MM400E
MM400E
    DREMEL
    MM400E EDGE STARTER KIT
MM400E 数据手册
  Dremel MM400E Wood & Metal Blade Model # MM400E Product Specifications The Edge™ Cutting System Is Created For People Who Do A Lot Of Cutting With Their Oscillating Tool And Want To Save Time And Money On New Cutting Blades.       Wood and metal flush cut blade-- Bi-Metal teeth optimized for fast cutting in wood and metal materials Wood flush cut blade--high carbon steel teeth optimized for fast cutting in wood and plastic materials Universal adapter interface to fit most competitive brands in the market Fast blade change-- loosen screw to change accessory   DIMENSIONS Blade Thickness (in): Description: Blade Thickness: Blade Length: Warranty: Contents: Blade Width: Color Code: 0.024 MM400E is a cutting kit that includes: 1 Edge Adapter, 1 - MM402E Wood Flush Cut Blade, 1 - MM404E BiM Flush Cut Blade, 1 - Hex Key, 1 - Hex Key Holder (Attaches to power cord) 0.024["] 2.22 Product Defects Only 4 Blades 1.28 Red https://www.dremel.com/en_US/products/-/show-product/accessories/dremel-mm400e-wood-metal-blade 10-10-18
MM400E 价格&库存
很抱歉,暂时无法提供与“MM400E”相匹配的价格&库存,您可以联系我们找货
