IW1699-03
IW1699-03
    DIALOGSEMICONDUCTOR(戴乐格)
    OFF-LINE DIGITAL GREEN-MODE QUAS
IW1699-03 数据手册
iW1699 Off-Line Digital Green-Mode Quasi-Resonant PWM Controller 1 Description ES IG N S The iW1699 is a high performance AC/DC power supply controller that uses digital control technology to build peak current mode PWM flyback power supplies. The device operates in quasi-resonant mode to provide high efficiency and key built-in protection features while minimizing the external component count, simplifying EMI design and lowering the total bill of material cost. The iW1699 removes the need for a secondary feedback circuit while achieving excellent line and load regulation. It also eliminates the need for loop compensation components while maintaining stability over all operating conditions. Pulse-by-pulse waveform analysis allows for a loop response that is much faster than traditional solutions, resulting in improved dynamic load response for both one-time and repetitive load transients. The built-in power limit function enables optimized transformer design in universal off-line applications and allows for a wide input voltage range. EW D Dialog’s innovative proprietary technology ensures that power supplies built with the iW1699 can achieve both highest average active efficiency and less than 30mW no-load power consumption, and have fast dynamic load response in a compact form factor in typical 12W and above applications. The active start-up scheme enables shortest possible start-up time without sacrificing no-load power loss. N 2 Features EC 3 Applications O M M EN D ED FO R ●● No-load power consumption < 30mW at 230VAC along ●● Adaptive multi-mode PWM/PFM control improves with fast dynamic load response and short turn-on efficiency delay time in typical 12W compact adapter/charger ●● No external loop compensation components required applications ●● Complies with EPA 2.0 energy-efficiency specifications ●● Tight constant-voltage and constant-current regulation with ample margin across line and load range ●● Built-in single-point fault protection features: output ●● PrimAccurateTM primary-side feedback eliminates short-circuit protection, output over-voltage protection, opto-isolators and simplifies design over-current protection and current-sense-resistor fault ●● Proprietary optimized 89kHz maximum PWM switching protection frequency with quasi-resonant operation achieves best ●● Dedicated pins for external over-temperature size, efficiency and common mode noise protection and over-voltage protection, with latch ●● User-configurable 5-level cable drop compensation function available provides design flexibility ●● No audible noise over entire operating range ●● EZ-EMI® design enhances manufacturability R ●● Compact AC/DC adapters or chargers for media tablets and smart phones N O T ●● AC/DC adapters for consumer electronics Product Summary www.dialog-semiconductor.com Rev. 1.1 1 of 6 12-Mar-2018 © 2018 Dialog Semiconductor iW1699 Off-Line Digital Green-Mode Quasi-Resonant PWM Controller L VOUT + + RTN ES IG N S N VSENSE 2 SD 3 CFG OUTPUT 6 4 ASU ISENSE 5 + N EW GND 7 R CDC FO R NTC VCC 8 1 D U1 iW1699 D ED Figure 3.1 : iW1699 Typical Application Circuit (Achieving < 30mW No-load Power Consumption) EN L + M M + RTN N O T R EC O N VOUT NTC U1 iW1699 VCC 8 1 VSENSE 2 SD 3 CFG OUTPUT 6 4 ASU ISENSE 5 R CDC + GND 7 Figure 3.2 : iW1699 Typical Application Circuit (Alternative Circuit without Using Active Start-up Device) Product Summary www.dialog-semiconductor.com Rev. 1.1 2 of 6 12-Mar-2018 © 2018 Dialog Semiconductor iW1699 Off-Line Digital Green-Mode Quasi-Resonant PWM Controller 4 Pinout Description 8 2 SD GND 7 3 CFG OUTPUT 6 4 ASU ISENSE 5 N VCC IG VSENSE ES 1 S iW1699 EW D Figure 4.1 : 8-Pin SOIC-8 Package Pin Name Type Pin Description 1 VSENSE Analog Input Auxiliary voltage sense (used for primary regulation). 