DKU20
DKU20
    DINKLE(台湾町洋)
    FEED-THRU SCW GDE RAIL TERM BLK
DKU20 数据手册
DKU20 NEMA Terminal Blocks > Rail Mounting Date:2022-06-09 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description M3.5, 600V, 20A General information Short description Category Pitch (mm) Color Connection method Type of locking Feed-Through single level, Screw Connection Feed-Through single level 8.2 Refer to drawing Screw Connection Rail mounting Length (mm) 40.5 Width (mm) 8.2 Height (mm) 33.5(TS-35N)/41(TS-35/15N) Number of poles 01P Number of positions 01P Level 1 Connection points 2 Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PC 1/4 Insulation material group Ⅲa Flame retardant rating , compliant with UL94 V2 Insulation resistance ≥1000MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 630 Rated current (A) 24 Rated voltage (III/3)(V) 630 Rated impulse voltage (III/3)(KV) 8 Conductor cross section solid. min (mm²) 0.2 Conductor cross section solid.max (mm²) 2.5 Conductor cross section stranded. min (mm²) 0.2 Conductor cross section stranded. max (mm²) 2.5 Screw thread M3.5 Philips screwdriver size PH2 Rated torque (N.m) 1~1.3 Recommend tightening torque. min (N.m) 1 Recommend tightening torque. max (N.m) 1.3 Stripping Length (mm) Mounting rail The stripping length depends on the specification provided by the cablelug manufacturer. TS-35N、TS-35/15N End cover plate required YES Grounding connections NO Connection data-UL Rated voltage (UL/CUL Group B)(V) 600 Rated current (UL/CUL Group B)(A) 20 Rated voltage (UL/CUL Group C)(V) 600 Rated current (UL/CUL Group C)(A) 20 Rated voltage (UL/CUL Group D)(V) 600 Rated current (UL/CUL Group D)(A) 20 Min. solid wire connection (AWG) acc. to UL/CUL 26 Max. solid wire connection AWG acc. to UL/CUL 12 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Min. stranded wire connection AWG acc. to UL/CUL 26 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 125 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 26-12 Rated voltage (Group B)(V) 600 Rated current (Group B)(A) 20 Wire Range (Group C)(AWG) 26-12 Rated voltage (Group C)(V) 600 Rated current (Group C)(A) 20 Wire Range (Group D)(AWG) 26-12 Rated voltage (Group D)(V) 600 Rated current (Group D)(A) 20 CUL Recognized Wire Range (Group B)(AWG) 26-12 Rated voltage (Group B)(V) 600 Rated current (Group B)(A) 20 Wire Range (Group C)(AWG) 26-12 Rated voltage (Group C)(V) 600 Rated current (Group C)(A) 20 Wire Ranget (Group D)(AWG) 26-12 Rated voltage (Group D)(V) 600 Rated current (Group D)(A) 20 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
DKU20 价格&库存
很抱歉,暂时无法提供与“DKU20”相匹配的价格&库存,您可以联系我们找货
