WR11-M900-DE1-XB
WR11-M900-DE1-XB
    DIGIINTERNATIONAL
    4G/3G HSPA+ 路由器 RJ-45
WR11-M900-DE1-XB 数据手册
COMPACT 4G LTE M2M ROUTER DIGI TRANSPORT® WR11 XT Secure 3G/4G/LTE cellular router for retail, kiosk and industrial control applications Digi TransPort WR11 XT delivers a cost-optimized 4G LTE connection to mission critical M2M applications around the world. These cellular routers are ideal for connecting: – Building and process automation controllers – Smart grid assets (meters, switches and controllers) – IP cameras and access controllers – Remote data loggers, flow meters and sensing equipment – Telco infrastructure controllers – ATMs, kiosks and service terminals BENEFITS: The Digi TransPort WR11 XT provides a secure, reliable connection to industrial controllers, retail terminals and process automation equipment on third party sites or remote locations. This drop-in connectivity gives operators a way to reduce the cost of downtime and service calls and also increase revenue by bringing distributed sites online faster. Digi management solutions provide easy setup, configuration and maintenance of large installations of remote Digi TransPort devices. Digi Remote Manager ® offers webbased device management for remote Digi cellular routers, gateways and third-party devices. APPLICATION EXAMPLE – Global HSPA+ and 4G LTE support and certification – Extremely resilient cellular connection through patented Digi SureLink™, VRRP+ protocol and dual SIM slots – Enterprise routing features for security, logging and redundancy (e.g., stateful firewall, VPN, SNMP); no annual enterprise software license required MANAGED SERVICE PROVIDER – Digi Remote Manager provides mass configuration, device management and troubleshooting tools CENTRAL APPLICATION 3G/4G/LTE – Rugged aluminum enclosure, flanges and optional DIN rail clip for flexible mounting – 5-year warranty standard—no additional cost DIGI REMOTE MANAGER® DIGI TRANSPORT® WR11 XT Gaming Terminal Industrial Controller Service Kiosk ATM RELATED PRODUCTS Digi TransPort® WR21 Digi TransPort® Digi TransPort® WR44 R WR31 Accessories Digi Remote Manager ® Digi TransPort® WR11 XT SPECIFICATIONS CELLULAR LTE - EMEA (M3) LTE CAT 1: 800(B20)/900(B8)/1800(B3)/2100(B1)/2600 (B7) 2G EDGE: 900/1800 MHz Transfer rate (max): 10 Mbps down, 5 Mbps up LTE - UNITED STATES (M4) LTE CAT 1: 700(B12)/850(B5,B26)/AWS(B4)/1900(B2,B25) Transfer rate (max): 10 Mbps down, 5 Mbps up Approvals: Sprint (pending) LTE - NORTH AMERICA (M6) LTE CAT 1: 700(B12,B13)/850(B5)/AWS(B4)/1900(B2) HSPA+: 850/1900 MHz Transfer rate (max): 10 Mbps down, 5 Mbps up Approvals: PTCRB, AT&T, Telus (pending) LTE - ANZ/LATAM (M9) LTE CAT 1: 700(B28)/850(B5)/900(B8)/1800(B3)/2100(B1) 3G HSPA+: 850/900/2100 MHz Transfer rate (max): 10 Mbps down, 5 Mbps up GLOBAL HSPA+ - (U9) 3G HSPA+: 850/900/1700AWS/1900/2100 MHz 2G EDGE/GPRS: 850/900/1800/1900 MHz Transfer rate (max): 21 Mbps down, 5.76 Mbps up Approvals: PTCRB, Vodafone CONNECTORS (2) 50 Ω SMA (center pin: female); (1) connector for non-LTE models SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Screw-down SIM cover SOFTWARE & MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager® (cloud based); SNMP v1/v2c/v3 (user installed/managed) LOCAL MANAGEMENT MANAGEMENT/ TROUBLESHOOTING TOOLS MEMORY WebUI (HTTP/HTTPS); CLI (Telnet, SSH, SMS) FTP, SFTP, SCP; Protocol analyzer with PCAP for Wireshark; Event logging with Syslog and SMTP; NTP/SNTP 20 MB RAM, 10 MB file space ETHERNET PORTS (1) RJ-45; 10/100 Mbps (auto-sensing) PHYSICAL DIMENSIONS (L X W X H) 3 in x 4 in x 1 in (7.62 cm x 10.16 cm x 2.54 cm) WEIGHT 0.5 lb (.22 kg) STATUS LEDS Power on, WWAN signal strength, WWAN service ENCLOSURE Industrial (Metal) / IP30 POWER REQUIREMENTS POWER INPUT 5 VDC, 15W minimum power source required POWER SUPPLY Must be used with a Digi approved power supply POWER CONSUMPTION 3.5W typical (Idle); 10W typical (Peak Tx/Rx) ENVIRONMENTAL