SEN0245
SEN0245
    DFROBOT
    光学传感器 1.18" ~ 78.74"(3 ~ 200cm) I²C 输出
SEN0245 数据手册
Gravity: VL53L0X ToF Laser Range Finder SKU:SEN0245 The VL53L0X range finder is a high-precision distance finder that based on new Time-of-Flight (ToF) principle. VL53L0X provides accurate distance measurement whatever the target reflectance unlike traditional technology. It can measure absolute distances up to 2m. DFRobot has introduced VL53L0X into Gravity Series. It provides Gravity-I2C interface, plug and play, supports 3.3V~5V power supply, and is compatible with more microcontrollers, and adapt to more application scenarios than others. The VL53L0X integrates a leading-edge SPAD array (Single Photon Avalanche Diodes) and embeds ST’s second generation FlightSenseTM patented technology. Its accuracy is ±3%, response time is less than 30ms, power consumption is only 20mW in normal operation mode, stand-by power consumption is 5uA. The VL53L0X's 940nm VCSEL emitter (vertical cavity surface emitting laser) is totally invisible to the human eye, coupled with internal physical infrared filters, it enables longer ranging distance, higher immunity to ambient light and better robustness to cover-glass optical cross-talk. Specification • • • • • • • • • • Power supply: 3.3-5V DC Operating Voltage: 2.8V Infrared emitter: 940nm Range: 30-2000mm FOV: 25° Ranging Accuracy: ±3% Sampling Time:
SEN0245 价格&库存
很抱歉,暂时无法提供与“SEN0245”相匹配的价格&库存,您可以联系我们找货
SEN0245
    • 1+270.53365
    库存:2
