Series 04
22.5mm 30.5mm IP65 10A 600VAC
Choose one component from each of the
colored sections to assemble a complete switch.
INDICATOR
PUSHBUTTON
E-STOP
MUSHROOM
KEYLOCK
Product Profile
SELECTOR
BUZZER
Indicator
The Series 04 is a high quality switch
range that includes pushbuttons,
indicators, selectors, mushroom
headed switches, key switches,
and Emergency-stops.
Options include self cleaning,
slow-make and snap-action
switching elements.
Technical drawings see pages 18-21
• IP65 Protection
• Switch Rating:
Maximum Voltage, 600VAC
Maximum Thermal Current, Ith = 10A
230VAC/6A, 24VDC/10A
• Raised Mounting into 22.5mm cut out
• Flush Mounting into 30.5mm cut out
• Illumination using Ba9s (T-31/4 bayonet
base) Lamps or LED’s
• All standard lenses are transparent
with translucent diffuser
• Screw terminal or plug-in connections
Indicator, round, full face, 22.5mm mounting
Color
Part No.
Indicator, flush mount, aluminum bezel,
30.5mm mounting
Color
Part No.
Red
704.000.2
Red
704.006.218
Yellow
704.000.4
Yellow
704.006.418
Green
704.000.5
Green
704.006.518
Blue
704.000.6
Blue
704.006.618
Clear
704.000.7
Clear
704.006.718
For complete switch also order
Non illuminated raised pushbutton,
aluminum bezel, 22.5mm mounting
Non illuminated flush mount pushbutton,
aluminum bezel, 30.5mm mounting
Non-illuminated pushbutton
gray plastic bezel, 22.5mm mounting
Part Ordering System 704.02 -
Pushbutton
Action
Lens/Cap
Style
1-Momentary
2-Momentary
3-Momentary
4-Momentary
5-Maintained
6-Maintained
7-Maintained
8-Maintained
Standard-plastic
Standard-metal
Extended-plastic
Mushroom-plastic
Standard-plastic
Standard-metal
Extended-plastic
Mushroom-plastic
www.eaoswitch.com 10
Front Ring
Style
A
0-Standard
1-Standard
2-Sealed
3-Sealed
4-Standard
6-Standard
7-Extended
9-Standard
* Only available in
standard plastic
Material
Black plastic
Anodized Al
Ni plated brass
Silicone cover
Anodized Al
Silicon cover
Chrome plastic
Gray plastic
Gray plastic
Steel
Color
Diffuser
Type
Lens/Cap
Color
0-Black
1-No diffuser
(Mushroom or
opaque lens)
7-Clear
9-White
0-Black
2-Red
3-Orange*
4-Yellow
5-Green
6-Blue**
7-White ***
8-Aluminum**
9-Steel**
** Not available with
mushroom cap
*** Combination of clear
lens and white diffuser
EAO Switch Condensed Catalog 100
Part No., Momentary
Part No., Maintained
Red
704.012.218
704.042.218
Yellow
704.012.418
704.042.418
Green
704.012.518
704.042.518
Blue
704.012.618
704.042.618
Clear
704.012.718
704.042.718
Black
704.012.018
704.042.218
A
Series 04
A
Choose one component from each of the colored sections to assemble a complete switch.
For other options or further information please contact EAO Switch directly.
BLOCK
LED
ACCESSORIES
Illuminated pushbutton
Illuminated raised pushbutton,
Part Ordering System 704.01 -
Pushbutton
Action
Lens
Style
Termination
Style
1-Momentary
2-Momentary
3-Momentary
4-Momentary
5-Maintained
6-Maintained
7-Maintained
8-Maintained
9-Momentary
10-Momentary
11-Maintained
12-Maintained
Standard
Standard
Extended
Extended
Standard
Standard
Extended
Extended
Mushroom
Mushroom
Mushroom
Mushroom
Screw
0.250” Q.C.
Screw
0.250” Q.C.
Screw
0.250” Q.C.
Screw
0.250” Q.C.
Screw
0.250” Q.C.
Screw
0.250” Q.C.
