WR54-A246
WR54-A246
    DIGIINTERNATIONAL
    3G 802.11a/b/g/n/ac,HSPA,LTE 路由器 AT&T,PTCRB,Verizon RJ-45,RS-232,USB
WR54-A246 数据手册
PRELIMINARY DATASHEET DUAL LTE / WI-FI MOBILE ACCESS ROUTER DIGI WR54 Rugged and secure cellular router with dual redundant communications for mission critical industrial and transportation applications The versatility and performance of the Digi® WR54 router make it ideal for mission critical applications requiring continuous connectivity, field longevity and edge computing. Routing and gateway functions are secured across traditional and wireless communications networks, protocols and interfaces – while bridging local private wired or wireless subnets across a public network – safeguarding message privacy and integrity. Each cellular transceiver employs Gobi LTE Advanced technology allowing use on major networks. Dedicated PCIe 2.0 internal data buses deliver 10 GT/s aggregate bandwidth ensuring low latency high bandwidth cellular communications. Four gigabit Ethernet ports connect other IP capable systems, each configurable as an isolated secure LAN or all four can function as a layer 2 switch. Mission critical communication is achieved through concurrent and independent dual cellular interfaces. System operation is assured with an industrial grade electrical and mechanical design, while an embedded python environment enables quick adaptation to future evolving system requirements. Digi TrustFence®, a suite of hardware and firmware features, ensures the integrity of Digi WR54 security functions. A cryptographic co-processor protects particularly sensitive data such as stored passwords and encryption keys. FEATURES AND BENEFITS APPLICATION EXAMPLE – Future built with dual-core 880 MHz MIPS processor and PCIe 2.0 internal bus – Link failover and load balancing across dual 600 Mbps CAT11 cellular – High speed 867 Mbps 802.11ac Wi-Fi for WAN or LAN service – Cryptographic co-processor with secure key generation and storage VPN Tunnel CUSTOMER DATA CENTER Primary and Secondary Cellular Link Wired Ethernet DIGI REMOTE MANAGER® WiFi Link – Gigabit WAN/LAN Ethernet switch (4-port) – Zero-touch fleet-wide configuration using Digi Remote Manager® DIGI® WR54 Smartphone Network Device Laptop/Tablet Legacy Equipment RELATED PRODUCTS Digi® WR64 Digi® WR44 RR Digi® WR31 Accessories Digi Remote Manager ® Security Camera Ethernet Switch Fare Collection SPECIFICATIONS DIGI WR54 CELLULAR LTE – WORLDWIDE LTE FDD : 700 (B12,B13,B17, B28, B29) / 800 (B20) / 850 (B5, B26) / 900 (B8) / 1700AWS(B4, B66) / 1800 (B3) / 1900 (B2, B25) / 2100 (B1) / 2300(B30) / 2600(B7) LTE TDD : 2300(B40) / 2500(B41) / 2600(B38) 3G HSPA: 850/900/1700AWS/1800/1900/2100 MHz Transfer rate (max): 600 Mbps down, 75 Mbps up CONNECTOR Single cellular models: (2) 50 Ω SMA (center pin: female) Dual cellular models: (4) 50 Ω SMA (center pin: female) SIM SLOTS Single cellular models: (2) Mini-SIM (2FF) Dual cellular models: (4) Mini-SIM (2FF) SIM SECURITY Screw-down SIM cover WI-FI MODULE 2 x 2 MIMO 2.4/5 GHz 802.11 a/b/g/n/ac, 867 Mbps (max) HOTSPOT Captive portal, customizable splash page AUTHENTICATION Basic ToS acceptance, Enterprise RADIUS 3RD PARTY SERVICES Content filtering, embedded advertising USER MANAGEMENT Per client usage limit and reporting MODES Up to 4 Access Points