EZ02-CA00-GLB
EZ02-CA00-GLB
    DIGIINTERNATIONAL
    以太网 适配器卡
EZ02-CA00-GLB 数据手册
Manage this device with Digi Remote Manager DIGI CONNECT EZ Click-to-connect | Modern, secure serial connectivity that boots in seconds, configures in minutes and runs for years Most companies are not replacing their equipment — they are updating the way they talk to it. Digi Connect® EZ modernizes operational infrastructure with expanded network connectivity and functionality for today’s applications. It is designed to meet the demands of a wide range of critical serial applications including connecting to automation, robotics control, centralized device management, data acquisition and point-of-sale equipment. Digi Connect EZ is a click-to-connect solution with 1, 2 or 4 serial ports, software-selectable for RS-232/422/485 communication, as well as optional LTE, Wi-Fi and industrial specifications (C1D2). It takes only a few minutes to configure with intelligent, use case-based options so that you can quickly install without having to modify your equipment or applications. FEATURES AND BENEFITS Digi simplifies key security requirements for critical infrastructure and distributed systems with enhanced access control, management and configuration capabilities. Digi Connect EZ and built-in Digi TrustFence® give your security and operations teams peace of mind against evolving security threats with encrypted connections, centralized authentication, VPN support and scalable security updates. Digi Connect EZ supports the widest range of industry standard and device-specific protocols using serial tunneling, TCP/UDP connections or Digi’s patented RealPort® COM port redirector for remote native COM port access. A built-in Python environment enables application development and customization at the device level, including event-based programmability, data conversion and full control of device connections. APPLICATION EXAMPLE – 1, 2 or 4 software-selectable RS-232/422/485 serial ports to connect a wide variety of serial equipment over IP networks DIGI REMOTE MANAGER® – 10/100/1000 Ethernet (dual Ethernet on 2- and 4-port), with optional Wi-Fi, industrial temp, C1D2 rating and LTE Server – Ideal for applications requiring COM ports, serial tunneling or TCP/UDP sockets – Optimizes performance for the widest range of industry standard and device-specific protocols LTE VPN IP Remote Site DIGI CONNECT® EZ – Built-in Digi TrustFence® for device security, secure encrypted connections, ongoing monitoring and support Wi-Fi – Easy setup and mass configuration with Digi Navigator™ and Digi Remote Manager® Display Kiosk Serial RELATED PRODUCTS Industrial Controller ConnectPort® TS ConnectPort® LTS RealPort® Digi Remote Manager® Industrial Controller Industrial Controller DIGI NAVIGATOR Digi Navigator gives users the ability to discover and configure Digi Connect EZ in minutes. The tool is what makes Digi Connect EZ easy. It allows you to spend your time where it matters most by taking away the hassle of finding devices on a network, configuring the IP address, defining serial ports and connected devices, setting up Digi RealPort and managing passwords. FEATURES – Find and connect to devices on a LAN – Guide IP address configuration – Configure Digi Connect EZ for use with Digi RealPort – Quickly define serial ports and devices associated with ports – Access the Digi Connect EZ web