OPERATING TEMPERATURE -30° C to +70° C (-22° F to +158° F) reduced cellular performance may occur above +60° C RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR PTCRB SAFETY UL 60950, CSA 22.2 No. 60950, EN60950 EMISSIONS/IMMUNITY CE, FCC Part 15 Class B, AS/NZS CISPR 22, EN55024, EN55022 Class B WARRANTY PRODUCT WARRANTY 5 years Ethernet Power DIGI TRANSPORT® WR11 XT - TOP Ethernet 3.67 in Power LEFT SIDE Ethernet RIGHT SIDE Single antenna for EVDO/HSPA+ variant Power Antenna 3.67 in Height: 1 in Single antenna for EVDO/HSPA+ variant Antenna Mounting for Screws 4.05 in Mounting for Screws 3.67 in Height: 1 in 4.05 in Mounting for Screws Height: 1 in 4.05 in Single antenna for EVDO/HSPA+ variant Antenna WWW.DIGI.COM ENTERPRISE SOFTWARE DESCRIPTION Enterprise Software PROTOCOL SUPPORT HTTP, HTTPS, FTP, SFTP, SSL, SMTP, SNMP (v1/v2c/v3), SSH, Telnet and CLI for web management; Remote management via Digi Remote Manager; SMS management, protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; Dynamic DNS client compatible with BIND9/No-IP/DynDNS SECURITY/VPN IP filtering, stateful inspection firewall with scripting, address and port translation; VPN: IPSec with IKEv1, IKEv2, NAT Traversal; SSL, SSLv2, SSLv3, FIPS 197, open VPN client and server; PPTP, L2TP; (5) VPN tunnels (upgradable to a maximum of 50); Cryptology: SHA-1, MD5, RSA; Encryption: DES, 3DES and AES up to 256-bit (CBC mode for IPsec); Authentication: RADIUS, TACACS+, SCEP for X.509; certificates; Content filtering (via 3rd party); MAC address filtering; VLAN support ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: PPP, PPPoE, RIP (v1, v2) OSPF, SRI, BGP, iGMP routing (multicast); RSTP (Rapid Spanning Tree Protocol); IP failover: VRRP, VRRP+TM; Automatic failover/ failback to second GSM network/standby APN OTHER PROTOCOLS DHCP; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; QoS via TOS/DSCP/WRED DIGI REMOTE MANAGER® CAPABILITIES – Centralized management of remote devices over 3G/4G/LTE – Define standard configurations and automatically monitor individual devices for PCI security compliance – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss – No servers or applications to operate and maintain – Complete tasks for your entire device network in minutes – Edit configurations and update firmware for your individual devices or groups – Monitor the status and location of your remote device via a web browser – Active or deactivate cellular lines and monitor data to ensure you never incur overage charges SECURITY INFRASTRUCTURE – Hosted in a commercial-grade SAS 70-certified environment – Superior availability, operating to 99.9% or greater – Open APIs available to support application development – Certified SSAE-16 and ISO27001 facilities – Over 175 Security Controls in place to protect your data – Enables compliance with security frameworks like PCI, HIPAA, NIST and more – Earned SkyHigh’s Cloud Trust Program highest ranking of Enterprise-Ready PART NUMBERS DIGI TRANSPORT WR11 XT WR11-M300-DE1-XB 4G LTE EMEA/APAC WR11-M400-DE1-XB 4G LTE Sprint WR11-M600-DE1-XB 4G LTE North America WR11-M900-DE1-XB 4G LTE LATAM/ANZ WR11-U900-DE1-XW HSPA+ Global PART NUMBERS ACCESSORIES* 76002065 Accessory Kit DC - Includes DC/DC power supply (9-30 VDC / 5 VDC), ethernet cable and antennas (2) 76002062 Accessory Kit AC - Includes AC/DC power supply (US), ethernet cable and antennas (2) 76002063 Accessory Kit AC Intl - Includes AC/DC power supply (Intl plugs), ethernet cable and antennas (2) 76002064 Accessory Kit Ext Temp AC - Includes AC/DC power supply (-30° C to +70° C), ethernet cable and antennas (2) *Sold separately, unless otherwise noted. DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2018 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004202 A2/1217 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
WR11-M900-DE1-XB 价格&库存
很抱歉,暂时无法提供与“WR11-M900-DE1-XB”相匹配的价格&库存,您可以联系我们找货
