SD60-PGK EZ Lock Pet Nail Grooming
Discs
Model # SD60-PGK
Product Specifications
The use of scissor- and guillotine-type clippers apply pressure and pinch the nail, which can be
uncomfortable for pet toes and feet. Dremel Pet Nail Grooming Discs are designed for use with
the Dremel AT01-PGA Pet Grooming Nail Guard. Pet nail grooming discs fit the Dremel EZ
Lock mandrel to make accessory changes easy as PULL - TWIST – RELEASE to allow you to
quickly, easily and gently trim your pet's nails. Includes 10 EZ Lock Pet Nail Grooming Discs.
Sized to fit inside the Dremel get grooming nail guard
Fits EZ Lock mandrel for fast and easy accessory changes
Can be used for general sanding purposes
Ideal grit for pet nail grooming
DIMENSIONS
Diameter:
Description:
Quantity:
Weight:
Grit:
20 mm
SD60-PGK EZ Lock Pet Nail Grooming Discs
10 pieces per pack
0.02[kg, lb, oz]
60 (Coarse)
https://www.dremel.com/en_US/products/‐/show‐product/accessories/sd60‐pgk‐ez‐lock‐pet‐nail‐grooming‐discs 10‐11‐18
很抱歉,暂时无法提供与“SD60-PGK”相匹配的价格&库存,您可以联系我们找货