and command line interface – Manage passwords easily DIGI REALPORT Digi’s patented RealPort software provides serial connectivity over IP networks, no matter where the devices reside. The software is installed directly on the server and allows applications to talk to devices across a network as though the devices were directly attached to the server. In actuality, the devices are connected to a Digi device server or terminal server somewhere on the network. RealPort is unique among COM port re-directors. It is the only implementation that allows multiple connections to multiple ports over a single TCP/IP connection. Other implementations require a separate TCP/IP connection for each serial port, adding additional network traffic and congestion. RealPort also provides end-to-end encryption and full hardware flow control, as well as optimizations for packetization, latency and throughput. DIGI REALPORT® SOFTWARE Server Serial Device Data Ethernet Other COM port redirectors require a TCP/IP connection for each serial port, adding additional network traffic and congestion: Four times the overhead Four times the processing on host DIGI CONNECT® EZ Data 1 Data 4 Credit Card Reader Data 2 Receipt Printer Signature Capture Device Serial Data 3 Traffic from multiple serial devices share the same session Barcode Scanner DIGI REMOTE MANAGER CAPABILITIES – Activate, monitor and diagnose your mission-critical devices from a single point of command and control — on your desktop or mobile app – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access – Keep tabs on device health and connectivity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready DIGI.COM SPECIFICATIONS DIGI CONNECT EZ EZ Mini EZ 2 EZ 4 EZ 4i SOFTWARE AND MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager, SNMP v3 (user installed/ managed) 3 3 3 3 LOCAL MANAGEMENT Digi Navigator discovery and configuration tool, Web UI (HTTP/HTTPS), CLI (Telnet, SSH) 3 3 3 3 MANAGEMENT / TROUBLESHOOTING TOOLS Digi Navigator discovery and configuration tool, FTP client, SCP, protocol analyzer with PCAP for Wireshark, event logging with syslog and SMTP client, NTP/SNTP, Nagios, Intelliflow, iPerf, Dynamic DNS, ping, traceroute 3 3 3 3 MEMORY 256 MB RAM, 4 GB Flash SECURITY 3 3 3 3 RJ-45, 10/100/1000 Mbps (auto-sensing) 1-port 2-port 2-port 2-port PORTS RS-232 DTE/RS-422/RS-485 capable, software selectable (1) DB9 (2) RJ45-10 (4) RJ45-10 (4) RJ45-10 RS-232 / EIA-232 SERIAL MODES Signal support TXD, RXD, RTS, CTS, DTR, DSR, DCD, RI flow control options: XON/OFF, CTS/RTS, RTS-toggle 3 3 3 3 RS-422 / EIA 422 SERIAL MODES TX+/-, RX+/-, software termination, pre-delay/post-delay 3 3 3 3 RS-485 / EIA 485 SERIAL MODES Data+/Data-, software termination, pre-delay/post-delay 3 3 3 3 AUTHENTICATION TACACS+, LDAP, Enterprise RADIUS ETHERNET PORTS SERIAL CELLULAR CERTIFICATIONS LTE (G4) WITH DIGI CORE® PLUG-IN LTE MODEM 1002-CMG4 Visit www.digi.com/resources/certifications for latest certifications LTE Cat 4: B1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B38, B40, B41; 3G: B1, B2, B4, B5, B6, B8, B19 2G EDGE / GPRS: 850 / 900 / 1800 / 1900 MHz CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Secured in cellular module - When used with Digi CORE plug-in LTE modem WI-FI MODULE 1 x 1 SISO dual-band 802.11a/b/g/n/ac (2.4 GHz / 5 GHz) - - 3 3 MODES Client mode and access point mode simultaneously - - 3 3 CLIENTS Maximum 10 clients (access point mode: regardless of combination of clients and access points) - - 3 3 ACCESS POINTS Maximum 2 access points (access point mode: regardless of combination of clients and access points) - - 3 3 SECURITY WPA-3/WPA-2 personal, WPA/WPA-2 enterprise - - 3 3 CONNECTORS (1) 50 Ω SMA (center pin: male) - - 3 3 PHYSICAL DIMENSIONS (L x W x H) 13.7 x 9.5 x 3 cm (5.39 x 3.74 x 1.18 in) 19.2 x 13.4 x 3.5 cm (7.56 x 5.28 x 1.38 in) PACKAGE DIMENSIONS 21.4 x 18.4 x 6.5 cm (8.43 x 7.24 x 2.56 in) 35.5 x 20.4 x 6.7 cm (13.98 x 8.03 x 2.64 in) 0.6 kg (1.32 lb) 1.3 kg (2.87 lb) PACKAGE WEIGHT STATUS LEDs Each Ethernet and serial port has two status LEDs Power, serial Power, signal, LTE, Ethernet, serial Power, signal, LTE, Wi-Fi, Ethernet, serial DIGI.COM SPECIFICATIONS DIGI CONNECT EZ EZ Mini EZ 2 EZ 4 EZ 4i 3 3 3 - - - - 3 POWER REQUIREMENTS POWER INPUT Locking barrel: 9 - 30 VDC, locking 2.1 mm center barrel connector Phoenix connector: 9 - 30 VDC, Connector: 2-position rewireable plug with securing screws included 9 V @ 1 A max, typical 1.7 W POWER CONSUMPTION 9 V @ 1.5 A max, 5 W typical with Digi CORE modem, 4.5 W typical without Digi CORE modem ENVIRONMENTAL Standard operating temperature of Connect EZ device OPERATING TEMPERATURE With Digi CORE plug-in LTE modem RELATIVE HUMIDITY 5% to 95% (non-condensing) 0° to 40° C (32° to 104°F) 0° to 40° C (32° to 104°F) 0° to 40° C (32° to 104°F) -35° to 74° C (-31° to 165°F) - 0° to 40° C (32° to 104°F) 0° to 40° C (32° to 104°F) -35° to 70° C (-31° to 158°F) 3 3 3 3 3 3 3 3 - - - 3 APPROVALS CELLULAR Visit www.digi.com/resources/certifications for latest cellular certifications SAFETY IEC62368-1, CB, EN62311 INDUSTRIAL CERTIFICATION Class 1, Division 2 ENVIRONMENTAL ROH53 3 3 3 3 EMISSIONS / IMMUNITY CE; RED; FCC Part 15, Subpart B; ICES-003; AU/NZS CISPR32 3 3 3 3 WARRANTY PRODUCT WARRANTY 5-year for base Connect EZ device, 3-year for Digi CORE plug-in LTE modem ENTERPRISE SOFTWARE DESCRIPTION CONNECTIVITY CAPABILITIES NETWORK PROTOCOL SUPPORT HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH, remote management via Digi Remote Manager; Protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS,Dynamic DNS client compatible with BIND9/No-IP/DynDNS; Captive portal, Intelliflow; Nagios, DNS server, NTP server, Multicast, mDNS, IPerf SERIAL AND DATA PROTOCOL SUPPORT RealPort, Socket and Autoconnect Socket Connectivity for TCP and Encrypted TCP, SSH, Telnet, UDP, Modbus, Pyserial support via builtin Python interpreter SECURITY IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; TLS 1.2 and above, FIPS 197, open VPN client and server; VPN tunnels; Authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support VPN IPsec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; Cryptology: SHA-1/256/384/512, MDS, RSA; Encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: RIP (v1, v2) OSPF, BGP, IP failover: VRRP; automatic failover; Digi SureLink® OTHER PROTOCOLS DHCP; dynamic DNS client compatible with No-IP/DynDNS DIGI.COM PRODUCT IMAGES Digi Connect EZ 4 Digi Connect EZ 4 - front 134 mm 35 mm Digi Connect EZ 4i - front 192 mm Digi Connect EZ 4 / 4i - back Digi Connect EZ 2 Digi Connect EZ 2 - front 134 mm 35 mm Digi Connect EZ 2 - back 192 mm Digi Connect EZ Mini - front Digi Connect EZ Mini 137 mm Digi Connect EZ Mini - back 30 mm 95 mm DIGI.COM