ZIGBEE SMART
ENERGY CERTIFIED
IP GATEWAY
CONNECTPORT X2E®
FOR SMART ENERGY
Gateway with the ZigBee Smart Energy Public Application Profile 1.1 provides low-cost,
interoperable IP-to-application connectivity for customer engagement
ConnectPort X2e is an enhanced Smart Energy gateway
optimized for large deployments of Smart Energy devices
in a Home Area Network (HAN) including utility meters,
thermostats and in-home displays.
The wireless gateway provides a low-cost connection between
Smart Energy devices and remote web applications or utilityhosted websites designed for consumer engagement and
demand response. By sharing the homeowner’s broadband
internet connection, the wireless gateway provides near realtime energy data access and control capabilities based on the
Smart Energy devices enabled in the customer’s home.
BENEFITS
The ConnectPort X2e for Smart Energy is available in two
configuration options. The Coordinator version is intended
for stand-alone Smart Energy networks that do not have
smart meters present. The Router version is configured to
connect and read the smart metering system which has been
installed at the site.
APPLICATION EXAMPLE
– Full certification to ZigBee Alliance Smart Energy Public
Application Profile 1.1 and backwards compatible to 1.0
– Ethernet, Wi-Fi and cellular options for flexible
broadband connectivity
– Uses Digi Device CloudSM to manage connectivity,
configuration and software upgrades as well as
application integration via published APIs
– Supports both stand-alone Smart Energy networks
and Smart Energy metering systems
– Enables the Home Area Network (HAN) and Smart
Energy devices, such as Programmable Communicating
Thermostat (PCT) and In-Home Display products from
other manufacturers
DEVICE CLOUD
Ethernet
or Wi-Fi
UTILITY
COMPANY
SMART METER NETWORK
ZIGBEE SMART ENERGY NETWORK
IN RESIDENTIAL HOUSE
CONNECTPORT X2E®
FOR SMART ENERGY
SE Certified
Smart Meter
RELATED PRODUCTS
Modules
SE Range
Extenders
Smart Plug
Cellular Gateways
Digi Device
CloudSM
SE Certified
Thermostat
XBEE-PRO®
RANGE EXTENDER
SE Certified
In-Home Display
SPECIFICATIONS
ConnectPort X2e® for Smart Energy
ConnectPort X2e® Cellular for Smart Energy
GENERAL
MANAGEMENT
Secure enterprise management via Device Cloud
PROTOCOLS
UDP/TCP, DHCP
LEDS
Power, Network (LAN/WAN), ZigBee (HAN/PAN)
Power, Network (LAN/WAN), ZigBee (HAN/PAN),
Cellular signal strength
SECURITY
SSL tunnels
SSL tunnels, Cellular network security
ZIGBEE
XBee® ZB SMT transmit power 6.3 mW (+8 dBm); Receiver sensitivity (1% PER) -102 dBm
DIMENSIONS (L X W X H)
3 in x 3 in x 1 in (7.62 cm x 7.62 cm x 2.54 cm)
3 in x 4 in x 1 in (7.62 cm x 10.16 cm x 2.54 cm)
WEIGHT
0.15 lb (0.07 kg)
0.37 lb (0.082 kg)
DEVELOPMENT
ZIGBEE PUBLIC APPLICATION
PROFILE
Smart Energy 1.1 (Backwards compatible to 1.0)
PYTHON VERSION
2.7.1
PROCESSOR AND MEMORY
(VARIES BY FIRMWARE AND OS
VERSION)
Freescale i.MX28, 20 MB RAM, 10 MB file space
ETHERNET
PORTS
1 RJ-45 port
PHYSICAL LAYER
10/100Base-T
DATA RATE
10/100 Mbps (auto-sensing)
N/A
MODE
Full or half duplex (auto-sensing)
N/A
ROUTING
Ethernet port designed for WAN backhaul only
Ethernet port designed for configuration only
802.11
b/g/n
N/A
DATA RATE
Up to 72.2 Mbps
N/A
TRANSMIT POWER
18 dBm typical (varies by mode and channel)
N/A
RECEIVER SENSITIVITY
Up to -87 dBm @ 11 Mbps
N/A
MODES
AP Client Modes only; Access Point Mode not supported
N/A
WI-FI
POWER REQUIREMENTS
POWER SUPPLY
5 VDC power supply with barrel connector included
POWER CONSUMPTION
Typical: 1.2 W, Max: 2.5 W
Typical: 3.5 W, Max: 15 W
ENVIRONMENTAL
OPERATING TEMPERATURE
0° C to 40° C (32° F to 104° F)
RELATIVE HUMIDITY
5% to 95% (non-condensing)
ETHERNET ISOLATION
500 VAC min per IEEE802.3/ANSI X3.263
REGULATORY APPROVALS
MOBILE CERTIFICATIONS (GSM)
N/A
AT&T
MOBILE CERTIFICATIONS (CDMA)
N/A
Verizon / Sprint
SAFETY
EN60950
EMISSIONS/IMMUNITY
CE, FCC Part 15 (Class B), IC, ETSI
WWW.DIGI.COM
PART NUMBERS
DESCRIPTION
X2K-Z1C-W1-A
Digi Smart Energy Developer Kit
X2E-Z1C-E1-A
ConnectPort X2e, ZigBee SE Coordinator, Ethernet
X2E-Z1C-E1-W
ConnectPort X2e, ZigBee SE Coordinator, Ethernet (International)
X2E-Z1R-E1-A
ConnectPort X2e, ZigBee SE Router, Ethernet
X2E-Z1R-E1-W
ConnectPort X2e, ZigBee SE Router, Ethernet (International)
X2E-Z1C-W1-A
ConnectPort X2e ZigBee SE Coordinator, Ethernet and Wi-Fi
X2E-Z1C-W1-W
ConnectPort X2e ZigBee SE Coordinator, Ethernet and Wi-Fi (International)
X2E-Z1R-W1-A
ConnectPort X2e ZigBee SE Router, Ethernet and Wi-Fi
X2E-Z1R-W1-W
ConnectPort X2e ZigBee SE Router, Ethernet and Wi-Fi (International)
X2E-Z1C-H1-A
ConnectPort X2e ZigBee SE Coordinator 3G GSM
X2E-Z1R-H1-A
ConnectPort X2e ZigBee SE Router 3G GSM
X2E-Z1R-D2-A
ConnectPort X2e ZigBee SE Router CDMA EVDO (Verizon)
X2E-Z1C-D1-A
ConnectPort X2e SE Coordinator EVDO (Sprint)
X2E-Z1R-D1-A
ConnectPort X2e SE Router EVDO (Sprint)
X2E-Z1C-D2-A
ConnectPort X2e ZigBee SE Coordinator CDMA EVDO (Verizon)
FOR MORE INFORMATION
PLEASE VISIT WWW.DIGI.COM
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
© 1996-2016 Digi International Inc. All rights reserved.
All trademarks are the property of their respective owners.
91001721
B2/616
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL FRANCE
+33-1-55-61-98-98 / www.digi.fr
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
很抱歉,暂时无法提供与“X2E-Z1R-E1-W”相匹配的价格&库存,您可以联系我们找货
