DKS-CRIMP-T1
DKS-CRIMP-T1
    DIGI-KEYELECTRONICS(得捷电子)
    手动压接器 工具 DKS-DIE-1,DKS-DIE-2,DKS-DIE-3
DKS-CRIMP-T1 数据手册
DKS-CRIMP-T1 Professional All-Purpose Crimping Hand Tool with Dies Product Highlights • • • Easy Handling Ratchet Release Ergonomic design Specifications: Length: Width: Depth: Weight: Packaging: Approx. 220mm Approx. 80mm Approx. 24mm Approx. 510 grams Box Conforms to the following Industry Standards: ROHS Compliant Yes Die Compatibility Die Part Number DKS-DIE-1 DKS-DIE-2 DKS-DIE-3 DKS-CRIMP-T1 Application Range Wire end ferrules with or without plastic shroud acc. to DIN 46228 Red/blue/yellow DIN cable lugs, pin cable lugs, tabs and receptacles, circular connectors and receptacles, and butt and parallel connectors. Non-insulated cable lugs, closed barrel Crimp tool with DKS-DIE-1, DKS-DIE-2, and DKS-DIE-3 Page 1 of 1 www.digikey.com Cross Section 0.14-10mm² Red: 0.5-1.5mm² / AWG 20 – 16 Blue: 1.5-2.5mm² / AWG 16 – 14 Yellow: 4.0-6.0mm² / AWG 12 – 10 0.1-10mm² / AWG 26 – 8
DKS-CRIMP-T1 价格&库存
很抱歉,暂时无法提供与“DKS-CRIMP-T1”相匹配的价格&库存,您可以联系我们找货