2 SD Analog Input External shutdown control. Used for external over-temperature protection (OTP) by connecting an NTC resistor from this pin to Ground. 3 CFG Analog Input Used for external cable drop compensation (CDC) configuration and supplemental over-voltage protection (OVP). 4 ASU Output Control signal for active start-up device (BJT or depletion mode NFET). 5 ISENSE Analog Input Primary current sense. Used for cycle-by-cycle peak current control and limit. 6 OUTPUT Output Gate drive for external MOSFET switch. 7 GND Ground Ground. 8 VCC EC O M M EN D ED FO R N Pin No. N O T R Power Input Power supply for control logic. Product Summary www.dialog-semiconductor.com Rev. 1.1 3 of 6 12-Mar-2018 © 2018 Dialog Semiconductor iW1699 Off-Line Digital Green-Mode Quasi-Resonant PWM Controller 5 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. Value Units DC supply voltage range (pin 8, ICC = 20mA max) VCC -0.3 to 18.0 V Continuous DC supply current at VCC pin (VCC = 15V) ICC 20 S Symbol N mA -0.3 to 18.0 V OUTPUT (pin 6) -0.3 to 18.0 V VSENSE input (pin 1, IVSENSE ≤ 10mA) -0.7 to 4.0 V -0.3 to 4.0 V D ASU output (pin 4) ES IG Parameter EW ISENSE input (pin 5) SD (pin 2) V -0.8 to 4.0 V 150 °C TJOPT -40 to 150 °C TSTG –65 to 150 °C θJA 160 °C/W ±2,000 V ±100 mA N CFG (pin 3, ICFG ≤ 20mA) -0.3 to 4.0 TJMAX R Maximum junction temperature FO Operating junction temperature Storage temperature ED Thermal resistance junction-to-ambient D ESD rating per JEDEC JESD22-A114 N O T R EC O M M EN Latch-up test per JESD78A Product Summary www.dialog-semiconductor.com Rev. 1.1 4 of 6 12-Mar-2018 © 2018 Dialog Semiconductor iW1699 Off-Line Digital Green-Mode Quasi-Resonant PWM Controller 6 Physical Dimensions H e A2 0.010 A2 0.049 0.059 1.25 1.50 B 0.014 0.019 0.35 0.49 C 0.007 0.010 0.19 0.25 D 0.189 0.197 4.80 5.00 E 0.150 0.157 3.80 4.00 e A SEATING PLANE L α C N MAX 0.10 1.75 0.050 BSC 0.25 1.27 BSC H 0.228 0.244 5.80 6.20 h 0.10 0.020 0.25 0.50 L 0.016 0.049 0.4 1.25 0° 8° α FO COPLANARITY 0.10 (0.004) B 0.0040 R A1 A1 EW h x 45° 1.35 IG 4 MIN 0.069 Millimeters ES 1 MAX 0.053 D 5 MIN A N E 8 Inches Symbol D S 8-Lead Small Outline (SOIC) Package Compliant to JEDEC Standard MS12F ED Controlling dimensions are in inches; millimeter dimensions are for reference only D This product is RoHS compliant and Halide free. EN Soldering Temperature Resistance: [a] Package is IPC/JEDEC Std 020D moisture sensitivity level 1 [b] Package exceeds JEDEC Std No. 22-A111 for solder immersion resistance; package can withstand 10 s immersion < 260˚C M M Dimension D does not include mold flash, protrusions or gate burrs. Mold flash, protrusions or gate burrs shall not exceed 0.15 mm per end. Dimension E1 does not include interlead flash or protrusion. Interlead flash or protrusion shall not exceed 0.25 mm per side. EC O The package top may be smaller than the package bottom. Dimensions D and E1 are determined at the outermost extremes of the plastic body exclusive of mold flash, tie bar burrs, gate burrs and interlead flash, but including any mismatch between the top and bottom of the plastic body. Options Package Description OVP/OTP latch, no CC operation SOIC-8 Tape & Reel1 iW1699-02 No OVP/OTP latch, 0.75V CC shutdown voltage SOIC-8 Tape & Reel1 iW1699-03 OVP/OTP