different update rates. Features • • • • • • Plug and play operation Ethernet & Cellular options Data buffering during loss of connectivity Supports all Whisker.io Cloud services Works with 3rd party platforms via Whisker.io Forwarding Supports two-way communication with field devices – monitor and control • Communicate with field devices over distances more than 1.6 kilometers. Robustness and Reliability Update Rate 5 Minutes 1 Hour 4 Hours 24 Hours This hub supports two-way communications with field devices that support the Whisker.io™ protocol. For battery powered devices, the hub will queue down-stream messages (commands) and send them to the device when it reports in at its sampling interval; therefore, the command latency is equivalent to the update rate of the device. For line powered devices, commands are sent immediately, with a latency of less than 1 second. Whisker.io Services If the hub loses connectivity to the Internet, it will buffer all incoming messages from field devices to storage on the SD card. When hub connectivity is restored, the messages will be sent to the cloud for storage and forwarding. In the event of catastrophic failure, the data on the SD card can be recovered using our Data Recovery App (Windows). Storage Alerting Dashboard Forwarding www.d6labs.com sales@d6labs.com Estimated number of devices 250 1500 5000 10000 © Copyright 2019 All Right Reserved Devices that are configured with the storage service will persist their historic data in the Whisker.io cloud, making it available for visualization and analysis using our Whisker.io™ Portal web-based software. Rules based alerting allows a text or email to be sent when the specified condition is met and when it clears. Secure, user friendly dashboard with visualization through gauges, graphs, sensor signal strength and fuel gauges. The forwarding service allows two-way communications between Whisker.io devices and third party platforms such as Amazon, ThingLogix, etc. Page 2 1-844-365-8647 Mechanical Connectivity Options Every Whisker.io™ Hub can connect to the Internet via Ethernet. Hubs that are purchased with the Cellular option can also connect via Cellular. Installation and Setup All Whisker.io™ hubs are truly plug-and-play, requiring no provisioning or setup in the field. Simply mount the hub, connect it to power, and wait for all the status lights to come on. Once a hub is installed, it is automatically configured to work with devices within its transmission range. Order Information Part Number WH1-9-00-PDNEN-N www.d6labs.com sales@d6labs.com Description Whisker.io™, Smart.Hub™, Pro, 900MHz, Ethernet, 120VAC © Copyright 2019 All Right Reserved Page 3 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WB1-9-00-TRNNNNNN-0000-LR Whisker.Block®, Int. Temp & 10KO Thermistor Input General Description Internal Channels Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They can be configured for battery or external power. When powered from internal batteries, the sensors can operate for 10 or more years, depending on the sensors use and configuration. Each sensor is housed in a durable, IP67 enclosure that supports a variety of mounting methods. External sensors are connected via one or two 4-pin M8 style waterproof connectors, depending on how many external channels are configured. The long range, exceptional battery life, and flexible I/O configurations of the Whisker.Block® make it the perfect choice for nearly any IoT application. This Whisker.Block® is configured with two (2) internal channels: Battery Voltage Ambient Temperature External Connections This Whisker.Block® is configured with one (1) external channels: Power This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl battery pack that should give 10+ years of service life before a battery change is required, assuming a 5 minute update period. Range They come in a variety of configurations with multiple external channels for various analog and digital inputs.In an unobstructed, outdoor line-of-site environment, the sensor should be able to communicate for more than 0.8 kilometers assuming a receiving antenna elevation of 3.0 meters. If the receiving antenna is raised to 6.1 meters or more, the range should increase to more than 1.6 kilometers. When used in environments where line of sight cannot be obtained or where there are many reflective obstacles in the transmission path, the range will degrade due to multi-path fading. It is impossible to predict the transmission range of a Whisker.Block® in any specific situation, so we do encourage users to take advantage of our site survey tools to ensure