XA-A14-CS2P-25
XA-A14-CS2P-25
    DIGIINTERNATIONAL
    XBEE PRO 802.15.4 RS232 ADAP 25P
XA-A14-CS2P-25 数据手册
Product Datasheet XBee Be ™ Adapters d pt rs ZigBee®/802.15.4 Device Adapters for Drop-in Networks XBee adapters provide easy ZigBee/802.15.4 wireless connectivity to sensors, controllers and other devices used for remote monitoring and control. All XBee adapters can be used with Digi’s ConnectPort™ IP gateways to build wireless Drop-in Networks. Ethernet Central Facilities Management Internet/ Frame Relay/ VPN Wireless Telco Network ConnectPort™ X Watchport® USB Camera Warehouse USB o P e P t 4 Watchport®/D O Distance Sensor Wire Zone 1 Lights Zone 2 Lights Adapter PR P • Compatible with Digi’s ConnectPort X family of IP gateways for LAN/WAN connectivity • Multiple interface options provide broad device support: Serial, USB, 1-Wire, Digital I/O, Analog I/O • Small form factor for easy handling and installation • Flexible powering options include external power, N-Cell battery or both for power redundancy • Two versions available: XBee and XBee-PRO™ (longer range) g -in Network op in Dr www.digi.com o hp t ID Fob Reader 232 ZigBee/802.15.4 Wireless Mesh Network Zone 3 Lights • ZigBee/802.15.4 wireless mesh connectivity for all types of end-point devices t O Lighting Ballast & Occupancy Sensor Features/Benefits W XBee™ Adapter Entry/Exit Door O XBee™ Module Overview ZigBee/802.15.4 technology enables low-cost, low-power networking of sensors, controllers and other such devices in self-configuring, self-healing wireless mesh networks. Digi’s XBee adapters are used to retrofit existing devices for ZigBee/802.15.4 connectivity. Available with multiple interface options, these adapters deliver the benefits of ZigBee/802.15.4 mesh networking off-the-shelf, without the development time required when using an embedded solution. As part of Digi's Drop-in Networks product family, XBee adapters can be used with ConnectPort X gateways to "drop-in" end-to-end device networks without the need for a wired network infrastructure. Each Digi XBee adapter contains a ZigBee/802.15.4 wireless module for network connectivity and a physical interface for device connectivity. Available interfaces include RS-232 (powered power harvesting), RS-485, USB, 1-Wire, Digital I/O and Analog I/O. Each is offered in a small form factor with various powering options that include external power supply, N-cell battery, both external and battery power for redundancy, or parasitic power drawn from the connected device. Two performance levels of XBee adapters are available: XBee and XBee-PRO. The PRO version provides greater transmit power and approximately three-times the range of the regular version. Compatibility Note: Two sets of XBee and XBee-PRO adapters are offered: Series 1 and Series 2. Though overall performance and product specifications are largley similar, the two series are built on distinct and non-compatible technology platforms. Thus, users must standardize on one series or the other for operability. The same is true for compatibility with the ConnectPort X gateways. Series 1 XBee adapters are compatible only with Series 1 gateways, while Series 2 XBee adapters are compatible only with Series 2 gateways. Series 1 XBee specifications appear on page 2 of this datasheet. Series 2 XBee specifications are on page 3. Features/Specifications - Series 1 XBee Adapters REGULATORY APPROVALS FEATURES INTERFACES General • Frequency: 2.4 GHz (ISM) • Antenna options: Integrated whip antenna Performance: XBee • Indoor/Urban range: Up to 100 ft (30 m) • Outdoor RF line of sight range: Up to 300 ft (100 m) • Transmit power output: 1 mW (0 dBm) • RF data rate: 250,000 bps • Receiver sensitivity: -92 dBm (1% PER) Performance: XBee-PRO • Indoor/Urban range: Up to 300 ft (100 m) • Outdoor RF line of sight range: Up to 1 mile (1.6 km) • Transmit power output: 60 mW (18 dBm)*, 100 mW EIRP* • RF data rate: 250,000 bps • Receiver sensitivity: -100 dBm (1% PER) Networking and Security • Network topologies: Point-to-Point, Point-to-Multipoint, Peer-to-Peer, Mesh • Number of channels: XBee: 16 - 5 MHz channels (Direct Sequence Spread Spectrum) XBee-PRO: 12 Direct Sequence Channels (software selectable) • Filtration options: PAN ID, Channel, Source/Destination Addresses LEDs • Power: Glows green when external power is