Front Ring
Material
0-Standard
1-Standard
2-Sealed
4-Standard
6-Standard
7-Extended
9-Standard
A
Diffuser*
Type
Black plastic
Anodized Al
Ni plated brass
Silicon cover
Anodized Al
Silicon cover
Chrome plastic
Gray plastic
Gray plastic
Steel
3-Sealed
Illuminated flush mount pushbutton,
Color
Lens
Color
7-Clear
9-White
2-Transparent red
3-Transparent orange
4-Transparent yellow
5-Transparent green
6-Transparent blue
7-White (uses clear
lens/white diffuser)
Part No., Momentary
Red
704.032.218
704.062.218
Yellow
704.032.418
704.062.418
Green
704.032.518
704.062.518
Blue
704.032.618
704.062.618
Clear
704.032.718
704.062.718
*White translucent for incandescent lamps and clear knurled for neon
A
Part Ordering System 704.03 -
Pushbutton
Action
Lighted or
Unlighted
Film
Insert
0-Momentary
1-Momentary
2-Momentary
3-Momentary
4-Maintained
5-Maintained
6-Maintained
7-Maintained
Lighted
Lighted
Unlighted
Unlighted
Lighted
Lighted
Unlighted
Unlighted
With
Without
With
Without
With
Without
With
Without
Lamp
Holder
Bezel
Color
0-No lamp holder
1-Lamp holder screw terminals
2-Lamp holder 0.250" Q.C. terminals
A
0-Black
4-Chrome
6-Light gray
Lens
Color
0-Black
2-Red
3-Orange
4-Yellow
5-Green
6-Blue
7-White*
*Combination of clear lens and white diffuser
11
Series 04
INDICATOR
PUSHBUTTON
E-STOP
MUSHROOM
KEYLOCK
SELECTOR
BUZZER
Emergency-stop switch
Emergency-stop, twist release, 37mm
diameter, foolproof to EN 60947-5-1 and
EN 418, use slow-make switching elements
Emergency-stop, key release, 37mm diameter,
foolproof to EN 60947-5-1 and EN 418,
Part No.
Part No.
704.064.2
704.066.2
A
Mushroom headed pushbutton, plastic bezel
and aluminum bezel, 22.5mm mounting,
function momentary
Front Ring
Markings
704.074.2
Gray plastic
Directional arrows
704.075.2
Anodized aluminum
Directional arrows
A
Keylock switch
Color
Part No.
For emergency stop applications, a maximum
of 2 switching elements can be used
Emergency-stop, twist release, mushroom
head, 40mm diameter, use slow-make
switching elements
Keylock switch 2 position,
raised, 22.5mm mounting
A
1
B
Mom 42°
Drawing
Part No.
Action
2
C
B
Maint 90°
Key rem.
Drawing
Part No.
A
3
Keylock switch
2 position, flush mount,
30.5mm mounting
B
Mom 42°
Action
4
C
B
Maint 90°
Key rem.
Part No., Plastic
Part No., Aluminum
Red
704.070.2
704.071.2
1
704.123.0
Momentary
A
3
704.123.018
Momentary
A
Yellow
704.070.4
704.071.4
2
704.121.0
Maintained
C
4
704.121.018
Maintained
C
Green
704.070.5
704.071.5
Black
704.070.0
704.071.0
Maintained versions available as well
www.eaoswitch.com 12
A
A
A
Series 04
A
BLOCK
Keylock switch
A
5
C
A
B
6
C
Mom 42°
Part No.
ACCESSORIES
Selector switch
Keylock switch 3 position,
Drawing
LED
B
Maint 90°
Action
Key rem.
Keylock switch
3 position, flush mount,
30.5mm mounting
Drawing
A
7
C
B
Maint/Mom 42°
Part No.
Action
Key rem.
Drawing
Part No.
A
8
Selector switch short
lever 2 position, raised,
22.5mm mounting
9
B
Mom 42°
Action
C
B
Maint 90°
Bezel
5
704.115.0 Momentary/Momentary
A
7
704.115.018 Momentary/Momentary
A
8
704.412.0
Momentary
Gray plastic
6
704.114.0
A
7
704.114.018 Maintained/Maintained
A
8
704.413.0
Momentary
Aluminum
A
A
9
704.410.0
Maintained
Gray plastic
9
704.411.0
Maintained
Aluminum
A
Selector switch
Selector switch short lever
30.5mm mounting
Drawing
Part No.
A
A
10
B
Mom 42°
Action
11 C
B
Maint 90°
Bezel
12
3 position, raised,
22.5mm mounting
Drawing
Part No.
C
A
B
Maint/Mom 42°
Action
Bezel
13
30.5mm mounting
Drawing
Part No.