coverage exists anywhere a sensor is to be deployed. For more information on site survey techniques, see application note . www.d6labs.com sales@d6labs.com Con 2: Not used Connector 1 1 1 1 Pin 1 2 3 4 © Copyright 2019 All Right Reserved Function Vout Channel 1 Not used Ground Con 1 (Right) Description Switched output voltage 10K Thermister Input Not used Circuit ground Page 4 1-844-365-8647 Mechanical Electrical Specifications Parameter Battery Life—Standard Pack Operating Temp. Range Transmission Range Frequency Range Internal Temperature Measurement Range Internal Temperature Measurement Accuracy Sensor Sample Rate Analog input voltage range Sensor Voltage supply Sensor Supply Current Thermal Resistance2 Minimum N/A -40 Typical 10 0.8 902 -40 -1 Maximum 20 +85 >8.1 928 +85 1 5 4 20 4.096 20 10K Units Years Degrees Celsius kilometers1 MHz Degrees Celsius Degrees Celsius Minutes mA VDC mA ohms 1) Outdoors, line of sight, unobstructed, antenna elevation 3 meters 2) This Whisker.Block® is configured for external 10K thermistor(s) Order Information Part Number WB1-9-00-TRNNNNNN-0000-LR www.d6labs.com sales@d6labs.com Description 900MHz, battery powered, int. antenna, int. temperature, ext. 10K thermistor qty. (1) © Copyright 2019 All Right Reserved Page 5 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WBP_SC_0005_02 Sensor Cable / Thermistor General Description This cable kit contains a base Sensor Attachment Cable that is connected to the sensor block. The below listed components are shipped attach to the listed Sensor Attachment Cable as shown in the below diagram. This bundle contains the following components: Quantity 1 1 Part Number WBP-TR-01-3F Description 8cm Thermistor Temperature Probe, 91cm Cable CBL_M8MALE26AWG_3FT_01 Sensor Attachment Cable, 91cm Cable Blue/No Marker = Channel 1, Yellow Marker = Channel 2 Wiring Diagram www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 6 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WBP-TR-01-3F 8cm Thermistor Temperature Probe, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. This external sensor is designed to work with a Whisker.Block® that is configured with an external thermistor (TR) input. When properly mounted, this sensor can detect temperatures in the range of -40°C to +85°C. The thermistor is contained within a 8cm stainless steel housing that can be used in air, food products, and most liquids. It is available with a 15cm and 91cm cable. We offer other temperatures probe configurations that can be used in a variety of applications. The WBP-TR-02-xx is a 13cm version of this probe, the WBP-TR-03-xx is designed to be mounted in HVAC ducts, and finally the WBP-TR-04-xx is a lug mounted probe that can be used on equipment such as motors. Part Number WB1-9-00-DCTRNNNN-0000-LR WB1-9-00-DCTRTRNN-0000-LR WB1-9-00-C1TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-C3TRTRNN-0000-LR WB1-9-00-C4TRTRNN-0000-LR Wiring Power Power for the sensor is provided by the Whisker.Block®. Mounting Recommended Wiring: Connector Pin Sensor Wire 1 1 Red 1 2 or 3 Blue/Black Description Sensor power supply Thermister output The sensor is housed in a 6.1mm round by 8cm long stainless steel tube. It should be mounted so that the bottom half the tube is fully submerged in the medium you are monitoring. Take care not to crimp or otherwise damage the stainless steel tube as that might adversely affect proper operation or might shorten the operating life of the sensor. www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 7 1-844-365-8647 D6 Labs™ Engineered IoT Solutions CBL_M8MALE26AWG_3FT_01 Sensor Attachment Cable, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. The Sensor Attachment Cable is installed on the Whisker.Block® to provide a means to connect up to two (2) sensors to the Whisker.Block® without having to wire the sensor(s) directly to the Whisker.Block® circuit board connector. Part Number WB1-9-00-A5NNNNNN-0000-LR WB1-9-00-C1NNNNNN-0000-LR WB1-9-00-C2NNNNNN-0000-LR WB1-9-00-C3NNNNNN-0000-LR WB1-9-00-C4NNNNNN-0000-LR WB1-9-00-C1TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-C3TRTRNN-0000-LR WB1-9-00-C4TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-DCNNNNNN-0000-LR WB1-9-00-TRNNNNNN-0000-LR WB1-9-00-TRTRNNNN-0000-LR Mounting The Sensor Attachment Cable comes attached to the Whisker.Block®. In some cases, the sensors must be connected to the Sensor Attachment Cable using the wiring configuration shown on the sensor data sheet. www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 8 1-844-365-8647
WSK-900-0006 价格&库存
很抱歉,暂时无法提供与“WSK-900-0006”相匹配的价格&库存,您可以联系我们找货
