Fermion: 2.0”” 320x240 IPS TFT LCD Display with MicroSD Card (Breakout)
SKU:DFR0664
INTRODUCTION
This 2.0” LCD display adopts ST7789V driver chip and has 320*240 color pixels (RGB565),
performing excellently in the angle of view (80/80/80/80). It supports SPI(4-wire)
communication mode and GDI port (work with main-controllers with GDI), plug, and play. The
module can be powered by 3.3V~5V, compatible with multiple main-controllers like Arduino
UNO, Leonardo, ESP32, ESP8266, FireBeetle M0, and so on. Use the GDI interface to work
with M0, which could effectively reduce wiring steps. Besides, there is an onboard MicroSD
card slot for displaying more pictures.
The module has the advantages of high resolution, wide viewing angle, and simple wiring,
and can be used in many display applications: waveform monitor display, electronic gift box,
electronic weather decorations, etc.
NOTE: MicroSD Card is not included.
FEATURES
Wide-angle of view
High resolution
GDI interface: plug and play
Onboard MicroSD card slot
APPLICATIONS
Waveform monitor display
Electronic gift box
Electronic weather decorations
Alarm clock display
SPECIFICATION
Operating Voltage: 3.3V-5.5V
Color Depth: 16-bit (RGB565)
Pixels: 240 x 320
Communication: SPI
Brightness(cd/m2): 250 (TYP) cd/m2
Full-screen Consumption: about 29mA (3.3V)/ 29mA (5V)(Typ)
Operating Temperature: -30℃~+70℃
Display Dimension: 1.20 x1.61inch / 30.6 x 40.8 mm
Module Dimension: 1.41x2.36inch / 35.70 x 60.00 mm
Mount Hole Diameter: 2mm
Weight: 26g
SHIPPING LIST
2.0" 320x240 IPS TFT LCD Display with MicroSD Card Breakout x1
2.54-10P Single Row Black Pin x1
FPC0.5-18PIN Flex Flat Cable Reverse Direction 10cm x1
https://www.dfrobot.com/product-2071.html 11-23-22
很抱歉,暂时无法提供与“DFR0664”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+166.74574
- 2+157.65444
- 3+153.52203
- 国内价格
- 1+373.82032
- 2+353.29015
- 3+341.31421
