ZIGBEE
RF MODULES
FOR OEMS
DIGI XBEE-PRO ZIGBEE
Embedded Zigbee modules provide OEMs with a simple way to integrate mesh
technology into their application
Digi XBee-PRO® Zigbee RF modules provide cost-effective
wireless connectivity to electronic devices. They are
interoperable with other Zigbee Pro feature set devices,
including devices from other vendors.
The Serial Peripheral Interface (SPI) provides a highspeed interface and optimizes integration with embedded
microcontrollers, lowering development costs and reducing
time to market.
Digi XBee-PRO Zigbee modules are ideal for applications
in the energy and controls markets where manufacturing
efficiencies are critical.
Digi’s Zigbee compatible module is based on the Ember
EM35x (EM357 and EM3587) system on chip (SoC) radio ICs
from Silicon Labs, utilizing 32-bit ARM® Cortex® M3 processor.
BENEFITS
APPLICATION EXAMPLE
– Surface mount form factors enable flexible design
options
– Link budgets of 110 dB for Digi XBee and 119 dB for Digi
XBee-PRO
– Industry-leading sleep current
Ethernet
DIGI REMOTE MANAGER®
REMOTE MONITORING
OFFICE
– Firmware upgrades via UART, SPI or over the air (OTA)
Cellular/Wi-Fi/Ethernet
ZIGBEE WIRELESS MESH NETWORK
– Turnkey development available from Digi WDS
DIGI XBEE®
ZIGBEE GATEWAY
Solar
panel
RELATED PRODUCTS
Solar
Inverter
Digi XBee®
Gateways
Modules
Network
Extenders
Development
Kits
Digi Remote
Manager®
DIGI XBEE®
MODULE
SPECIFICATIONS
SPECIFICATIONS
PERFORMANCE
TRANSCEIVER CHIPSET
Silicon Labs EM357 SoC
DATA RATE
RF 250 Kbps, serial up to 1 Mbps
INDOOR/URBAN RANGE*
Up to 90 m (300 ft)
OUTDOOR/RF LINE-OF-SIGHT
RANGE*
Up to 3200 m (2 miles)
TRANSMIT POWER
63 mW (+18 dBm)
RECEIVER SENSITIVITY (1% PER)
-101 dBm
FEATURES
SERIAL DATA INTERFACE
UART, SPI
CONFIGURATION METHOD
API or AT commands, local or over-the-air (OTA)
FREQUENCY BAND
ISM 2.4 GHz
FORM FACTOR
Surface mount
INTERFERENCE IMMUNITY
DSSS (Direct Sequence Spread Spectrum)
ADC INPUTS
(4) 10-bit ADC inputs
DIGITAL I/O
15
ANTENNA OPTIONS
SMT: RF pad, PCB antenna, or U.FL connector
OPERATING TEMPERATURE
-40º C to 85º C (-40º F to 185º CF)
DIMENSIONS (L X W X H) AND
WEIGHT
SMT: 2.199 x 3.4 x 0.305 cm (0.866 x 1.33 x 0.120 in)
NETWORKING AND SECURITY
PROTOCOL
Zigbee PRO 2007, HA-Ready with support for binding/multicastingc
ENCRYPTION
128-bit AES
RELIABLE PACKET DELIVERY
Retries/Acknowledgements
IDS
PAN ID and addresses, cluster IDs and endpoints (optional)
CHANNELS
15 channels
POWER REQUIREMENTS
SUPPLY VOLTAGE
2.7 to 3.6 V
TRANSMIT CURRENT
115 mA @ 3.3 VDC
RECEIVE CURRENT
34 mA @ 3.3 VDC
POWER-DOWN CURRENT
很抱歉,暂时无法提供与“XBP24CZ7RIS-005”相匹配的价格&库存,您可以联系我们找货
