WR44-E1A3-CE1-SW
WR44-E1A3-CE1-SW
    DIGIINTERNATIONAL
    RF MODULES TRANSPORT WR44 EDGE,
WR44-E1A3-CE1-SW 数据手册
ENTERPRISE CLASS WI-FI TO CELLULAR ROUTER DIGI TRANSPORT® WR44 Enterprise class, commercial grade Wi-Fi to cellular router with flexible interface options ideal for mobile and transportation applications The Digi TransPort WR44 cellular router is an all-in-one mobile communications solution with true enterprise-class routing, security and firewall. This multifunction cellular router features a flexible design with integrated Wi-Fi access point, USB, serial and 4-port Ethernet switch, as well as a variety of configuration options including multiple serial ports (async or sync), GPS or I/O telemetry modules. The Digi TransPort family offers an advanced routing, security and firewall feature set including stateful inspection firewall and integrated VPN. Enterprise-class protocols incorporate BGP, OSPF and VRRP+, a patented technology built upon the BENEFITS popular VRRP failover standard providing true auto sensing, auto failure and auto recovery of any line drop. Digi TransPort WR44 is ideal for transportation and mobile applications. Flexible power options include 11-58 VDC barrel or molex connectors for direct integration into vehicle applications. Digi Remote ManagerSM provides easy setup, configuration and maintenance of large installations of Digi TransPort devices. APPLICATION EXAMPLE – Enterprise class cellular routers with advanced dynamic routing, security and firewall features – High speed cellular interfaces: GSM GPRS/EDGE/ HSPA/CDMA EV-DO and 4G LTE – Optional integrated 802.11 b/g Wi-Fi access point and 4-port Ethernet switch DEVICE CLOUD HEADQUARTERS – Flexible interfaces including DSL, serial (async/sync), GPS, USB and telemetry, with DC power options CREDIT CARD PROCESSOR Cellular/VPN – Powerful integrated end user programming DIGI TRANSPORT® 44 – Digi Remote Manager software for easy setup, configuration, and maintenance – Available in industrial and commercial grade platforms RELATED PRODUCTS Wi-Fi Laptop Digi TransPort® WR11 Digi TransPort® WR21 Digi TransPort® WR44 R Accessories Digi Remote ManagerSM Serial Cash Register SPECIFICATIONS Digi TransPort® WR44 WIRELESS INTERFACES WWAN** LTE - EMEA (L1) 800/850/900/1800/1900/2100/2600 MHz; 3G fall back to 850/900/1900/2100MHz and 2G fall back to 850/900/1800/1900 MHz; Transfer rate (max): 50 Mbps Up, 100 Mbps Down LTE - NORTH AMERICA (L5) Multi-Carrier (Verizon, AT&T, and Sprint) 700/850/1700(AWS)/1900 MHz; 2G/3G GSM fall back to 850/900/1700AWS/1800/1900/2100 MHz; 2G/3G CDMA fall back to 800/1900 MHz; Transfer rate (max): 50 Mbps Up, 100 Mbps Down LTE – NORTH AMERICA (L6) 700/850/1700(AWS)/1900 MHz; 2G/3G fall back to 850/1900 MHz; Transfer rate (max): 50 Mbps Up, 100 Mbps Down LTE – VERIZON (L8) 700/1700(AWS) MHz; No 2G/3G fall back; Transfer rate (max): 50 Mbps Up, 100 Mbps Down HSPA+ (U9) 850/900/1700 (AWS)/1900/2100 MHz; Transfer rate (max): 5.76 Mbps Up, 21 Mbps Down GSM-R (R5)* 900/1800/1900 MHz (TRM-5); GPRS Class 10; Transfer rate (max): 42.8 Kbps Up, 85.6 Kbps Down EDGE (E1) GPRS/EDGE Class 10; 850/900/1800/1900 MHz; Transfer rate (max): 236 Kbps Up/Down CDMA EV-DO (DX)* 450 MHz; EV-DO Rev B; R-UIM support; Transfer rate (max): 14.7 Mbps Up; 5.4 Mbps Down CONNECTOR Ux, Lx variants: 2 x 50 Ω SMA (Center pin: female); E1, Dx, Bx variants: 1 x 50 Ω SMA (Center pin: female) SIM SLOTS 2, Mini-SIM (2FF) SIM SECURITY SIM slot cover plate optional WI-FI* STANDARD 802.11b/g/n MODES Access point, Client and support for multiple SSID TRANSMIT POWER 20 dBm + 1.0/-1.5 dBm RECEIVE SENSITIVITY 54 Mbps /
WR44-E1A3-CE1-SW 价格&库存
很抱歉,暂时无法提供与“WR44-E1A3-CE1-SW”相匹配的价格&库存,您可以联系我们找货
