WR44-L900-AE1-RF
WR44-L900-AE1-RF
    DIGIINTERNATIONAL
    CELLULAR ROUTER GLOBAL HSPA 3G C
WR44-L900-AE1-RF 数据手册
ENTERPRISE-CLASS CELLULAR ROUTERS FOR RUGGED APPLICATIONS DIGI TRANSPORT® WR44 R All-in-one cellular router with advanced routing and VPN features, designed specifically for use in rugged environments The Digi TransPort WR44 R is a rugged, all-in-one 4G LTE Advanced mobile communications solution with true enterprise-class routing, security and firewall. Featuring a heavy-duty cast aluminum enclosure, it offers a flexible interface design with an optional integrated Wi-Fi access point (with multi SSID), USB, serial and 4-port Ethernet switch, as well as a variety of configuration options including GPS and CAN support. These routers are ideal for transportation and mobile applications. Flexible power options include 9-36 VDC locking barrel or automotive Molex connectors for direct integration into vehicle applications. Also ideal for mobile applications is the cellular to Wi-Fi autoswitch feature, which uses the highest speed/lowest cost WAN network available. All Digi TransPort products offer an advanced routing, security and firewall feature set including stateful inspection firewall and integrated VPN. Enterprise class protocols incorporate BGP, OSPF and VRRP+. Advanced features allow the Digi TransPort to be used as a component of a PCI compliant network. Digi Remote Manager® provides easy setup, configuration and maintenance of large installations of Digi TransPort and third-party devices. BENEFITS APPLICATION EXAMPLE – Rugged, enterprise-class cellular routers with advanced dynamic routing, security and firewall features – Heavy-duty cast aluminum enclosure for reliable performance in rugged environments – Integrated 802.11 ac/a/b/g/n; a/n Wi-Fi access point (optional) and 4-port Ethernet switch – Flexible interfaces including GPS and CAN with DC power options Encrypted WAN DIGI REMOTE MANAGER® TRANSIT HEADQUARTERS 3G/4G/LTE PUBLIC TRANSIT NETWORKING – Cellular to Wi-Fi autoswitch feature automatically uses the highest speed/lowest cost WAN network available – Digi Remote Manager® provides mass configuration, device management and troubleshooting tools DIGI TRANSPORT® WR44 R Surveillance Advertising Mobile Billboard RELATED PRODUCTS Serial Bus Schedule/ Advertising Digi TransPort® WR11 XT Digi TransPort® WR21 Digi TransPort® WR44 RR Accessories Digi Remote Manager ® Vehicle Bus and GPS Ethernet or Wi-Fi Connections Ticket/Payment Mobile Internet SPECIFICATIONS Digi TransPort® WR44 R WIRELESS INTERFACES CELLULAR* LTE - NORTH AMERICA/EMEA (M8) LTE Advanced CAT 6: 700(B12,B13,B29)/800(B20,B26)/850(B5)/900(B8)/AWS(B4)/1800(B3)/1900(B2,B25)/ 2100(B1)/2300(B30)/2500(B41)/2600(B7) 3G HSPA+: 850/900/AWS/1800/1900/2100 MHz Transfer rate (max): 300 Mbps down, 150 Mbps up Approvals: PTCRB, AT&T, Verizon, Vodafone (pending) LTE - ANZ/LATAM (L9) LTE-Advanced CAT 6: 700(B28)/850(B5,B18,B19)/900(B8)/1500(B21)/1800(B3)/1900(B39)/2100(B1)/ 2600(B7,B38)/2300(B40)/2500(B41) 3G HSPA+: 800/850/900/1700/2100 MHz Transfer rate (max): 300 Mbps down, 150 Mbps up LTE - EMEA/APAC (M2) LTE CAT 3: 450(B31)/800(B20)/1800(B3)/2600 (B7) HSPA+: 900/2100 MHz EDGE: 900/1800 MHz Transfer rate (max): 100 Mbps down, 50 Mbps up CONNECTOR (2) 50 Ω SMA (Center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY SIM slot cover plate WI-FI** STANDARD 802.11 ac/a/b/g/n 2.4/5 GHz MODES Access point, client and support for multiple SSID TRANSMIT POWER 20 dBm + 1.0/-1.5 dBm RECEIVE SENSITIVITY 54 Mbps /
WR44-L900-AE1-RF 价格&库存
很抱歉,暂时无法提供与“WR44-L900-AE1-RF”相匹配的价格&库存,您可以联系我们找货
