CPCI-AC-3U-300R
CPCI-AC-3U-300R
    DIGITALPOWER
    AC/DC CNVRTR 5V 3.3V +/-12V 354W
CPCI-AC-3U-300R 数据手册
CPCI-3U-R (Ruggedized) COTS Series (877) 634-0982 www.digipwr.com 200–300 Watt Military Grade Compact-PCI Power Supply for Harsh Environment and Military Applications Product Specification Universal AC Input with PFC, 48VDC or 24/28VDC Input Key Product Features Modified per Request • Up to 300W • 3U Cabinet • Environmentally Rugged • High Current 3.3V and 5V Outputs • Up to 40A • Accurate Current Sharing • Internal Oring FETs for redundant applications • PICMG 2.11 Compliant Specifications • Ruggedized for Enhanced Shock & Vibration Input Voltage Range—AC Input Input 85-264 VAC, 47-63Hz • Conformal Coated Voltage Range—48VDC Input Input 36-72 VDC Voltage Range—24/28VDC Input 18-36 VDC Operating Temperature Range Current -5°C to +55°C Full Power with 250 LFM Sharing Accuracy (V1 and V2) 10% Sharing – up to 6 units Cage Code 59947 Safety and EMC • UL/cUL 60950-1, IEC/EN60950-1 Approved (AC Input and 48 VDC Input) • EN55022 Level B Emissions (with external filter) Description The CPCI 3U Series of power supplies offer industry leading performance with up to 300 Watts in a 3U package. A full range of AC Input, 24/28VDC Input and 48VDC Input products is available and all products are compliant to the PICMG 2.11 power interface specification. These CPCI products are ruggedized and excel in defense and harsh industrial applications. Model Selection Model Input Output Power V1 Output V2 Output V3 Output V4 Output NSN CPCI-AC-3U-200R 85-264VAC 200W +5V/20A +3.3V/30A +12V/3A -12V/0.5A 6130-01-526-6870 CPCI-AC-3U-300R 85-264VAC 300W +5V/30A +3.3V/40A +12V/5A -12V/1.0A 6130-01591-7607 CPCI-DC-3U-200/24R 24/28VDC (18–36) 200W +5V/25A +3.3V/36A +12V/3A -12V/0.5A 6130-01-526-6793 CPCI-DC-3U-300/24R 24/28VDC (20–36) 300W +5V/30A +3.3V/40A +12V/5A -12V/0.5A CPCI-DC-3U-200/48R 48VDC (36–72) 200W +5V/20A +3.3V/30A +12V/3A -12V/0.5A CPCI-DC-3U-300/48R 48VDC (36–72) 300W +5V/30A +3.3V/40A +12V/5A -12V/1.0A VDC-Out Adjustment Range: V1= 4.8V-5.4V; V2=3.1V-3.5V; V3=0V; V4=0V CPCI-3U-200 Watt: Note: Maximum output power at any combination within this table is 200W CPCI-3U-300 Watt: Notes: 1) Maximum output power at any combination within this table is 300W 2) Maximum output power on V1+V3 not exceed 185W 3) Maximum output power on V2+V4 not exceed 138W CPCI-3U Series Electrical Specifications Input AC Models 85–264 VAC, 47–63 Hz Power Factor >0.90/0.95 typical @ 110/220 VAC (full load) Hold-up Time 20 ms minimum (full load) Inrush Current
CPCI-AC-3U-300R 价格&库存
很抱歉,暂时无法提供与“CPCI-AC-3U-300R”相匹配的价格&库存,您可以联系我们找货
