2x1.2A DC Motor Driver (TB6612FNG)
SKU: DRI0044
Introduction
This DFRobot micro dual way DC motor driver is design based on TB6612FNG motor driver IC. It
inherits DFRobot L298N motor control logic, which only need four pins to drive 2 motors. Compared
with the IC Breakout, it saves two precious GPIO resource, especially in Arduino UNO board.
TB6612FNG is a dual-channel full-bridge drive chip. The maximum continuous drive current of single
channel can reach 1.2A, peak value 2A/3.2A (continuous pulse / single pulse) , which can drive
some micro DC motors. The control logic is similar to L298n, and the code can be directly
compatible with the DFROBOT L298N motor driver. Standard XH2.54 pin can be inserted directly
into the breadboard. It is a good choice for DIY project or product developments.
Specification
VCC Operating Voltage: 2.7V~5.5V
VM Input Power: 2.5V~12V
Output Current: 1.2A (single-channel continuous drive current)
Start / Peak Current: 2A (continuous pulse) / 3.2A (single pulse)
Dimension: 0.79 x 0.77(in) / 20 x 19.50(mm)
Board Overview
Label Number
Description
1
DIR1
M1 Direction Control
2
PWM1
M1 Speed control(PWM)
3
PWM2
M2 Speed control(PWM)
4
DIR2
M2 Direction Control
5
GND
Negative power supply
6
VCC
Power 3.3V-5V or IO port output high
7
M1+
A Output 1
8
M1-
A Output 2
9
M2+
B Output 1
10
M2-
B Output 2
11
GND
12
VM(
很抱歉,暂时无法提供与“DRI0044”相匹配的价格&库存,您可以联系我们找货