supplied (not active when battery powered to limit power drain) • Associate: Glows when unit is connected and associated on an RF network Controls • Device reset (internal push button) • Identification (internal push button): Relays identification to ConnectPort X gateway Serial • RS-232 (DB-9M) • RS-232PH (DB-9M); power harvesting version • RS-485 (6-position wire terminal block) - Switch selectable between RS-422 half duplex, RS-422 full duplex and RS-485 • 1-Wire (RJ-45) USB • USB 2.0 Full Speed (with ESD protection); connects to host via captive 2-meter cable ENVIRONMENTAL XBee 232, 485, 1-Wire, Analog I/O and Digital I/O • Operating temperature: Externally powered: -40C to 85C Battery powered: -18C to 55C XBee USB • Operating temperature: -40° C to 85° C XBee 232PH • Operating temperature: 0° C to 65° C DIMENSIONS XBee 232, 485, 1-Wire, Analog I/O and Digital I/O Width: 1.68 in (4.26 cm) Height: 0.99 in (2.53 cm) Length: 3.87 in (9.84 cm) Weight: 2.29 oz (6.50 g) XBee USB and 232PH Width: 1.80 in (4.57 cm) Height: 0.83 in (2.10 cm) Length: 2.87 in (7.29 cm) Weight: 1.60 oz (45.36 g) • • • • • • • • FCC Part 15.247 - Pending Industry Canada (IC) - Pending Europe (CE) - Pending EN55022, Class A - Pending UL60950 - Pending CAN/CSA C22.2 No. 60950 - Pending EN60950 - Pending RoHS compliant POWER REQUIREMENTS XBee 232, 485, 1-Wire, Analog I/O and Digital I/O • Externally powered: 9-30 VDC, locking connector • Battery powered: 3 internal N cell batteries XBee USB • Bus powered: +5V from USB bus • Power consumption during normal operation: - XBee: 70mA - XBee-PRO: 70 mA (Rx) and 250 mA (Tx) • Power consumption during suspend mode: - XBee and XBee-PRO: 200 uA XBee 232PH • Internal battery provides power when unit is operating and recharges from the serial port when in sleep mode • Requires a sleep/wake duty cycle as part of its normal operation. • Requires a fully functional serial port conforming to the RS232c standard for optimal operation. • Sleep/wake duty cycle requirements will vary based on the current output of serial port • Serial ports with more than 14VDC output (rare) are not supported and may cause malfunction • Serial ports that provide hard power of 5 to 14VDC on one or more pins will allow the device to operate continually without a sleep/wake cycle MODEL......................PART NUMBERS Model/Interface XBee/XBee-PRO RS-485 XBee/XBee-PRO RS-232 XBee/XBee-PRO 1-Wire XBee/XBee-PRO Analog I/O XBee/XBee-PRO Digital I/O XBee/XBee-PRO USB XBee/XBee-PRO RS-232PH (power harvesting) XBee XA-A14-CS3R XA-A14-CS2R XA-A14-CS1R XA-A14-CS5R XA-A14-CS4R XA-A14-CE1R XA-A14-CE2R XBee-PRO XA-A14-CS3P XA-A14-CS2P XA-A14-CS1P XA-A14-CS5P XA-A14-CS4P XA-A14-CE1P XA-A14-CE2P Series 1 XBee Adapters are compatible only with Series 1 ConnectPort X gateways. * When operating in Europe: XBee-PRO adapters must be configured to operate at a maximum TX power output level (power output level is set using the PL command). Additionally, European regulations stipulate an EIRP power maximum of 12.86 dBm (1 mW). Features/Specifications - Series 2 XBee Adapters FEATURES INTERFACES General • Frequency: 2.4 GHz (ISM) • Antenna options: Integrated whip antenna Performance • Indoor/Urban range: Up to 100 ft (30 m) • Outdoor RF line of sight range: Up to 300 ft (100 m) • Transmit power output: 1 mW (0 dBm) • RF data rate: 250,000 bps • Receiver sensitivity: -95 dBm (1% PER) Networking and Security • Network topologies: Point-to-Point, Point-to-Multipoint, Peer-to-Peer, Mesh • Number of channels: 16 - 5 MHz channels (Direct Sequence Spread Spectrum) • Filtration options: PAN ID, Channel, 264 (64-bit) addresses LEDs • Power: Glows green when external power is supplied (not active when battery powered to limit power drain) • Associate: Glows when unit is connected and associated on an RF network Controls • Device reset (internal push button) • Identification (internal push button): Relays identification to ConnectPort X gateway Serial • RS-232 (DB-9M) • RS-232PH (DB-9M); power harvesting version • RS-485 (6-position wire terminal block) - Switch selectable between RS-422 half duplex, RS-422 full duplex and RS-485 • 1-Wire (RJ-45) USB • USB 2.0 Full Speed (with ESD protection); Connects to host via captive 2-meter cable DIMENSIONS XBee 232, 485, 1-Wire, Analog I/O and Digital I/O Width: 1.68 in (4.26 cm) Height: 