M1 Dock AI Development Kit
SKU:KIT0144
INTRODUCTION
Artificial intelligence tide is sweeping across our world. All open sources developers and AI
geekers, good news, come to see this excellent M1 Dock AI development kit. With the
integrated Micropython in the module, you can start you AI development with ease!
The development kit adopts professional AI chip K210, a dual-core RISC-V with an FPU. It
serves as the core unit and dual-core processing with independent FPU, 64-bit CPU and 8M inbuilt SRAM. With a 400Mhz adjustable nominal frequency, it supports multiplication, division
and square root operation. In the AI processing, AI chip K210 can perform operations such as
convolution, batch normalization, activation and pooling. At the same time, the pre-processing of
voice direction scanning and voice data output can also be performed. This module can realize
face detection, voice, color and object recognition, MNIST handwritten digit recognition, feature
map visualization, tiny yolov2 and so on.
M1 Dock Embedded AI development platform is composed of M1 Dan Dock, OV2640 camera,
2.4 inches LCD with 320*240 resolution, and it also has built-in microphone, TF card slot and
on-board USB to serial chip for downloading and debugging codes. With so many powerful
functions, I am sure this product would be the best choice for all AI enthusiasts!
FEATURES
Digital Video Port (DVP) interface support
Universal Asynchronous Receiver/Transmitter(UART)
Direct Memory Access Controller (DMAC)
Joint Test Action Group(JTAG)
I2C, I2S, SPI interfaces
Field Programmable IO Array (FPIOA/IOMUX)
AES and SHA256 algorithm hardware accelerators
Fast Fourier Transform (FFT) hardware accelerator
Neural Network Processor (KPU)
Audio processor (APU)
SPECIFICATION
Machine Vision
Machine Hearing
Low power, better vision processing speed and accuracy
KPU high performance Convolutional Neural Network (CNN) hardware accelerator
Firmware encryption support
Unique programmable IO array maximises design flexibility
FPC24P socket for DVP camera and 8-bit MCU LCD
3.3V/1.8V dual voltage IO support eliminates need for level shifters
Access to all 72-pin full pin lead-out, freely mappable
USB Type-C interface
Power amplifier IC for use with speakers
Built-in microphone
TF card slot
On-board Wifi, adopt ESP8285 chip
Onboard high-speed DAC
Microphone Array expansion board for sound localization, beam forming, speech
recognition etc.
DOCUMENTS
• Product wiki
SHIPPING LIST
• M1 Dock AI Development Kit x1
https:// www.dfrobot.com/product-1888.html?search=KIT0144&description=true/9-11-19
很抱歉,暂时无法提供与“KIT0144”相匹配的价格&库存,您可以联系我们找货