C
B
Maint/Mom 42°
Action
Bezel
10
704.413.018
Momentary
Aluminum
12
704.404.0 Momentary/Momentary Gray plastic
13
704.405.018
Momentary
Aluminum
11
704.411.018
Maintained
Aluminum
12
704.405.0 Momentary/Momentary Aluminum
13
704.403.018
Maintained
Aluminum
12
704.402.0 Maintained/Maintained Gray plastic
12
704.403.0 Maintained/Maintained Aluminum
A
A
A
13
Series 04
INDICATOR
PUSHBUTTON
E-STOP
MUSHROOM
KEYLOCK
SELECTOR
BUZZER
Selector switch
Drawing
A
14
Selector switch long
22.5mm mounting
15
B
Mom 42°
Part No.
Action
C
B
Maint 90°
Bezel
Selector switch long lever
30.5mm mounting
Drawing
Part No.
A
16
17
B
Mom 42°
Action
C
B
Maint 90°
Bezel
A
lever 3 position, raised,
22.5mm mounting
Drawing
Part No.
18
C
B
Maint/Mom 42°
Action
Bezel
14
704.102.0
Momentary
Gray plastic
16
704.103.018
Momentary
Aluminum
18
704.094.0
Momentary
Gray plastic
14
704.103.0
Momentary
Aluminum
17
704.101.018
Maintained
Aluminum
18
704.095.0
Momentary
Aluminum
15
704.100.0
Maintained
Gray plastic
18
704.092.0
Maintained
Gray plastic
15
704.101.0
Maintained
Aluminum
18
704.093.0
Maintained
Aluminum
A
Selector switch
A
A
Buzzer
A
lever 3 position, flush mount,
30.5mm mounting
Drawing
Part No.
19
C
B
Buzzer, plastic bezel, raised, 22.5mm mounting,
24VDC, 95dB ± 8 at a distance of 0.1m
Maint/Mom 42°
Action
Part No.
Front finish
Part No.
Front finish
19
704.095.018
Momentary
Aluminum
14-810.002
Black plastic
14-810.910
Black plastic
19
704.093.018
Maintained
Aluminum
14-810.902
Chromium-plated
14-810.918
Chromium-plated
www.eaoswitch.com 14
Bezel
Buzzer, plastic bezel, flush mount,
30.5mm mounting, 24VDC, IP40,
A
Series 04
A
BLOCK
Contact block
LED
ACCESSORIES
LED
Contact block, screw terminal, snap-action
with silver self-cleaning contacts
Contact block, screw terminal, slow-make
(positive-break) with silver forced
opening contacts
LED, Ba9s (T-31/4 bayonet base), single chip,
6 Volt and 12 Volt
Part No.
Contact type
Part No.
Contact type
Part No.
Voltage
704.900.1
1NO
704.910.2
1NC
Red
10-2506.1082
6VDC, 17mA
704.900.2
1NC
704.910.4
2NC
Yellow
10-2506.1084
6VDC, 17mA
704.900.3
2NO
704.910.5
1NO/1NC
Green
10-2506.1085
6VDC, 17mA
704.900.4
2NC
704.910.1
1NO
Blue
10-2506.1086
6VDC, 17mA
704.900.5
1NO/1NC
704.910.2
2NO
White
10-2506.1089
6VDC, 17mA
Red
10-2509.1142
12VAC/DC, 16mA
Yellow
10-2509.1144
12VAC/DC, 16mA
Green
10-2509.1145
12VAC/DC, 7mA
Blue
10-2509.1146
12VAC/DC, 16mA
White
10-2509.1149
12VAC/DC, 16mA
Not recommended for
Emergency-stop applications
Color
LED
LED, Ba9s, single chip, (T-31/4 bayonet base)
24 Volt and 28 Volt
LED, Ba9s, (T-31/4 bayonet base) single chip,
48 Volt
130 Volt and 230 Volt
Color
Color
Color
Part No.
Voltage
Part No.
Voltage
Part No.