and 1 Client SECURITY None, WPA/WPA2-Personal, WPA/WPA2-Enterprise CONNECTORS 2 x 50 Ω RP-SMA (Center pin: male) GPS TECHNOLOGY Multi-constellation: Concurrent reception of up to 3 GNSS (GPS, Galileo, GLONASS, BeiDou) SENSITIVITY -163 dB PROTOCOL Protocol NMEA 0183 V2.3 sentence output CONNECTOR 1 x 50 Ω SMA (Center pin: female); +3.3VDC active antenna drive SOFTWARE AND MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager® (cloud based); SNMP v1/v2c/v3 (user installed/managed) LOCAL MANAGEMENT WebUI (HTTP/HTTPS); CLI (Telnet, SSH, SMS) MANAGEMENT/ TROUBLESHOOTING TOOLS FTP, SFTP, SCP; Protocol analyzer with PCAP for Wireshark; Event logging with Syslog and SMTP; NTP/SNTP PROGRAMMING TOOLS/ ENVIRONMENTS Python v3.6 MEMORY 256 MB RAM, 512 MB file space ETHERNET PORTS (4) RJ-45; 10/100/1000 Mbps (auto-sensing) SERIAL PORTS (1) DB09M; RS232 DTE Signal support TXD, RXD, RTS, CTS, DTR, DCD, DSR, RI software (XON/XOFF), hardware supported USB PORTS (1) USB 3.0 Type A connector PHYSICAL DIMENSIONS (L X W X H) 5.75 in x 8.25 in x 2.5 in (14.61 cm x 20.95 cm x 6.35 cm) WEIGHT 3.3 lbs (1.5 kg) STATUS LEDS Power on, WWAN signal strength, WWAN service ENCLOSURE Die-cast aluminium / IP54 POWER REQUIREMENTS POWER INPUT 9 - 36 VDC, 30W minimum power source required POWER CONSUMPTION 13W typical (idle); 20W typical (peak Tx/Rx) ENVIRONMENTAL OPERATING TEMPERATURE -34° C to +74° C (-29° F to +165° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) WWW.DIGI.COM SPECIFICATIONS DIGI WR54 APPROVALS CELLULAR PTCRB SAFETY UL 60950, CSA 22.2 No. 60950, EN60950, EN62368 VEHICLE ISO-7637-2, SAE J1455, SAE J1113, E-Mark ENVIRONMENTAL MIL-STD-810G EMISSIONS/IMMUNITY CE, FCC Part 15 Class B, AS/NZS CISPR 22, EN55024, EN55032 WARRANTY PRODUCT WARRANTY 3 years DIGI REMOTE MANAGER Manage and control devices from a central, secure platform. When it comes to the Internet of Things, only the most reliable communication connections will do. With Digi Remote Manager ®, you can visually monitor, update and maintain the performance requirements you depend on most, with reports on the following key parameters: – Cellular connection history – 3G/4G LTE signal quality – Public Wi-Fi client usage statistics – Packet delivery SECURITY – Latency – Certified SSAE-16 facilities – Cellular data sent and received – Over 175 security controls in place to protect data – CPU and memory utilization – Security framework compliance with PCI, HIPPA, NIST and others – Network interface throughput – Earned SkyHigh’s Cloud Trust Program highest ranking of Enterprise-ready – Level 1 PCI-DSS validation – Open APIs available to support application development – PCI certified; Attestation of Compliance PART NUMBERS DESCRIPTION WR54-A106 TransPort WR54 Single LTE, Wi-Fi, Worldwide WR54-A206 TransPort WR54 Dual LTE, Wi-Fi, Worldwide PART NUMBERS ACCESSORIES 76002084 WR54 Accessory Kit - Single Cellular 76002085 WR54 Accessory Kit - Dual Cellular 76002076 WR54 Power Supply The information provided in this document is preliminary and may be subject to change without notice. DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2018 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004362 A3/1118 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
WR54-A246 价格&库存
很抱歉,暂时无法提供与“WR54-A246”相匹配的价格&库存,您可以联系我们找货
