SEN0153
SEN0153
    DFROBOT
    URM07 - UART LOW-POWER CONSUMPTI
SEN0153 数据手册
      URM07‐UART Ultrasonic Sensor SKU: SEN0153        Introduction An ultrasonic sensor measures distance by calculating the time difference between sending a signal and receiving an echo from an object. It uses echolocation to measure distances, just like a bat. The URM07 is an ultra low-power sensor. The effect range is up to 7.5m, and it has a wide range power supply of 3.0 - 5.5V. It is directly compatible with 3.3V or 5V devices such as Arduino, Raspberry Pi .etc. The average operating current is only 5mA and standby current is only 14uA. According to the principle of ultrasound sensors, the accuracy of the distance value will be affected by the air temperature and wind direction, so using a DFRobot URM07 built-in temperature sensor, you can read the ambient temperature, and automatically calculate temperature compensation. The sensor uses an integrated ultrasonic probe with a detection angle of approximately 60° in a compact and lightweight unit. The unit uses a 2.54mm pitch 4Pin interface, using UART communication, compatible with most common microcontrollers. URM07 UART ultrasonic distance sensors have undertaken rigorous road testing and optimization. We guarantee that this sensor has first-class response speed, ultra high stability, the highest sensitivity and ultra low power consumption. If you have harsh environmental requirements for your sensor performance in your design, the URM07 is definitely the best choice. Features Dimension         Streamlined design High Stability High Sensitivity Built-in temperature compensation Low Power Consumption Reverse polarity protection (short-term protection) Overvoltage Protection Convenient connection and Usage Specification URM07 Detecting Angle                  Operating Voltage: 3.0 ~ 5.5V DC I/O Operating Mode: Open Drain (OD), integrated pull-up resistor Effective Range: 20 ~ 750 cm Direction Angle: 60 ° Standby Current:
SEN0153 价格&库存
很抱歉,暂时无法提供与“SEN0153”相匹配的价格&库存,您可以联系我们找货
