DK16H
DIN Rail Terminal Blocks > Screw Connection
Date:2023-01-26Version:1.2
The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design.
The final product is made according to engineering drawing.
Product Description
M5, 600V, 100A, Beige (default)
General information
Short description
Category
Color
Connection method
Type of locking
DIN rail terminal blocks, Feed through terminal blocks
Beige (default)
Screw connection
Rail mounting
Length (mm)
48
Width (mm)
12
Height (mm)
51.3
Number of positions
≥1P
Level
Connection points
Single level
2
Material information
Insulation material
Insulation material group
Flame retardant rating , compliant with UL94
TEL: +886-2-8069-9000 / E-mail: service@dinkle.com
© DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED
PA
I
V0
1/4
Insulation resistance
≥500MΩ at DC 500V
Connection data-IEC
Rated voltage (V)
1000
Rated current (A)
101
Rated voltage (III/3)(V)
1000
Rated impulse voltage (II/2)(KV)
8
Rated impulse voltage (III/2)(KV)
8
Rated impulse voltage (III/3)(KV)
8
Conductor cross section solid. min (mm²)
1.5
Conductor cross section solid.max (mm²)
25
Conductor cross section stranded. min (mm²)
1.5
Conductor cross section stranded. max (mm²)
25
Conductor cross section flexible, with min ferrule
without plastic sleeve (mm²)
1.5
Conductor cross section flexible, with max ferrule
16
Conductor cross section flexible, with min ferrule with
1.5
Conductor cross section flexible, with max ferrule with
16
2 conductors with same cross section, solid, min (mm²)
1.5
2 conductors with same cross section, solid, max (mm²)
6
2 conductors with same cross section, stranded, min
(mm²)
1.5
2 conductors with same cross section, stranded, max
(mm²)
6
2 conductors with same cross section flexible, with min
ferrule without plastic sleeve (mm²)
1.5
2 conductors with same cross section flexible, with max
6
2 conductors with same cross section flexible, min twin
ferrules with plastic sleeve (mm²)
1.5
2 conductors with same cross section flexible, max twin
10
Screw thread
M5
Slotted screwdriver size (Blade thickness x Width)(mm)
Philips screwdriver size
Rated torque (N.m)
1.0x5.5
PH2
2.5~3.4
2/4
Recommend tightening torque. min (N.m)
2.5
Recommend tightening torque. max (N.m)
3.4
Stripping Length (mm)
13~15
Mounting rail
TS-35
End cover plate required
YES
Grounding connections
NO
Connection data-UL
Rated voltage (UL/CUL Group B)(V)
600
Rated current (UL/CUL Group B)(A)
100
Rated voltage (UL/CUL Group C)(V)
600
Rated current (UL/CUL Group C)(A)
100
Min. solid wire connection (AWG) acc. to UL/CUL
14
Max. solid wire connection AWG acc. to UL/CUL
3
Min. stranded wire connection AWG acc. to UL/CUL
14
Max. stranded wire connection AWG acc. to UL/CUL
3
Environment & Safety
Back of the hand protection (YES or NO)
YES
Finger protection (YES or NO)
YES
Operating temperature. max (°C)
120
Operating temperature. min (°C)
-40
UL Recognized
Wire Range (Group B)(AWG)
14~3
Rated voltage (Group B)(V)
600
Rated current (Group B)(A)
100
Wire Range (Group C)(AWG)
14~3
Rated voltage (Group C)(V)
600
Rated current (Group C)(A)
100
CUL Recognized
14~3
600
100
3/4
14~3
600
100
VDE Approval
Wire Range (mm²)
1.5~25
Rated voltage (V)
1000
Rated current (A)
101
Drawings
Approvals
Powered by TCPDF (www.tcpdf.org)
4/4
很抱歉,暂时无法提供与“DK16H”相匹配的价格&库存,您可以联系我们找货
