FG7-02.GB220.04
FG7-02.GB220.04
    DAVIESMOLDING
    抽屉型 手柄 铝 螺钉孔,背面
FG7-02.GB220.04 数据手册
Connection Typ FG7-02.L A FG Handle Series FG7 Material and surface: Handle ledge ø 30 x 5 mm aluminium round tube AlMgSi 0.5; fine ground and black anodized. Handle shanks of polyamide PA 6, black with fine structure. B Function elements: 2 Push buttons up to 1A with LED. Type FG7-05 with additional emergency stop (2 NC contacts). C Connection A: Coupling positioned at the tubular axle of the handle ledge in the handle shank. Connection B: Coupling positioned in the mounting surface of the handle shank. Typ FG7-05.G with emergency stop Connection C: The 5 m connection cable is guided out of the mounting surface of the handle shank. The connection A and C are available with straight and chamfer handle shanks, as left and right-hand versions for use with double doors. Protection class: IP 65 (for the connecting A and B with screwed coupling). Note: Coupling with 10 m ready made cable available as accessories. Other handle lengths, anodized versions and illuminated emergency stop button on request. Switching version Counter-handle without electrical function elements s. p. 41. www.daviesmolding.com with emergency stop, 2 push button Order no. Order no. straight FG7-02.GA220.04 FG7-05.GA220.04 left FG7-02.LA220.04 FG7-05.LA220.04 right FG7-02.RA220.04 FG7-05.RA220.04 straight FG7-02.GB220.04 FG7-05.GB220.04 straight FG7-02.GC220.04 FG7-05.GC220.04 left FG7-02.LC220.04 FG7-05.LC220.04 right FG7-02.RC220.04 FG7-05.RC220.04 8-pole (M12 x 1) 12-pole (M12 x 1) Bestell-Nr. Order no. Bestell-Nr. Order no. FZ-KS.G08.10 FZ-KS.G12.10 FZ-KS.W08.10 FZ-KS.W12.10 Connecting A B C U7-30.G without emergency stop, 2 push button L 10 m 19 13 Stecker / Plug M12 x 1 60 60 ø 30 x 5 9 M6 18,5 41,3 19 65,5 27,5 FG 27 44 220 283 40 30 31,3 25,5 232 Drucktaster LED rot Push button LED rot Drucktaster LED grün Push button LED green Not-Halt Emergency stop Technical data Typ FG7-02 FG7-05 with 2 push buttons add. emergency stop PK(5) BK(7) Emergency stop (2 NC contacts) without YE(6) GY(8) LED Push button LED red (1 change-over contact) PK(6) BN(2) WH(1) red GY(5) RD(8) BU(7) YE(4) GY(5) GN(3) LED Push button LED green (1NO contact) VT(10) BU(2) BN(1) RD(9) RD/BU(12) GY/PK(11) LED grün green green RD(9) GN(4) WH(3) 1-42 V AC/DC 100 mA - Emergency stop 24 V AC/DC max. 1 A Push buttons 24 V DC (12 V DC optional) Operating voltage LED 8-pole M12 x 1 Connection type 12-pole M12 x 1 BU (2) VT (10) BN (1) RD (9) WH (3) RD/BU (12) GY/PK (11) GY (8) GN (4) PK (5) YE (6) BK (7) RD (8) BN (2) Connector assignment (Plug side view) LED rot red WH (1) GN (3) BU (7) PK (6) YE (4) GY (5) ø 18 ø 6,5 Mounting cutout 18,5 All dimensions in mm. 220 Door solenoid tumbler see page 304–305. www.daviesmolding.com
FG7-02.GB220.04 价格&库存
很抱歉,暂时无法提供与“FG7-02.GB220.04”相匹配的价格&库存,您可以联系我们找货
