FireBeetle Covers‐24×8 LED Matrix (Red) SKU: DFR0488
Introduction
FireBeetle Covers-24×8 LED Matrix
DFRobot FireBeetle is a low-power consumption micro-controller intentionally designed for Internet
of Things (IoT). This series micro-controllers aims at IoT node of low-power consumption, attending
to build the IoT hardware platform quickly and conveniently. There are three types of FireBeetle,
containing Boards (main control), Covers (expansion boards) and related Accessories.
This 24×8 LED Matrix display is special designed for FireBeetle series. It supports low-power
consumption mode and scrolling display. With HT1632C high performance LED driver chip, every
led has independent register, which makes it easy to drive separately. It integrates a 256KHz RC
clock, only 5uA under low-power mode, support 16 scale PWM brightness adjustment. This product
also works with the other Arduino micrcontroller like Arduino UNO.
Specification
Operating Voltage: 3.3~5V
LED Color: Single color (White/Blue/Yellow/Red/Green)
Drive Chip: HT1632C
Working Current: 6~100mA
Low-power Consumption: 5uA
RC clock: 256KHz
Chip Select (CS): D2, D3, D4, D5 selectable
Serial Data Communication
Support Arduino Library
Support Scrolling display
Interface mode: FireBeetle Series Compatible
Operating Temperature: -10 ~+85
Dimension: 24 × 58(mm)/0.94 x 2.28(inches)
Weight: 26g
FireBeetle Covers-24×8 LED Matrix Chip Select
Note: FireBeetle Covers-24x8 LED Matrix has 4 CS pin, you can select the CS from the dialing
switch, and one FireBeetle can control 4 LED matrix at the same time.
Board Overview
Num Label
Description
1
DATA
DATAD6
2
WR
WRD7 (Generally Not Used)
3
CS
CSD2, D3, D4, D5 selectable
4
RD
RDD8
5
VCC
5VUSB; 3.7VLipo Battery
Tutorial
In this section,we will demonstrate several example about how to use this LED matrix.
Requirements
Hardware
FireBeetle Board - ESP32 x 1
FireBeetle Covers-24×8 LED Matrix x1
Software
Arduino IDE Click to Download Arduino IDE from Arduino®
https://www.arduino.cc/en/Main/Software%7C
Arduino Library (Github)
https://github.com/Chocho2017/FireBeetleLEDMatrix.git
Sample Code: Hello
Note: You need use D(x) to call digital I/O pins under Arduino IDE. Or that will be IO(x).
CS = D2
#include "DFRobot_HT1632C.h"
#define DATA D6
#define CS D2
#define WR D7
//#define RD 7
DFRobot_HT1632C ht1632c = DFRobot_HT1632C(DATA, WR,CS);
char str[] = "Hello";
void setup() {
// put your setup code here, to run once:
ht1632c.begin();
ht1632c.isLedOn(true);
ht1632c.clearScreen();
ht1632c.setCursor(0,0);
ht1632c.print(str);
void loop() {
// put your main code here, to run repeatedly:
Sample Code: Draw Point
You can draw points at any place of the Matrix. X-Y axis coordinate diagram:
FireBeetle Covers-24×8 LED Matrix X-Y Axis Coordinate Diagram
setPixel(x,y):Set coordinates
writeScreen():Draw points
Sample Code:
ht1632c.setPixel(0,0);
writeScreen();
Sample Code: Srolling Display
You can use ‘’‘setPixel’‘’ to set the start point, and print str with ms srolling display.
print(str,ms):
// str = string; ms = delay time
Smaple code:
#define DATA D6
#define CS D2
#define WR D7
char str[] = " DFROBOT 2017";
void setup() {
Serial.begin(115200);
ht1632c.begin();
delay(500);
void loop() {
ht1632c.print(str,50);
//delay(100);
Additional Instruction
FireBeetle Covers-24×8 LED Matrix support Low-power consumption mode, you can use
inLowpower function to enter Low-power consumption mode. When it is in Low-power consumption
mode, it will close RC clock automatically.
Dimension
FireBeetle Covers-24×8 LED Matrix Dimension
https://www.dfrobot.com/wiki/index.php/FireBeetle_Covers-24%C3%978_LED_Matrix_(Red)_SKU:_DFR0488 7-10-17
很抱歉,暂时无法提供与“DFR0488”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+305.09226
- 2+296.35036
- 5+193.19596
