ED350V-XXP
PCB Terminal Blocks > PCB Terminal Blocks
Date:2021-05-19Version:V1
The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design.
The final product is made according to engineering drawing.
Product Description
Pitch : 3.50mm , 300V , 10A
General information
Short description
Category
Pitch (mm)
Color
Connection method
Type of locking
PCB Terminal Blocks , Wire Protector Type
PCB Terminal Blocks
3.5
Green(default)
Wire Protector Type
Without
Length (mm)
3.50xP
Width (mm)
6.8
Height (mm)
8.4
Pin demensions (Thickness x Width)(mm)
Ø0.77
PCB hole diameter (mm)
1.0~1.2
Number of positions
02~21
Level
Single level
Material information
Insulation material
TEL: +886-2-8069-9000 / E-mail: service@dinkle.com
© DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED
PA
1/4
Insulation material group
Flame retardant rating , compliant with UL94
Conductor material
Plating of conductor surface
I
V0
Copper Alloy
Tinned
Connection data-IEC
Rated voltage (V)
130
Rated current (A)
10
Rated voltage (II/2)(V)
320
Rated voltage (III/2) (V)
160
Rated voltage (III/3)(V)
160
Rated impulse voltage (II/2)(KV)
2.5
Rated impulse voltage (III/2)(KV)
2.5
Rated impulse voltage (III/3)(KV)
2.5
Conductor cross section solid. min (mm²)
0.5
Conductor cross section solid.max (mm²)
1.5
Conductor cross section stranded. min (mm²)
0.5
Conductor cross section stranded. max (mm²)
1.5
Conductor cross section flexible, with min ferrule
without plastic sleeve (mm²)
0.25
Conductor cross section flexible, with max ferrule
1.5
Conductor cross section flexible, with min ferrule with
0.25
Conductor cross section flexible, with max ferrule with
1.5
2 conductors with same cross section, solid, max (mm²)
0.75
2 conductors with same cross section, stranded, max
(mm²)
0.75
Screw thread
M2
Rated torque (N.m)
0.2
Stripping Length (mm)
5~6
Connection data-UL
Rated voltage (UL/CUL Group B)(V)
300
Rated current (UL/CUL Group B)(A)
10
Min. solid wire connection (AWG) acc. to UL/CUL
24
2/4
Max. solid wire connection AWG acc. to UL/CUL
16
Min. stranded wire connection AWG acc. to UL/CUL
24
Max. stranded wire connection AWG acc. to UL/CUL
18
Environment & Safety
Finger protection (YES or NO)
YES
Operating temperature. max (°C)
115
Operating temperature. min (°C)
-40
UL Recognized
Wire Range (Group B)(AWG)
24~16
Rated voltage (Group B)(V)
300
Rated current (Group B)(A)
10
CUL Recognized
24~16
300
10
VDE Approval
Wire Range (mm²)
0.5~1.5
Rated voltage (V)
130
Rated current (A)
10
Drawings
3/4
Approvals
Powered by TCPDF (www.tcpdf.org)
4/4
很抱歉,暂时无法提供与“ED350V-06P”相匹配的价格&库存,您可以联系我们找货