0.99 in (2.53 cm) Length: 3.87 in (9.84 cm) Weight: 2.29 oz (6.50 g) XBee USB and 232PH Width: 1.80 in (4.57 cm) Height: 0.83 in (2.10 cm) Length: 2.87 in (7.29 cm) Weight: 1.60 oz (45.36 g) ENVIRONMENTAL REGULATORY APPROVALS XBee 232, 485, 1-Wire, Analog I/O and Digital I/O • Operating temperature: Externally powered: -40C to 85C Battery powered: -18C to 55C XBee USB • Operating temperature: -40° C to 85° C XBee 232PH • Operating temperature: 0° C to 65° C • • • • • • • • FCC Part 15.247 - Pending Industry Canada (IC) - Pending Europe (CE) - Pending EN55022, Class A - Pending UL60950 - Pending CAN/CSA C22.2 No. 60950 - Pending EN60950 - Pending RoHS compliant MODEL......................PART NUMBERS Model/Interface XBee/XBee-PRO RS-485 XBee/XBee-PRO RS-232 XBee/XBee-PRO 1-Wire XBee/XBee-PRO Analog I/O XBee/XBee-PRO Digital I/O XBee/XBee-PRO USB XBee/XBee-PRO RS-232PH (power harvesting) XBee XA-B14-CS3R XA-B14-CS2R XA-B14-CS1R XA-B14-CS5R XA-B14-CS4R XA-B14-CE1R XA-B14-CE2R XBee-PRO Available Sep 07 Available Sep 07 Available Sep 07 Available Sep 07 Available Sep 07 Available Sep 07 Available Sep 07 Series 2 XBee Adapters are compatible only with Series 2 ConnectPort X gateways. POWER REQUIREMENTS XBee 232, 485, 1-Wire, Analog I/O and Digital I/O • Externally powered: 9-30 VDC, locking connector • Battery powered: 3 internal N cell batteries XBee USB • Bus powered: +5V from USB bus • Power consumption during normal operation: - XBee: 70mA - XBee-PRO: 70 mA (Rx) and 250 mA (Tx) • Power consumption during suspend mode: - XBee and XBee-PRO: 200 uA XBee 232PH • Internal battery provides power when unit is operating and recharges from the serial port when in sleep mode • Requires a sleep/wake duty cycle as part of its normal operation. • Requires a fully functional serial port conforming to the RS232c standard for optimal operation. • Sleep/wake duty cycle requirements will vary based on the current output of serial port • Serial ports with more than 14VDC output (rare) are not supported and may cause malfunction • Serial ports that provide hard power of 5 to 14VDC on one or more pins will allow the device to operate continually without a sleep/wake cycle Line Art/Application Diagram XBee 232, 485, 1-Wire, Analog I/O, Digital I/O Front XBee USB, 232PH Back Back Assc Ident Power Interface Options Power 232PH XBee USB Interface Options XBee 485 6-position wire XBee 1-Wire XBee 232, Analog I/O, Digital I/O RJ-45 USB DB-9M DB-9M Serial Drop-in Network for Tank Level Monitoring Headquarters Servers Internet/ Frame Relay/ VPN Ethernet Wireless Telco Network ConnectPort Gateway M e tP C n rt X4 XBee Ada ™ ZigBee/802.15.4 Wireless Mesh Network Level Sensor RS-485 Liquid Storage Tank DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here WHEN to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 11001 Bren Road E. Minnetonka, MN 55343 U.S.A. PH: 877-912-3444 952-912-3444 FX: 952-912-4952 email: info@digi.com Digi International France Digi International KK Digi International (HK) Limited 31 rue des Poissonniers 92200 Neuilly sur Seine PH: +33-1-55-61-98-98 FX: +33-1-55-61-98-99 www.digi.fr NES Building South 8F 22-14 Sakuragaoka-cho, Shibuya-ku Tokyo 150-0031, Japan PH: +81-3-5428-0261 FX: +81-3-5428-0262 www.digi-intl.co.jp Suite 1703-05, 17/F., K Wah Centre 191 Java Road North Point, Hong Kong PH: +852-2833-1008 FX: +852-2572-9989 www.digi.cn MATTERS™ Digi International, the leader in device networking for business, develops reliable products and technologies to connect and securely manage local or remote electronic devices over the network or via the web. With over 20 million ports shipped worldwide since 1985, Digi offers the highest levels of performance, flexibility and quality. www.digi.com © 2007 Digi International Inc. All rights reserved. Digi, Digi Inte national, the Digi logo, he When Reliability Matters logo, ConnectPort, Watchport, XBee and XBee-PRO are either trademarks or registered trademarks of Digi Inte national Inc. in the United States and o her countries worldwide. Microsoft, Windows and he Windows logo are trademarks or registered trademarks of Microsoft Corporation in he United States and/or other countries. All other trademarks are the property of their respective holders. 91001420 A1/607
XA-A14-CS2P-25 价格&库存
很抱歉,暂时无法提供与“XA-A14-CS2P-25”相匹配的价格&库存,您可以联系我们找货
