DFR0338
DFR0338
    DFROBOT
    IO EXPANSION SHIELD FOR INTEL E
DFR0338 数据手册
    IO expansion board for Edison SKU: DFR338   Contents     1 Introduction 2 Application 3 Pinout Diagram 4 Tutorial 4.1 IO expansion board for Edison Quick Start 4.1.1 The Construction of the Hardware Environment  4.1.1.1 Hardware Connection Diagram 4.1.2 The Construction of the Software Environment  4.1.2.1 Software Environment  4.1.2.2 Operating System  4.1.2.3 Compile Environment Introduction IO expansion board for Edison is a multi-purpose, all-in-one development platform based on Intel Edison and Arduino SoC. IO expansion board for Edison is compatible with Arduino open source platform and Linux, and supports Java and C development environment. It can also be used as a standalone communication platform for software like flash, processing, Max/MSP and VVVV. Application      Digital I/O pins :D0-D13 PWM Output interface :4 (Digital pins D3, D5, D6 and D9) Support USB power and external power supply switch Support 1 x I2C interface Support Broadcom 43340 802.11 a/b/g/n dual band (2.4G and 5GHz) WiFi Support Bluetooth 4.0 Pinout Diagram Tutorial IO expansion board for Edison Quick Start The Construction of the Hardware Environment Part List:     IO expansion board x1 Edison module x1 micro USB x1 Computer x1 Hardware Connection Diagram Hardware Connection Diagram The Construction of the Software Environment Software Environment Operating System Windows 8.1 Compile Environment A.Edison Arduion IDE Download Edison Arduion IDE(winwos version) https://communities.intel.com/docs/DOC-23242 Extract to your local folder. NOTE: There is a bug with Edison Arduion IDE, you have to change your PC loca tion to U.S to avoid IDE FC. Control Panel-->Change data, time or number formats-->Format-->English(United States) Open Edison Arduion IDE B.Install Driver Download FTDI drivers http://www.ftdichip.com/Drivers/CDM/CDM%20v2.10.00%20WHQL%20Certified.exe Install CDM v2.10.00 WHQL Certified.exe Download Intel Edison Drivers https://communities.intel.com/docs/DOC-23242 https://www.dfrobot.com/wiki/index.php/File:DFR0331_Edison_driver.png Install Edion Driver Open the Device Manager, and check Device Driver C.Quick test with the module Open Edison Arduino IDE and open a sample code "Blink" Select Tools-->Board-->Intel Edison Select Tools-->Serial Port-->COM xx When the uploading has been finished, the LED will be flashing once a second. Powered By DFRobot © 2008-2017
DFR0338 价格&库存
很抱歉,暂时无法提供与“DFR0338”相匹配的价格&库存,您可以联系我们找货