SPECIFICATIONS PART NUMBERS DIGI CONNECT EZ EZ01-MA00-GLB Digi Connect EZ Mini - serial server, 1-port, with accessories EZ02-CA00-GLB Digi Connect EZ 2 - serial server, 2-port with accessories EZ02-CAG4-GLB Digi Connect EZ 2 - serial server, 2-port, with LTE and accessories EZ04-WA00-GLB Digi Connect EZ 4 - serial server, 4-port, with Wi-Fi and accessories EZ04-WAG4-GLB Digi Connect EZ 4 - serial server, 4-port, with LTE, Wi-Fi and accessories EZ04-IA00-EXT Digi Connect EZ 4i - serial server, 4-port, industrial-rated, with Wi-Fi and accessories EZ04-IAG4-EXT Digi Connect EZ 4i - serial server, 4-port, industrial-rated, with LTE, Wi-Fi and accessories PART NUMBERS ACCESSORIES 1002-CMG4-GLB Digi CORE plug-in LTE modem - global LTE Cat 4, 3G/2G fallback 76000926 Antenna - 3G/4G, Multiband 699-2690 MHz, swivel 76002118 Antenna - dipole, 4G, magnetic mount, 1 meter cable 29000938 Antenna - whip 2.4 and 5 GHz dipole 5 dBi 24000136 Power Supply - 12 VDC 3 A wall plug, locking barrel, with tips for US, UK, EU and AU 76000823 Power supply - 12 VDC 1.5 A wall plug, locking barrel, with tips for US, UK, EU and AU 76002079 Power supply - 12 VDC 2.5 A wall plug, with tips for US, UK, EU and AU, extended temp 76002093 DIN rail mounting bracket 76002095 DIN rail clip, 44 mm wide, with screws PART NUMBERS SERIAL CABLES AND ADAPTERS CABLE ADAPTERS 76000697 DB-9F Console Adapter, quantity 4 76000698 DB-25M Console Adapter, quantity 4 76000699 DB-25F Console Adapter, quantity 4 76000700 DB-25M Modem Adapter, quantity 4 76000701 DB-9M Modem Adapter, quantity 4 CABLES 76000195 RJ-45 to DB-25 Male Straight, 4 feet 76000199 RJ-45 to DB-25 Female Straight, 4 feet 76000201 RJ-45 to DB-9 Female Straight, 4 feet 76000238 RJ-45 to DB-25 Male Crossover, 4 feet 76000240 RJ-45 to DB-9 Male Straight, 4 feet 76000264 RJ-45 to DB-9 Male Crossover, 4 feet 76000631 RJ-45 to RJ-45 for Sun Netra/Cisco, 6 feet 76000645 RJ-45 to DB-9 Female Crossover, 4 feet SPECIALTY CABLES 76000723 Connects screw terminal EIA 422/485 devices to Digi MEI products that have 10-pin RJ-45 connectors DIGI.COM DIGI CONNECT EZ - INCLUDED ACCESSORIES MATRIX Connect EZ Mini EZ01-MA00GLB LTE modem 1002-CMG4-GLB Antenna - 3G / 4G 76000926 Antenna - dipole, 4G Antenna - 2.4 and 5 GHz Power supply 12 V, 3 A Power supply 12 V, 1.5 A Power supply 12 V, 2.5 A Connect EZ 2 EZ02-CA00GLB Connect EZ 4 EZ02-CAG4GLB EZ04-WA00GLB Included EZ04-IA00EXT EZ04-IAG4EXT Included Included Included (2) Included (2) Included (2) 76002118 29000938 29000136 76000823 EZ04-WAG4GLB Connect EZ 4i Included Included Included Included Included Included Included Included Included Included Included 76002079 DIN rail bracket 76002093 Separate Separate Separate Separate Separate Separate Separate DIN rail clip 76002095 Included Included Included Included Included Included Included PART NUMBERS DIGI REMOTE MANAGER DIGI-RM-STD-1YR Digi Remote Manager Standard - 1-year subscription DIGI-RM-PRM-1YR Digi Remote Manager Premier - 1-year subscription DIGI-RM-PRM-3YR Digi Remote Manager Premier - 3-year subscription DIGI-RM-PRM-5YR Digi Remote Manager Premier - 5-year subscription FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2021 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004473 A13/721 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL GERMANY +49-89-540-428-0
EZ02-CA00-GLB 价格&库存
很抱歉,暂时无法提供与“EZ02-CA00-GLB”相匹配的价格&库存,您可以联系我们找货
