VC490
VC490
    DREMEL
    VELOCITY VC490 PANEL BLADE
VC490 数据手册
                                VC490 Velocity Panel Blade Model # VC490  Product Specifications The Dremel VC490 Panel Blade is made for making long, straight rip cuts in plywood, wood, laminates and drywall. Its Bimetal construction optimizes the VC490 for metal cutting, so you’ll experience no more destroyed teeth if you hit a nail while cutting. The VC490 Panel Blade is also designed to optimize cutting while using the control foot on the Dremel Velocity tool. When using the foot, the blade sits at the perfect angle to ensure cutting accuracy, along with an enhanced speed of cut.  Blade geometry provides enhanced speed of cut and accuracy when used with Dremel Velocity tool  Bimetal blade material for high performance wood/metal cutting applications  Curved hub and reinforced cutting blank prevents blade‐flex while cutting through even the toughest materials for a straight, accurate cut  Universal Quick‐Fit interface – Directly fits all Dremel®, Rockwell®, Ridgid®, Fein®, Makita®, Craftsman®, Ryobi® and Milwaukee® oscillating tools       DIMENSIONS Blade Thickness (in): 0.375 Description: VC490 Velocity Panel Blade Blade Thickness: 0.375["] Model Number: VC490 Blade Length: 5 Application: VC490 Panel Blade for cutting wood and metal materials. Great for making long straight cuts in plywood, wood, laminates and drywall. Warranty: Product Defects Only Used on Model No.: VC60, MM20, MM30, MM40, MM45 Blade Width: 1 Color Code: Red Depth of Cut: 2‐7/8"                        https://www.dremel.com/en_US/products/‐/show‐product/accessories/vc490‐velocity‐panel‐blade 10‐12‐18
VC490 价格&库存
很抱歉,暂时无法提供与“VC490”相匹配的价格&库存,您可以联系我们找货