latch, 0.75V CC shutdown voltage SOIC-8 Tape & Reel1 iW1699-05 No OVP/OTP latch, 2.9V CC shutdown voltage SOIC-8 Tape & Reel1 N O iW1699-01 T Part no. R 7 Ordering Information Note 1: Tape and reel packing quantity is 2,500/reel. Minimum ordering quantity is 2,500. Product Summary www.dialog-semiconductor.com Rev. 1.1 5 of 6 12-Mar-2018 © 2018 Dialog Semiconductor iW1699 Off-Line Digital Green-Mode Quasi-Resonant PWM Controller Disclaimer Information in this document is believed to be accurate and reliable. However, Dialog Semiconductor does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information. Dialog Semiconductor furthermore takes no responsibility whatsoever for the content in this document if provided by any information source outside of Dialog Semiconductor. N S Dialog Semiconductor reserves the right to change without notice the information published in this document, including without limitation the specification and the design of the related semiconductor products, software and applications. ES IG Applications, software, and semiconductor products described in this document are for illustrative purposes only. Dialog Semiconductor makes no representation or warranty that such applications, software and semiconductor products will be suitable for the specified use without further testing or modification. Unless otherwise agreed in writing, such testing or modification is the sole responsibility of the customer and Dialog Semiconductor excludes all liability in this respect. EW D Customer notes that nothing in this document may be construed as a license for customer to use the Dialog Semiconductor products, software and applications referred to in this document. Such license must be separately sought by customer with Dialog Semiconductor. All use of Dialog Semiconductor products, software and applications referred to in this document are subject to Dialog Semiconductor’s Standard Terms and Conditions of Sale, available on the company website (www.dialog-semiconductor.com) unless otherwise stated. R N Dialog and the Dialog logo are trademarks of Dialog Semiconductor plc or its subsidiaries. All other product or service names are the property of their respective owners. FO © 2018 Dialog Semiconductor. All rights reserved. RoHS Compliance O T R EC O M M EN D ED Dialog Semiconductor’s suppliers certify that its products are in compliance with the requirements of Directive 2011/65/EU of the European Parliament on the restriction of the use of certain hazardous substances in electrical and electronic equipment. RoHS certificates from our suppliers are available on request. N Contacting Dialog Semiconductor United Kingdom (Headquarters) Dialog Semiconductor (UK) LTD Phone: +44 1793 757700 North America Dialog Semiconductor Inc. Phone: +1 408 845 8500 Singapore Dialog Semiconductor Singapore Phone: +65 64 8499 29 China (Shenzhen) Dialog Semiconductor China Phone: +86 755 2981 3669 Germany Dialog Semiconductor GmbH Phone: +49 7021 805-0 Japan Dialog Semiconductor K. K. Phone: +81 3 5425 4567 Hong Kong Dialog Semiconductor Hong Kong Phone: +852 3769 5200 China (Shanghai) Dialog Semiconductor China Phone: +86 21 5424 9058 The Netherlands Dialog Semiconductor B.V. Phone: +31 73 640 8822 Taiwan Dialog Semiconductor Taiwan Phone: +886 281 786 222 Korea Dialog Semiconductor Korea Phone: +82 2 3469 8200 Email info_pcbg@diasemi.com Web site: www.dialog-semiconductor.com Product Summary www.dialog-semiconductor.com Rev. 1.1 6 of 6 12-Mar-2018 © 2018 Dialog Semiconductor
IW1699-03 价格&库存
很抱歉,暂时无法提供与“IW1699-03”相匹配的价格&库存,您可以联系我们找货
