MTO1804 Brushless DC Motor (CW)
SKU:FIT0633
INTRODUCTION
Designed for multi-rotor wings, this brushless DC motor is a boon for all drone enthusiasts. The
brushless DC motor has the following features: capable of outputting large torques at low
speeds and allowing full power operation at any speed. High efficiency and strong overload
capability, good regenerative-braking effect, small size, high power density and simple drive
control.
Dimension Figure
The motor adopts high-quality NSK bearings with strong durability which can achieve
more stable rotation, higher resistance to falls and super-low noise. The internal
oxygen-free winding copper set can withstand high temperature of up to 220℃. So,
there is no need to worry about burning the motor when turning at high speed. The
maximum hollow design not only makes the motor lighter but also improves thermal
performance. The unique assembly process can guarantee 100% dynamic balance
calibration, so that the flight is more stable. At the same time, we also equipped with a
positive and negative thread, which eliminates the safety hazard of multi-axis installed
anti-propeller rear-shooting paddle, and secures a safe flight.
This brushless DC motor is suitable for the intelligent robot, drone line and other
industries and professional aerial photography. It is ideal for a wide range of
enthusiasts.
NOTE: This motor needs to be used with the drive plate.
SPECIFICATION
Motor
KV value: 2480
Stator diameter: 18mm
Stator length: 4mm
Axis diameter: M5 (0.8mm)
Motor size(outside): Φ23×25.1mm (D * L) / Φ0.9×1.0inch
Weight: 16g
Power supply: 2-3 lithium batteries
Maximum continuous current: 5A
Maximum continuous power: 55.5W
Magnetic steel model: N40UH, ferrite boron magnetic steel
Bearing model: NSK
Silicon steel chip: 0.2mm cold-rolled low iron loss no orientation silicon steel
Dynamic balance: 100% dynamic balance calibration
Copper wire: oxygen-free copper, with 220 °C heat-resistant temp.
Drive board
Continuous current: 20A
Peak current: 25A
BEC: NO BEC
Input voltage: 2-4 lithium batteries
Weight: 7.5g
Dimension: 27*12mm / 1.06*0.47inch
SHIPPING LIST
Brushless DC Motor MTO1804 (CW) x1
https://www.dfrobot.com/product‐1960.html?search=FIT0633&description=true/2‐25‐20
很抱歉,暂时无法提供与“FIT0633”相匹配的价格&库存,您可以联系我们找货
