micro:IO Extender- a micro:bit IO
Expansion Board
SKU:MBT0008
INTRODUCTION
A simple IO extension board for micro:bit. This board leads out all IO ports of micro:bit that are
in accordance with Gravity standard interface. Meanwhile, it has independent I2C and Serial
port. The board also integrates the frequently-used buzzer and edge connector contacts.
The silkscreens on the back clearly indicate the functions of all interfaces, which can help users
to get started easily.
FEATURES
Gravity 3-Pin interface, plug and play, support DFRobot Gravity series
Lead out all micro:bit pins in the form of 3P pin header, 19 pins in total.
Independent I2C and 1-way serial port.
Onboard buzzer and buzzer switch
Onboard edge connector contacts
Clear silkscreen, ENIG technology and high quality
SPECIFICATION
Operating Voltage: 3.3V
Dimension: 45.5*66.5mm/1.79*2.62”
Interface: IO port ×19
SHIPPING LIST
IO Extender for micro:bit (V1.0) x1
https://www.dfrobot.com/product‐1868.html?search=MBT0008/7‐11‐19
很抱歉,暂时无法提供与“MBT0008”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+47.09140
- 5+45.14401
- 10+43.27993