Voltage
Red
10-2512.1142
24VAC/DC, 15mA
Red
10-2519.1052
48VAC/DC, 8mA
Red
10-2H24.2052
130VAC / 5mA
Yellow
10-2512.1144
24VAC/DC, 15mA
Yellow
10-2519.1054
48VAC/DC, 8mA
Yellow
10-2H24.2054
130VAC / 5mA
Green
10-2512.1145
24VAC/DC, 7mA
Green
10-2519.1055
48VAC/DC, 4mA
Green
10-2H24.2055
130VAC / 3mA
Blue
10-2512.1146
24VAC/DC, 15mA
Blue
10-2519.1056
48VAC/DC, 8mA
Blue
10-2H24.2056
130VAC / 5mA
White
10-2512.1149
24VAC/DC, 15mA
White
10-2519.1059
48VAC/DC, 8mA
White
10-2H24.2059
130VAC / 5mA
Red
10-2513.1142
28VAC/DC, 13mA
Red
10-2H25.2042
230VAC / 3mA
Yellow
10-2513.1144
28VAC/DC, 13mA
Yellow
10-2H25.2044
230VAC / 3mA
Green
10-2513.1145
28VAC/DC, 7mA
Green
10-2H25.2045
230VAC / 2mA
Blue
10-2513.1146
28VAC/DC, 13mA
Blue
10-2H25.2046
230VAC / 3mA
White
10-2513.1149
28VAC/DC, 13mA
White
10-2H25.2049
230VAC / 3mA
15
Series 04
INDICATOR
A
PUSHBUTTON
E-STOP
MUSHROOM
KEYLOCK
SELECTOR
BUZZER
Accessories
Lens cap, round, transparent, plastic for
raised and flush indicators with bezel and
pushbutton actuators
Color
Protective cover, raised pushbutton
Protective front ring with silicon membrane
for raised or flush mount pushbutton, natural
anodized aluminum
Part No.
Part No.
Red
704.602.2
704.925.0 for pushbuttons
Comment
704.600.3 29mm Ø for raised pushbutton
Part No.
Size
Yellow
704.602.4
704.925.3 for selector with short
704.955.3 35mm Ø for flush mount pushbutton
Green
704.602.5
lever with “self return”
Blue
704.602.6
Clear
704.602.7
For complete lens also order diffuser
704.609.9 (see page 21)
A
Accessories
1
Emergency-stop protective shroud, yellow
painted aluminum with 22.5mm mounting hole
Emergency-stop switch label, 60mm
diameter, English, French and German
with adhesive backing
Part No.
Part No.
Contact EAO Switch directly
704.963.6
Markings
1
704.945.0
704.963.5
Not Aus
2
704.945.6
704.963.7
Arret D’urgence
Blank
90mm versions also available
www.eaoswitch.com 16
Emergency-stop switch enclosure with
Emergency stop
44-950
2
Part No.
Series 04
A
BLOCK
A
ACCESSORIES
Accessories
Blanking plate
Part No.
A
LED
Lens, LED and lamp remover
Part No.
Part No.
704.960.7
Mounting hole
22.5mm Ø
704.955.0
700.006.0
704.964.8
30.5mm Ø
704.955.1
Accessories
1
1
2
2
Legend plate, adhesive, natural anodized
aluminum finish for raised and flush
mount pushbuttons
Label for front bezel set for 22.5 and 30.5mm
flush mount with label support, self adhesive
Part No.
Mounting hole
1
704.968.2
22.5mm Ø
1
704.968.0
Part No.
2
704.968.3
30.5mm Ø
2
704.968.1
17
Series 04
Technical Drawings
04 Indicator
04 Indicator
Raised
Flush
04 Pushbutton
04 Pushbutton
Non-Illuminated, Raised
Non-Illuminated, Flush
04 Pushbutton
04 Pushbutton
Illuminated, Raised
www.eaoswitch.com 18
Illuminated, Flush
Technical Drawings
04 E-Stop
EN 418
Series 04
04 E-Stop
EN 418 with optional key
04 E-Stop Mushroom
04 Keylock
Pushbutton Mushroom
2-Position, 3-Position, Raised
04 Keylock
04 Selector
2-Position, 3-Position, Flush
2-Position, 3-Position, Short and Long, Flush
19
Series 04
Technical Drawings
04 Selector, Short Lever
04 Selector, Long Lever
04 Buzzer
04 Buzzer
Raised
Flush
www.eaoswitch.com 20
Technical Drawings
Series 04
04 Cut-outs, Raised Mounting
04 Cut-outs, Flush Mounting
(All but long lever)
04 Long Lever Cut-outs, Raised Mounting
04 Long Lever Cut-outs, Flush Mounting
04 E-Stop EN418 Cut-outs
04 E-Stop Mushroom Cut-outs
Pushbutton Mushroom
21
