FIT0609
FIT0609
    DFROBOT
    SIX ARM SOLDERING STATION
FIT0609 数据手册
      Six Arm Soldering Station SKU:FIT0609 INTRODUCTION This is a third hand soldering station with six flexible helping arms and an aluminum alloy base, allowing you to finish all kinds of complicated welding work. Aluminum-made base and rubber pad of the product are able to keep the soldering station from sliding around on your bench, which greatly ensures stability. The six adjustable flexible arms can easily hold anything that is going to be soldered. We also set freely-rotating alligator clips on the top of the arms to convenient your operation. The grooves on the base can be used to place your screws and other material. A free USB fan is included in the package. SPECIFICATION  Universal Joint Pipe Length: 11 inches  Aluminum Alloy Base Dimension: 2.7”×4.5” SHIPPING LIST  Aluminum Alloy Base  Universal joint pipe  Non-Slip Rubber Pad  Alligator clip x6  USB Fan x1 x1 x6 x6   https://www.dfrobot.com/product‐1826.html/7‐12‐19
FIT0609 价格&库存
很抱歉,暂时无法提供与“FIT0609”相匹配的价格&库存,您可以联系我们找货
