ENTERPRISE CLASS
WI-FI TO CELLULAR
ROUTER
DIGI TRANSPORT® WR44
Enterprise class, commercial grade Wi-Fi to cellular router with flexible
interface options ideal for mobile and transportation applications
The Digi TransPort WR44 cellular router is an all-in-one
mobile communications solution with true enterprise-class
routing, security and firewall. This multifunction cellular router
features a flexible design with integrated Wi-Fi access point,
USB, serial and 4-port Ethernet switch, as well as a variety of
configuration options including multiple serial ports (async or
sync), GPS or I/O telemetry modules.
The Digi TransPort family offers an advanced routing, security
and firewall feature set including stateful inspection firewall
and integrated VPN. Enterprise-class protocols incorporate
BGP, OSPF and VRRP+, a patented technology built upon the
BENEFITS
popular VRRP failover standard providing true auto sensing,
auto failure and auto recovery of any line drop.
Digi TransPort WR44 is ideal for transportation and mobile
applications. Flexible power options include 11-58 VDC barrel
or molex connectors for direct integration into vehicle
applications. Digi Remote ManagerSM provides easy setup,
configuration and maintenance of large installations of
Digi TransPort devices.
APPLICATION EXAMPLE
– Enterprise class cellular routers with advanced
dynamic routing, security and firewall features
– High speed cellular interfaces: GSM GPRS/EDGE/
HSPA/CDMA EV-DO and 4G LTE
– Optional integrated 802.11 b/g Wi-Fi access point
DEVICE CLOUD
HEADQUARTERS
– Flexible interfaces including DSL, serial (async/sync),
GPS, USB and telemetry, with DC power options
CREDIT CARD
PROCESSOR
Cellular/VPN
– Powerful integrated end user programming
DIGI TRANSPORT® 44
– Digi Remote Manager software for easy setup,
configuration, and maintenance
– Available in industrial and commercial grade platforms
RELATED PRODUCTS
Wi-Fi
Laptop
Digi TransPort®
WR11
Digi TransPort®
WR21
Digi TransPort®
WR44 R
Accessories
Digi Remote
ManagerSM
Serial
Cash Register
SPECIFICATIONS
Digi TransPort® WR44
WIRELESS INTERFACES
WWAN**
LTE - EMEA (L1)
800/850/900/1800/1900/2100/2600 MHz; 3G fall back to 850/900/1900/2100MHz and 2G fall back to 850/900/1800/1900 MHz;
Transfer rate (max): 50 Mbps Up, 100 Mbps Down
LTE - NORTH AMERICA (L5)
Multi-Carrier (Verizon, AT&T, and Sprint) 700/850/1700(AWS)/1900 MHz; 2G/3G GSM fall back to 850/900/1700AWS/1800/1900/2100 MHz;
2G/3G CDMA fall back to 800/1900 MHz; Transfer rate (max): 50 Mbps Up, 100 Mbps Down
LTE – NORTH AMERICA (L6)
700/850/1700(AWS)/1900 MHz; 2G/3G fall back to 850/1900 MHz; Transfer rate (max): 50 Mbps Up, 100 Mbps Down
LTE – VERIZON (L8)
700/1700(AWS) MHz; No 2G/3G fall back; Transfer rate (max): 50 Mbps Up, 100 Mbps Down
HSPA+ (U9)
850/900/1700 (AWS)/1900/2100 MHz; Transfer rate (max): 5.76 Mbps Up, 21 Mbps Down
GSM-R (R5)*
900/1800/1900 MHz (TRM-5); GPRS Class 10; Transfer rate (max): 42.8 Kbps Up, 85.6 Kbps Down
EDGE (E1)
GPRS/EDGE Class 10; 850/900/1800/1900 MHz; Transfer rate (max): 236 Kbps Up/Down
CDMA EV-DO (DX)*
450 MHz; EV-DO Rev B; R-UIM support; Transfer rate (max): 14.7 Mbps Up; 5.4 Mbps Down
CONNECTOR
Ux, Lx variants: 2 x 50 Ω SMA (Center pin: female); E1, Dx, Bx variants: 1 x 50 Ω SMA (Center pin: female)
SIM SLOTS
2, Mini-SIM (2FF)
SIM SECURITY
SIM slot cover plate optional
WI-FI*
STANDARD
802.11b/g/n
MODES
Access point, Client and support for multiple SSID
TRANSMIT POWER
20 dBm + 1.0/-1.5 dBm
RECEIVE SENSITIVITY
54 Mbps /
很抱歉,暂时无法提供与“WR44-E100-NE1-SW”相匹配的价格&库存,您可以联系我们找货
