900 MHZ WIRELESS
ETHERNET BRIDGE
XPRESS™
ETHERNET BRIDGE
The XPress Ethernet Bridge provides a secure point-to-point or point-to-multipoint
IP connection without the expense and limitations of physical cabling
The XPress Ethernet Bridge replaces costly wiring with a
solution that can wirelessly connect industrial PLCs, digital
signs, security cameras, access controllers and more. With a
range of up to 15 miles, the ability to transmit through as many
as 10 standard walls, a 1.5 Mbps data rate, and the added
range and capabilities of the 900 MHz band, the easy-to-use,
long-range XPress Ethernet Bridge communicates where Wi-Fi
and other wireless data products fall short.
available radio channel at start-up, monitor the signalto-noise ratio and move the network to a new channel if
necessary. A web interface simplifies installation, allows
users to monitor packet success and signal strength and
facilitates remote troubleshooting.
The XPress Ethernet Bridge is housed in a weatherproof
enclosure. It is available in pre-paired units or single units for
point-to-multipoint applications.
The XPress Ethernet Bridge features a built-in spectrum
analyzer, allowing users to monitor RF interference. Frequency
agility enables the product to automatically select the best
BENEFITS
APPLICATION EXAMPLE
– Easy-to-use web interface simplifies configuration
and remote troubleshooting
– Check packet success and signal strength with the
web interface
– Outdoor line-of-sight range of up to 15 miles
(with high gain antenna)
CENTRAL
OFFICE
XPRESS™
ETHERNET BRIDGE
– AES encryption, FIPS 197 and optional FIPS 140-2
provide secure communication
– Built-in NAT supports multiple IP client devices
RF Signal
– Frequency agility ensures reliable connection between
radios
– Monitor RF interference with built-in spectrum analyzer
RELATED PRODUCTS
Industrial PLC
Network Camera
OR
OR
Access Controller
Network Printer
OR
XTend®
RF Modem
Digi XLR Pro™
ConnectPort®
X2
XBee® ZigBee®
Module
XBee® ZigBee®
Adapter
VoIP Phone
XPRESS™
ETHERNET BRIDGE
OR
Wi-Fi Access
SPECIFICATIONS
XPress™ Ethernet Bridge
PERFORMANCE
INDOOR/URBAN RANGE
Up to 1000 ft (300 m) w/ 2.1 dB dipole antenna
OUTDOOR/RF LINE-OF-SIGHT RANGE
Up to 2 miles (3.2 km) w/ 2.5 dB dipole antenna, Up to 15 miles (24 km) w/ high-gain antenna
TRANSMIT POWER OUTPUT
125 mW (+21 dBm), 4W EIRP w/ 15 dBi antenna
THROUGHPUT DATA RATE
935 Kbps
RF DATA RATE
1.536 Mbps
RECEIVER SENSITIVITY
-97 dBm (@10e-4 BER)
FEATURES
SUPPPORTED PROTOCOLS
TCP/IP, Rockwell (RSLinx EtherNet/IP, CSP), Modbus/TCP
BROWSER MANAGEMENT TOOLS
QoS statistics, Network settings, Spectrum analyzer, Firmware upgrading
DATA CONNECTION
10/100Base-T RJ-45, Auto MDI/MDIX
INTERFERENCE IMMUNITY
DSSS (Direct Sequence Spread Spectrum)
ENCRYPTION
128-bit AES, FIPS 197/NIST certified (optional FIPS 140-2)
RADIO CHANNELS/BANDWIDTH
12 channels (6 in international version) with 2.0833 MHz spacing and 1.75 MHz occupied bandwidth
FREQUENCY BAND
ISM 902-928 MHz (915-928 MHz international version)
FREQUENCY AGILITY
Radio channel automatically selected and adaptively optimized
MANUAL FREQUENCY MODE
Channel selected with DIP switch or web browser interface
STATUS LEDS
Power, RF TX/RX, Ethernet link, channel, link quality
ERROR-CORRECTION TECHNIQUE
Sub-block error detection and retransmission
ADJACENT-BAND REJECTION
>60 dB - SAW receiver filter attenuates cellular and pager interference
REGULATOR TYPE
Switching regulator
ANTENNA CONNECTOR
RF RPTNC female
POE (POWER OVER ETHERNET)
Proprietary system included
SUBSCRIBER UNITS
Up to 16 active (63 total) per access point
SERIAL NUMBER BASED MATING PROTOCOL
Yes
DIMENSIONS (L X W X H) AND WEIGHT
7.9 in x 3.6 in x 2.4 in (20.0 cm x 9.1 cm x 6.1 cm); 415 grams
POWER REQUIREMENTS
POWER CONSUMPTION
Transmit: 1.7W, Receive: 0.8W
TRANSMIT CURRENT DRAW
9 - 48 VDC Power over Ethernet, 175 mA at 9 VDC, 140 mA at 12 VDC, 35 mA at 48 VDC
POWER CONNECTOR
Use PoE injector, power jack P5-2.1 mm center positive
ENVIRONMENTAL
OPERATING TEMPERATURE
Radio/Enclosure: -40° C to +70° C; POE injector: -40° C to +85° C; Power supply: 0° C to +40° C
WEATHERPROOFING
The XPress Ethernet Bridge is IP65 rated. The PoE injector and power supply are not weatherproof and should be installed indoors.
REGULATORY APPROVALS
FCC (U.S.A)
Yes
IC (CANADA)
Yes
ETSI (EUROPE)
N/A
C-TICK (AUSTRALIA)
Yes
TELEC (JAPAN)
N/A
PART NUMBERS
DESCRIPTION
XEB09-CIPA
XPress Ethernet Bridge, Pair
XEB09-CIPAF
XPress Ethernet Bridge, Pair - with FIPS 140-2
XEB09-CIPA-W
XPress Ethernet Bridge, Pair (International)
XEB09-CISA
XPress Ethernet Bridge, Single
XEB09-CISAF
XPress Ethernet Bridge, Single - with FIPS 140-2
XEB09-CISAFB
XPress Ethernet Bridge, Radio Board - with FIPS 140-2
XEB09-CISA-W
XPress Ethernet Bridge, Single (International)
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
© 1996-2015 Digi International Inc. All rights reserved.
All trademarks are the property of their respective owners.
91001402
D1/915
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL FRANCE
+33-1-55-61-98-98 / www.digi.fr
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
很抱歉,暂时无法提供与“XEB09-CISA-W”相匹配的价格&库存,您可以联系我们找货
