KIT0098
KIT0098
    DFROBOT
    ECELL: BREADBOARD-PLUGIN COMPONE
KIT0098 数据手册
    Breadboard Plugin Components Pack   SKU:KIT0098 Overview Breadboard-Plugin series is a new kit for breadboard experiment. It provides convenient, reliable and reusable components, plugins and modules. This innovative approach will solve the following issues when using a breadboard:  The problem by using DIP type of components Hard to read the value (Resistor color codes) Severe deformations of the pin after used, non-reusable, not environment-friendly The pin diameter is too thin or too thick, poor match with the breadboard hole Confused the order of transistor “e”, “b”, “c” pins  Usage problem: Most of sensors and actuators require 3 interfaces: Signal/VCC/GND, you have to use the jumper wire for the connection, messy and unreliable. Features       Easy to recognize : Resistance value, capacitance values, positive/negative polaron and pin functions are marked clearly. Easy to learn : The circuit symbol is clearly visible, directly match the circuit diagram Easy to use : Direct-plug pin Easy to Plug/unplug : The 0.64mm diametral pin matches the breadboard hole perfectly High-reliability : ENIG technology, the circuit connection is reliable and durable Environment-friendly : Reusable and Environment-friendly Breadboard-Plugin is designed by Maker LeoYan, produced and sold by DFRobot Specification Resistors Description Package: 1206 Resistance: 220R, 1K, 4.7K, 10K resistors Pins: 2 Lead Pitch: 4x2.54mm (400mil) Dimensions (without pins): 13.8 (w) x 11.4 (h) mm Capacitors Description Package: 1206 Capacitance: 22pF@50V,100nF(0.1uF)@50V,47uF@10V Capacitors Pins: 2 Lead Pitch: 4x2.54mm (400mil) Dimensions (without pins): 13.8(W) x 11.4(H) mm Leds Description Package: 1206 (PCB integrates current limiting resistance) Color: Red (R), Yellow (Y), Green (G), Blue (B) Pins: 2 Leds Lead Pitch: 4x2.54mm (400mil) Dimensions (without pins): 13.8(W) x 14.5(H) mm Diodes Description Type: SS14 (Schottky Barrier Rectifiers) Parameter: If=1A, Vfm=0.7V, Vr=40V Pins: 2 Diodes Lead Pitch: 4x2.54mm (400mil) Dimensions (without pins): 13.8(W) x 11.5(H) mm Transistor-NPN Description Type: BC817-25 Parameter: Vceo=45V, Ic=500mA, hFE=400 Pins: 3 Lead Pitch: 2x2.54mm (200mil) Transistor-NPN Dimensions (without pins): 13.8(W) x 11.7(H) mm Transistor-PNP Description Type: BC807-25 Parameter: Vceo=-45V, Ic=-500mA, hFE=400 Pins: 3 Lead Pitch: 2x2.54mm (200mil) Transistor-PNP Dimensions (without pins): 13.8(W) x 10.7(H) mm Breadboard Plugin Connector Description Support 4 x 3-Pin modules Dimensions: 15.2x16.2mm Breadboard Plugin Connector Instructions 1. Breadboard Plugin Connector  Circuit Schematic  Breadboard The kit supports following kinds of breadboard:   Breadboard 1: it is the default supported breadboard, can use it directly. Breadboard 2: If using this kind of bread board, resolder Pin at "M" and solder the Pin to “L” or “R”.  Usage tutorial 1. Recognize the front and back 2. Plug the back pins into Breadboard 3. Plug the Module on the breadboard plugin board. (Please notice the power polarities) For any question/ advice/ cool idea to share with us, please visit DFRobot Forum or Email to Techsupport Team . https://www.dfrobot.com/wiki/index.php/Breadboard_Plugin_Components_Pack_SKU:KIT0098 5-30-17
KIT0098 价格&库存
很抱歉,暂时无法提供与“KIT0098”相匹配的价格&库存,您可以联系我们找货
KIT0098
    • 1+319.87267
    库存:1
